Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer (DE,ES,GTS) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 29, 2009, 07:09 PM   #1
Personal Sales Rating: (0)
Drives: Lancer ES
Will these fit my ES....pls help!
I don't know much about tires/rims. Will these fit my ES Sport. If so, is there anything I need to match the Offset? I've listed the specs below.
Rims:
Make: Fast Wheels
Model: Techno (F41)
Size: 18” X 7.5”
Bolt Pattern: 5 X 114.3
Offset: +43
One Piece Alloy Wheel
Platinum Finish with Diamond Cut Lip
Clear Coated
60 degree Conical Seats
Center Cap Included
Valve Included
Tires:
General Exclaim UHP 225/40/18
Offline
Old May 29, 2009, 08:05 PM   #2
Personal Sales Rating: (11)
jRox's Avatar
Drives: Traded: WW 2008 Lancer GTS || Upgraded: WW 2009 Lancer Ralliart
Send a message via AIM to jRox
I would think it would fit. The most aggressive setup I've seen so far on 08/09 Lancers is 18x8.5 +30 offset and lowered on teins, but he had to slightly roll the fenders in the rear. So using this as a reference, you're setup should fit fine.
__________________
////////// FS: DRL Bypass w/ Relay Harness
Offline
Old May 29, 2009, 11:29 PM   #3
MasterAK's Avatar
Drives: 08 Lancer ES MT
They will fit perfectly
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Old May 30, 2009, 01:13 AM   #4
Stuntfly02's Avatar
Drives: Apex Silver 2008 Lancer GTS
if you can go with 235/40R18s instead of 225s you will be closer to your original tires overall diameter. Plus a slightly larger contact patch will improve traction/handling.
__________________
RRM SRI Intake
RRM Rear Strut Tower Bar
RRM Carbon Fiber Mirror Covers
RRM Carbon Fiber Splitter
RRM Emblem on rear
RRM Timing Module
Partially Debadged rear
Limo Tint on rear
Vortex Generator
Nikon D80 with Nikkor 18-55mm lens and 55-200mm lens.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
