So here it goes...
The front calipers on my 93 Honda were seized. The slider pins where seized and the whole assembly had a hard time... The car was braking fine, but I had to pass a safety check and my calipers failed...
even though I could brake just fine.
So I got my-self 2 calipers from the local junker.
I removed the old calipers from the car and bled the lines leaving barely any fluid in the master cylinder.
I installed the "new" calipers and I'm having the following issue:
If the engine is not running, I can pump the brake pedal and build up pressure in the braking system.
If the engine is running, I can't get any pressure buildup.
What's your take on this?
I bled the system twice already, but I'll do it a third time tonight.
