Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 30, 2009, 02:44 PM   #1
Personal Sales Rating: (0)
Drives: 2005 OZ Rally Lancer
Control Arm Bushings
I searched and only found threads from 2005-2006; they said that no one makes replacement bushings for our control arms? Are you kidding me.
Has anything developed since then? Poly-Urethane? If I have to replace them where should I look: (I suspect that the dealer will charge an arm and a leg for their soft crappy ones that fall apart after 100,000 km anyway).
I have 108,000 kilometers on my car and the suspension is shot. I can't believe it.
I'm thinking new shocks and struts, end link bushings, and possibly control arm bushings.
Any suggestions?
Offline
Old Mar 30, 2009, 03:54 PM   #2
Drives: 2004 ES
I haven't seen any. Your best best is to just pick up some aftermarket replacement arms.
Offline
Old Mar 30, 2009, 07:29 PM   #3
Personal Sales Rating: (3)
KillahB's Avatar
Drives: 04 4G69 (daily) 97 Mirage 4G63 powered (fun)
Send a message via AIM to KillahB Send a message via Yahoo to KillahB
Have your control arm bushings been falling apart? That is weird since they are some of the longer lasting bushings on the car.
Nonetheless, you would want to find a Superpro dealer near you (or conversely, one online) and hope the wait time is bearable. This is for the CH-body style Lancer (05-08)
SPF1715K Front Control Arm Lower - Inner Front Bushing
SPF3112K Front Control Arm Lower - Inner Rear Eccentric Bushing
SPF3113K Front Control Arm Lower - Inner Rear Eccentric Bushing
SPF3111K Front Control Arm Lower - Inner Rear Bushing
SPF2292BK Front Sway Bar Link Bushing Kit
SPF1451K Front Sway Bar Mount Bushing
You can probably get the sway bar endlink kit from Energy and save you international waiting time and shipping. Other than that, just get the kit.
Strangely enough, I dont see any for the CG Lancer (02-03).
__________________
Daily driver: 4G69 powered Ralliart Lancer
Fun car: 4G63 powered 5th Gen Mirage
Offline
Old Mar 30, 2009, 07:31 PM   #4
KillahB's Avatar
__________________
Offline
Old Mar 30, 2009, 09:39 PM   #5
Thanks for the help!
This is for the CH-body style Lancer.
Do these part numbers apply to a 2005 OZ Rally (4g94)? Not sure if I have the "CH-Body style Lancer" you stated?
Thanks again.
Offline
Old Mar 30, 2009, 09:48 PM   #6
I checked energysuspensionparts.com for swaybar end links.
TO FIT/SELECT THE PROPER SET-
Length of 'A' Part Number
1" 98122
1-5/8" 98120
2" 98123
2-3/8" 98125
2-5/8" 98117
2-7/8" 98118
3-3/8" 98119
3-9/16" 98124
4-1/4" 98149
4-1/2" 98121
Any idea what size guys?
Offline
Old Mar 30, 2009, 10:05 PM   #7
KillahB's Avatar
Thanks again.
I'm sorry to confuse. I'll edit the original post.
CH style is the 05-08 style, so those are good for you.
CG body style is the 02-03.
__________________
Offline
Old Mar 30, 2009, 10:24 PM   #8
KillahB's Avatar
1" 98122
1-5/8" 98120
2" 98123
2-3/8" 98125
2-5/8" 98117
2-7/8" 98118
3-3/8" 98119
3-9/16" 98124
4-1/4" 98149
4-1/2" 98121
Can you take your tyre off and take approximate measurements? It'll probably help the rest of this community as well if you can get those measurements. I know the 9.8105 was the replacement for the Mirage bushings and the entire kit was the 9.8120 ... unknown if this will work for the Lancer though. May be worth a shot to try. The bushings cost about 10 bucks.
__________________
Offline
Old Mar 31, 2009, 09:07 AM   #9
Drives: 2004 ES
Yes 91820 is the correct one (comes with the thru-bolt, washers, and bushings).
Offline
Old Mar 31, 2009, 11:35 AM   #10
Personal Sales Rating: (2)
Lucas03ES's Avatar
Drives: 2003 Rio Red Lancer ES
Send a message via AIM to Lucas03ES Send a message via MSN to Lucas03ES Send a message via Yahoo to Lucas03ES
When we are on the topic of control arms, are there any companies who make aftermarket sets?
Offline
Old Apr 2, 2009, 04:43 PM   #11
jwick76's Avatar
Drives: 2003 Black and Carbon Fiber O-Z Rally
Not for the stock lancers (ES/OZ/LS), all you can find are just slightly better-than-stock replacements. Best bang for the buck is Rockauto.com.
People have been toying around with trying out the eurethane bushings for the EVOs out on the base lancers to see if they'll work, but no one's done it yet...
__________________
N/A 4G94
NGK Iridium IX Plugs
Magnacore 8.5mm Wires
OBX header
SR*S Modified Catback
Rear Strutbar (RoadRace)
Lower Tiebar (RoadRace)
http://www.myspace.com/xtragicxcomicx
Offline
Old Apr 4, 2009, 09:20 AM   #12
I came across this; has anyone else got experience of them?
http://www.hardrace.com/products.asp...2&strClass3=29
Country code 886 is Taiwan.
Offline
Tags
spf3113k
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
