Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 30, 2009, 05:06 AM   #1
Personal Sales Rating: (19)
sykou's Avatar
Drives: 2003 Lancer OZ Rally
Lightbulb Front sway bar bushings installed
Installed the energy suspension endlinks along with the bushings. FYI the 25mm sway bar bushing set is NOT a direct fit. The passenger side will fit but the drivers side requires some modification. The bushing "c-brackets" are too long in the Energy suspension set. You have to cut it to match the length of the stock one. Also you have to grind off the grease nipple completely as there isn't enough clearance for it. I do not know of any adverse affects of cutting it off but it is necessary.
As for the endlinks, it may be because i installed the bushings also, but hand tight+1 turn is definately not enough. The bushings in the energy suspension set are nuch thicker and need to be compressed more to match the original stock length. If not, the bushings do not seat correctly. I went till 4 threads were showing but i think it needs to be tightened even more. Btw this is with using the stock metal spacers along with all parts included in the kit. Endlinks were assembled correctly in this order from bottom to top; bolt-washer-bushing-lca-bushing-washer-spacer-washer-bushing-sway bar-bushing-washer-nut
__________________
"Everything is LEGAL... As long as you don't get caught."
Offline
Old May 30, 2009, 11:29 AM   #2
Personal Sales Rating: (3)
2001 Mitsubishi Lancer
Evo666's Avatar
Drives: the image above
Send a message via AIM to Evo666 Send a message via MSN to Evo666 Send a message via Yahoo to Evo666
pics please
__________________
Myspace - Cardomain
Offline
Old Jun 1, 2009, 11:25 AM   #3
sykou's Avatar
Dont have my camera now but ill take some this weekend. Oh and to check the sway bar clearance. I used a jack to push the control arm upwards. Should be ok right?
__________________
Offline
Tags
bar, bushings, endlinks, energy suspension, installed, space, sway, sway bar, tight
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
