Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 27, 2009, 11:19 AM   #1
Personal Sales Rating: (5)
mtags24's Avatar
Drives: 40+ MPG Lancer!
Brake Squeal
Hi guys I've been having a problem and need some advice:
I changed out my non-squeaking pads and rotors for some brembo replacement rotors and some PBR/Axxiss Ultimate pads. I used the stock shims (are those even necessary with new pads?) and the old clips. After about 50 miles they started squeaking VERY loudly.
I had a mechanic look it over and he said I did them perfectly; he said the squeaking was caused by the pad material. This doesn't make sense to me though because I have been using these pads for 2 years now and haven't had them make ANY noise above a slight grind.
My brake pedal feels good at low speeds but when hard braking at highway speeds I get some pulsations and a droning noise. I'm pretty sure this is due to the pads not sitting well. One of the clips on the left pad has come off now. I feel very strongly that the clips were not installed correctly and are causing the problem.
My quesion is: Should I just grab new clips and try to fix them? or should I grab some OEM pads and clips and just change the pads entirely? I'm worried that all this bad friction may have ruined my pads and that even with a clean install they will still squeal.
Thanks for your help! I'm getting really embarrassed riding around with this!
Offline
Old May 27, 2009, 11:25 AM   #2
Personal Sales Rating: (3)
2001 Mitsubishi Lancer
Evo666's Avatar
Drives: the image above
Send a message via AIM to Evo666 Send a message via MSN to Evo666 Send a message via Yahoo to Evo666
could be brake dust. Spray it down with brake cleaner and apply grease that prevents squealing.
__________________
Myspace - Cardomain
Offline
Old May 27, 2009, 12:55 PM   #3
Personal Sales Rating: (7)
blaze_125's Avatar
Drives: Yellow OZ
Changing the clips is an easy/cheap place to start. I say go with that first. And while you're down there, also go with Evo666's idea.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old May 27, 2009, 01:02 PM   #4
mtags24's Avatar
^ Thanks a lot guys! That's what I think I'll be doing this weekend.
I've read that the clips are only there as a brake alarm for when the pads need changing. others have said they are pivotal to keeping the brakes in place and not squeaking. Are they necessary at all?
Offline
Old May 27, 2009, 01:32 PM   #5
blaze_125's Avatar
Drives: Yellow OZ
The clips that go on the top and lower portion of the caliper are there to ensure the pad is in there tight enough to not wiggle around while you drive. Each corner has 4 clips, each corner has 1 of those clip with the squealer. The squealer is the wear indicator that screams when your pads are getting thin.
__________________
Offline
Old May 27, 2009, 02:10 PM   #6
Personal Sales Rating: (1)
Jehuty's Avatar
Drives: Cali into the arms of S6
Send a message via AIM to Jehuty
How do you know which clip goes in which spot. Some times I feel like I have the wrong clip in the wrong spot.
__________________
RAPTOR JESUS' ANGEL OF DEATH
WINNAR OF JEHUTY OF THE YEAR AWARD
Quote:
Originally Posted by 22stars View Post
i <3 Jehuty
Quote:
Originally Posted by mikesevo8 View Post
:walks in, looks around:
:grabs piece of chalk and writes "Jehuty>VincentX" on the wall:
:walks out:
Quote:
Originally Posted by Kurt View Post
Something is not right about you. I like that.
Quote:
Originally Posted by thetox View Post
shoot a load in her dumper or her belly will get plumper.
XBOX LIVE: TheMasterQweeph (XBOX live made me change my name....sigh)
Offline
Old May 27, 2009, 02:30 PM   #7
mtags24's Avatar
Quote:
Gotcha thanks! Now I know I can't just leave them out of the equation.
Jehuty- Yeah I also have that problem. I notice the clips are different shapes, and I think I always put them back the way they were, but I guess now I know my memory isn't too sharp.
Does anyone have a diagram/picture/explanation of how to correctly insert the clips and where each kind goes?
Offline
Old May 28, 2009, 06:10 AM   #8
blaze_125's Avatar
Drives: Yellow OZ
It's been a while since I've done brakes on the Lancer... but aren't they all the same except 1? Each corner has 4 clips. 3 identical, and 1 with the squealer. The one with the squealer goes on the back of the rotor in the bottom opening.
__________________
Offline
Old May 28, 2009, 07:44 AM   #9
Jehuty's Avatar
I'll check them out this weekend and take photos. I'm not entirely sure, I just know that when I put the clips in certain spots the caliper rejects the clips as if to say "hey stupid...wrong clip" so I feel insulted and I get all "yeah well I just won't put brakes on, that'll show you"....
in reality I just force them...I guess I need new clips
__________________
i <3 Jehuty
:walks out:
Offline
Old May 28, 2009, 11:58 AM   #10
mtags24's Avatar
hahaha yep that sounds like my brake pad changes! Some photos would be awesome, thanks man.
Offline
Old May 28, 2009, 12:03 PM   #11
mtags24's Avatar
Thanks for that explanation Blaze. So, what you are saying is that each front side has 4 clips that hold that pads in. Out of the 4 there will be 1 clip with the sound squealer that goes on the inside pad facing the inside of the car (as opposed to the pad facing out from the car). This squealer clip goes on the bottom part of this pad. Is that right?
Offline
Old May 28, 2009, 06:47 PM   #12
Personal Sales Rating: (0)
swankin's Avatar
Drives: '91 Celica GT-S (mine until an Evo comes along), '09 Lancer GTS (hers)
You could also be at a hard spot in the pads. If so, it should be gone in about another 50 miles or so.
Offline
Old May 29, 2009, 08:12 AM   #13
blaze_125's Avatar
Drives: Yellow OZ
Yes. As far as I remember the squealer goes inside... as in closest to the engine, in the lower caliper spot.
__________________
Offline
Old May 29, 2009, 08:26 AM   #14
Personal Sales Rating: (6)
evosam726's Avatar
Drives: WW IX,07 white Rav4, sold my teggy type-r
Send a message via AIM to evosam726
__________________
EvoSam
stuff wit some more stuff um
tanabe gf210 springs
jdm rear
apr lip
braille in-cabin brace
gt-spec rear trunk cage
uk cf evolution ix trunk badge
eclipse head unit w/ ipod adapter:D
stockturbo
4 sale
stock uicp w/ tial flange
stock radiator
stock evo ix cam's
stock fuel pump
:::just >726< here:::
Offline
Old May 29, 2009, 09:26 AM   #15
Jehuty's Avatar
I have aftermarket rotors and they are warped...it's really stupid. So I have to get new ones, plus I bought cheapo deapo pads from Auto Zone...so my car squealing is 100% my fault. Now to buy new clips, do I just go to the store and say "hey...I need new clips"
__________________
i <3 Jehuty
:walks out:
Offline
Tags
brake, fix, lancer, mitsubishi, squealer
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
