Mar 3, 2009, 12:14 PM
Personal Sales Rating: ( 11)
2002 Mitsubishi Lancer
Drives: 02 OZ Rally
tires: 205 or 215
I've got some new 17x7.5 Rotas that I'm putting on my car soon as it warms up. A lot of people recommend 215 size tires for 7.5 inch wide rims but I like the stretched look of 205. I wanna run 205/45 17 size tires on these rims. Just wanna make sure nobody thinks that would be a problem
Also, I figured with tires a bit less wide, I'd have less to worry about in terms of rubbing
Any input? Thanks in advance guys
Offline
Mar 3, 2009, 12:30 PM
Personal Sales Rating: ( 7)
2007 Subaru Impreza
Drives: Robut bear cavalry to the bearpocalypse
215s will be a bit of a stretch.
Offline
Mar 3, 2009, 01:03 PM
Drives: 02 OZ Rally
I ran 215s on a set of 7 inch wide wheels and the sidewall was straight up, didn't look too good imo. Will the extra half inch make a noticeable difference?
Offline
Mar 3, 2009, 01:11 PM
2007 Subaru Impreza
Depends on the tire but it should.
Offline
Mar 3, 2009, 01:40 PM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
I feel like 205s are stretched on my 17x7 rims now...
Offline
Mar 3, 2009, 06:29 PM
Personal Sales Rating: ( 0)
Drives: 2002 Turbo Lancer 19lbs of Boost
i ran 215/45R17 and they rubbed when i lowered my car i like the 215's but they have to be a 40 series so they dont rub.
Offline
Mar 3, 2009, 06:43 PM
Personal Sales Rating: ( 1)
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
Read this article, Lancerman's Wheel Offset Guide
I think he ran 205/45 on them. As long as you have the proper offset, you should be able to run 215/40 ot 45 if its not lowered or still at stock height. I wanted to try 225 on mine, but doubt it will work. I'm going with 215 myself and I have seen them, but you do need the right offset.
Offline
Mar 4, 2009, 02:30 AM
Drives: 02 OZ Rally
Well my car is lowered, do I have much of a chance of fitting 215's in there? When I tried the wheel on the offset worked pretty damn well with a 5mm spacer: the outside was flush with the fender and the inside was a finger or so away from the suspension... but as well as it sits I'd hate nothing more than to rub. I sold my old 7" wide wheels with 215/45's to someone and he rubbed with his stock suspension
Still haven't decided, any more input is greatly appreciated
edit: and I'm set on 45 sidewall because I'm afraid to drive on the roads here with anything smaller
Offline
Mar 4, 2009, 11:04 PM
What offset where you old rims and what car did your friend put them on?
did you try your old 215 tires?
Offline
Mar 5, 2009, 12:51 AM
Personal Sales Rating: ( 13)
Drives: 03 16g lancer es
i bought his old rims and they would rub the inside of the inner wall everytime i would turn the wheel all the way to make a u both right and left and i have a 03 es and i belive it was 215/45/17
Offline
Mar 5, 2009, 01:18 AM
This is the area on both sides that would rub
Offline
Mar 5, 2009, 02:18 AM
Drives: 02 OZ Rally
Juan, I think the rims I sold to Link were a 38 offset. These rims I just bought are a 45mm offset plus a 5mm spacer which brings it to about 40.
Offline
Mar 5, 2009, 09:07 AM
215 work awesome i have them. i had the right offset but couldnt run that tall of a tire so i had to go down to a 215/40R17 doesnt even come close to rubbing anymore.
Offline
Tags
17, 205, 20545, 215, 21545, 45, 75, inch, lancer, rim, stretch, tire, tires, wheel, wide  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
