Mar 25, 2009, 04:40 PM
Personal Sales Rating: ( 0)
Drives: 03 Lancer ES
Installing Springs
Hey there,
I am in the process of installing springs and all is going well, but when I go and try to loosen the top nut to release the upper assembly everything just spins in place. Getting nowhere.
There is no tension in the spring but I dont know of a way to prevent it from spinning.
Thanks in advance
Offline
Mar 25, 2009, 07:21 PM
Personal Sales Rating: ( 8)
2003 Mitsubishi Lancer Evolution
Drives: EVO IX
I know this isn't an Evo strut but you may have to hold the center (allen wrench in this case) and turn the nut or use an impact wrench.
Offline
Mar 25, 2009, 11:58 PM
Yeah it seems like there is a spot to grab the top part with a wrench but that would make it impossible to get a ratchet or spanner in there. Kinda wish they were as easy as the evo struts haha.
Offline
Mar 26, 2009, 12:32 AM
Personal Sales Rating: ( 5)
Drives: 2004 lancer
1.ok this is what i did. if im not mistaken you use an deep 14mm for the top of the strut, while someone else pinchs the center of the strut (the shiny silver part). you may want to use somthing in between the plyers and the strut so you don't scratchit up. I used a peice of cloth. now your partner is going to clamp down really hard (on the strut itself) if he's (or she, trying not to piss anyone off LOL) not using an impact wrench while you unscrew the bolt up top, it took me a couple of tries. Now as you get to the top, you should find somthing to fold over the top of the strut, leaving a little space so that you continue unscrewing until you fell it pop, remember to point it in an area where it's least likely to hit somthing or someone.
2. You also can just go down to a cool shop and have them loosen it up for you with an air tool, then hand tighten it back just a little bit, so you can get back to your work spot safely.
I know your wondering why i told you both ways, because the shop i went to wanted to charge me 20bucks to loosen some bolts! so i let them do the front at the shop and i did the back at home. So just in case they charge you, i told you the free way. hopefully they will loosen it and then tighten it for you when your done. remember to cover the spring before you fully unscrew it off. i hope this was of some use.
Offline
Mar 26, 2009, 06:46 AM
Personal Sales Rating: ( 7)
Drives: Yellow OZ
Sorry for french fellas
Si tu fais la job avec un impact sa devrait sortir tout seul. T'utilise un spring compressor pour enlever la tension du spring?
Tu pourrait essayer d'huiler le tarot et laisser un peu de temp à l'huile pour bien pénétrer les thread de la vis. Ensuite sa devrait sortir. Ou tu peux aussi chauffer le boulon avec une torche. Ton boulon est juste saisie en ce moment... Si t'es dans la région de l'outaouais laisse le moi savoir. Je vais te le faire à l'impact.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Mar 26, 2009, 06:50 AM
Drives: Yellow OZ
Quote:
Use a spring compressor or leave it to professionals. End of story. You should not be posting stuff like that. Taking struts apart without a spring compressor can be very dangerous, harmful and yada yada yada. If you don't have the tools to work safely, don't do it. There are some places that will rent/loan a vast array of tools.
__________________
Offline
Mar 27, 2009, 07:19 AM
Drives: 06 Lancer OZ Rally
Your major parts departments have spring compressor, they are not like the professioal mechanics tools but they work! Be safe! done shoot your friends.
Offline
Mar 27, 2009, 10:51 AM
Drives: Yellow OZ
Quote:
Agreed, but it's safer than going like...: "humm... lets aim it in that direction and pray to god nobody walks by, or lets pray to god the spring doesn't bounce back, or lets pray to god I take my hand/wrench of the nut fast enough"
In my area, the spring compressors are like this:
It's easy to use, and it's FREE!!!
__________________
Offline
Mar 27, 2009, 10:53 AM
Personal Sales Rating: ( 11)
2002 Mitsubishi Lancer
Drives: Lancer
Spring compressors are for *****s
I've never used one and I've lowered about 8 cars .
Just hold your foot on it and loosen it up , should only pop about 2 inch's !
Offline
Mar 27, 2009, 10:56 AM
Drives: Yellow OZ
Until you do it wrong and get it right in the face.
When it happens, come back and share your story. I want to be the first to laugh back at you.
Spring compressors are usually lent for free. Use them.
__________________
Offline
Mar 27, 2009, 11:03 AM
Drives: Lancer
Ha !
I've lowered so many cars let alone build a couple honda motors .
You think i don't know how to do it ?
I don't care if they gave me money to use them i still wouldn't do it .
My statement again , only pussy's use them
Offline
Mar 27, 2009, 11:10 AM
Drives: Yellow OZ
Ha !
Congrats, I'll get a shirt that says "02-Lancer-Es is my hero"
Reminds me of a guy who used to weld without a maks.
Only pussies use a mask... Guess what... He can barely see now.
My statement? Only retards don't.
So now that know we don't agree. Let's give Provost the help he came here for.
__________________
Offline
Mar 27, 2009, 04:53 PM
Thanks for the help gents, I got the front struts taken apart. They were a pain in the arse but they finally came apart.
I ended up using a product to help with the rust and then pinching the middle with a pair of vice grips and rubber.
Tomorrow I will put the front back together and get crackin on the back. Hopefully the nuts will be easier to take off.
Blaze thanks for the offer, I actually am in Aylmer so its not far from Ottawa. I will keep your offer in mind if my back ones give me problems.
Offline
Mar 29, 2009, 04:02 PM
Drives: 2004 lancer
I agree with 02-lancer-es the compresser is only nessesary for when your putting back the stock spring on the vechicle. otherwise the bolt wont even shot more than a foot. i've done many cars this way, i told him to point it in a safe direction because safety comes first.
Offline
Mar 30, 2009, 03:32 PM
Personal Sales Rating: ( 2)
Drives: 2002 lancer oz rally
wanna chance it?  oods are against you without at least spring compressor.
http://www.youtube.com/watch?v=CYFOI...eature=related
i've seen one go through a car's hood and one through a wall in a garage....trust me some have alot of tension even when assebly laying on the ground.
__________________
[x] RRM PULLEY & SS Piggyback v.2
[X] K&N FIPK SRI
[X] Magnaflow CAT
[X] Custom Dynomax Catback
[X] Progress Springs & Rear Anti Sway Bar
[X] KYB GR2 Struts And Shocks
[X] Light-Glow L.E.D. Color Change Underbody
[X] Premium Video/Audio/NAV
[X] Blacked Windows...due to medical condition :P
[X] Hello Kitty Exhaust Tip..Hello Kitty Everywhere!
[ ] RRM Stage 1 Turbo Kit W/ Intercooler
[ ] Magniflow/Greedy Catback
[ ] EVO Style Hood
[ ] Projector Head Light, OE Fog, H.I.D. Dual
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
