Mar 3, 2009, 07:57 PM
Personal Sales Rating: ( 1)
Drives: 2003 Mitsubishi Lancer
215-50-16
soooo i am about to get tires for my new 16x7 rims and i was planning on getting 205-50-16 tires but i like to look of wide tires (at least i think) so i was ondering if the 215 width would rub??? the rims are also +38 offset which i know would factor in
if anyone had pic that would be greatttt
__________________
plans:
[x]evo VII grill
[x]evo VII style tails
[x]16x7 bronze te37 replicas
[x]cedia headlightss
[x]speed element VG
[x]OZ lip kit
[x]amber side markers
[]megan, tien or ksports coilover
[]rexpeed type-c spoiler
[]tints (not sure how dark)
[]new fb rmr type 1 lip or kaminari?
[] paint job?
[]greddy exhaust
[]rmr sri
Offline
Mar 3, 2009, 08:18 PM
Personal Sales Rating: ( 2)
Drives: 2003 Rio Red Lancer ES
I would use a size 215/45-16 tire if I was heartset on using 215 series tires, because they are only 0.6% larger than stock.
If you wanted to consider a set of 205/45-16 they are WAY more readily available, and cheaper, and they are also only 0.9% smaller than stock tires.
To answer your question, no, I do not think they would rub.
Edit: 215/50-16 tires are 4.2% larger than stock
Offline
Mar 4, 2009, 02:14 PM
Personal Sales Rating: ( 18)
Drives: 2006 Audi A4 Quattro 2007 Mazda CX-9
Right on the fence as far as rubbing or not. If you want a shorter tire look at the 205/45's mentioned above.
__________________
Neal, Sales Representative
1-877-522-8473 ext 624
www.tirerack.com
Offline
Mar 4, 2009, 05:01 PM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
it'll look nice if you are lowered and have the stock ground effects.
otherwise it'll look funny
Offline
Mar 4, 2009, 11:03 PM
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
215 should work, 225 might be pushing it. If you don't lower it, it might work.
Offline
Mar 5, 2009, 03:07 PM
hmmmm thanks for everyones imput i appreciate the help
__________________
plans:
[x]evo VII grill
[x]speed element VG
[x]OZ lip kit
[] paint job?
[]greddy exhaust
[]rmr sri
Offline
Tags
16, 2055016, 215, 2155016, 50, 5016, cheap, evom, inch, lancer, pics, rim, tire, tires, wide  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
