Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 24, 2007, 09:51 PM   #1
Personal Sales Rating: (3)
lancerman360's Avatar
Drives: RX-7 convertible, 92 Accord...... R.I.P. Lancer
Send a message via AIM to lancerman360
Lancerman's Wheel Offset Guide
Ok here is everything I have learned about wheel offset on 02-03 lancers. If I have made a mistake please be kind enough to p.m. me and I will fix any errors. Again this is what I have learned, take it as you will.
First: Wheel Offset basics
I got this from Tire Rack, here is a picture Tire Rack
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive<----what we have
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
Second: Stock Lancer Offset
I am not sure the offset of the wheels on an ES lancer but I know that the OZ wheels have an offset of +46. I just went and looked so dont call me a liar. If you have noticed the oz wheels are sunk in a little and leave a lot of room between the tire and wheel well. Even on a dropped car you can clearly see that a wider wheel can easily fit in there.
Third: Wheel Width and Diameter
I believe the biggest wheel size you should ever need or want to go would be 18x7.5 or a 17x7.5. Dont go any wider. If you go with a wheel thats 7.5 in width you have to make sure the offset is correct or one of two things will happen:
1. The wheel will not stick out far enough and tuck in so much that it hits the strut guard in the rear.
^No good, tire will rub.
Or,
2. The wheel will stick out too far and hit the fenders while driving. The same rules apply to wheels any other width, but with a 7.5 you have to be careful.
^sticks out too far
Fourth: What Fits?
For those with 18x7.5 or 17x7.5
A wheel with the offset of +44 will scrape the inside rear metal strut guard and will probably not even turn. An offset of +42 comes very close. I have an old wheel with this offset and it fits but there is no tire on it, so I am not sure how close it is with a tire.
My wheels (18x7.5) have an offset of +38. With 5 mm spacers they still do not scrape and I am dropped on Tein S techs. So I do believe that with the right sized tire you could fit an 18 inch wheel with a +35 offset. Anything between +42 and +38 will fit, but I think +40 is a very common wheel size and thats what I would reccomend.
Here is a pic of my wheels with no spacer and one with the spacer.
^not much room for error
For those with 17x7 - 16x7 - 15x7
Since its possible (with a smaller width) you could get a higher offest than a 7.5 width wheel. This means you could have wheels closer to stock that tucked in a lot. There is no advantage for doing this and since most afretmarket wheels stick out more than stock all you have to worry about is how far the wheel sticks out from the hub (no deep dish chrome wheels). The max I would ever go is +38.
Lastly: Spacers
If your wheels tuck in too much you can get spacers like the ones pictured below. They are cheap ebay spacers that are not hub centric but they do the job. I bought 5mm spacers for my Racing Harts that have the wrong offset. I would not go any wider than 5mm but thats just me.
Since I tried these on my current wheels and they didnt scrape I left them on. So now my rear wheels stick out 5mm more than the front. I only had 2 spacers. These wheels had a +38 offset before the spacers.
If you have any questions or more info let me know. Once again this is just what I have learned, so this may not be 100% correct.
__________________
Quote:
Originally Posted by CaliMR View Post
They found a lost book, the book of Raptor Jesus. The dinosaurs spent so much time on the internet that they did not even notice the comet approaching the earth until too late, and Raptor Jesus sacrificed himself to protect the dinosaurs from the comet. Then he arose on Easter and guided all the faithful dinosaurs to the moon which is where they live now. All those that did not believe were left on earth and died when Moses caused the floods.
Offline
Old Jan 25, 2007, 01:18 PM   #2
Personal Sales Rating: (10)
SLVROZ_03's Avatar
Drives: '03 OZ Rally
JDM, made in China... LOL! Good write up. Sticky me!
__________________
Mission accomplished! Got the garage, and now it's time to play!!!
Offline
Old Jan 25, 2007, 01:21 PM   #3
Former Vendor
Personal Sales Rating: (27)
2008 Volkswagen GTI
crypto's Avatar
Drives: GTI MkV
Send a message via AIM to crypto Send a message via MSN to crypto Send a message via Yahoo to crypto
nice write up. i may put spacers on my front wheels. From what i've read that will improve handling, plus it should look pretty nice
__________________
THIS SPACE FOR RENT
Offline
Old Jan 25, 2007, 01:24 PM   #4
Personal Sales Rating: (12)
Skylineracer's Avatar
Location: Port Orange, FL Lived: Daytona Beach, FL Lived: Clifton, NJ
Drives: Evo IX SE Tarmac Black Drove: Thunder Grey Lancer ES Flies: C172sp Nav III
Send a message via AIM to Skylineracer
nice write up
never knew u left the OT area
__________________
2006 TB IX SE
Mod List:
1-Up Air Freshener
Agency Power SS Clutch Line
AMS Front Motor Mount \\ Cam Gear Mount
Buschur Inline Boost Controller \\ 3" Cat-Back Exhaust \\ 5-Speed Shifter Bushings
DBA 4000 series rotors
EBAY Test pipe
Energy Suspension Shifter Tower Bushings
AMSOil Cone Filter
Megan Racing DP
Prosport Gauges
Racing Brake ET500's
Rexpeed VG \\ Gurney Flap
Synapse Synchronic BOV
JestrTuned
Offline
Old Jan 25, 2007, 01:58 PM   #5
Quote:
Originally Posted by Skylineracer View Post
nice write up
Every once in a while. lol.
Yeah I like the way it looks a little wider. Others may not be able to notice but I can.
__________________
Offline
Old Jul 28, 2007, 10:47 PM   #6
Bump, for tha newbies
__________________
Offline
Old Jul 28, 2007, 11:28 PM   #7
Personal Sales Rating: (1)
coal's Avatar
Drives: Lancer ES
Good info.
__________________
Amsoil 0W-30
Amsoil EAO13 Oil Filter
RRM SRI
RRM Slotted Rotors
RRM Header
RRM check engine light eliminator
Cat back exhaust by Portland muffler
RDD front strut bar PC black
RDD rear strut bar PC black
RDD trunk bar PC black
RDD rear tie bar
Ported intake manifold
Magnacore plug wires
Offline
Old Jul 30, 2007, 05:55 PM   #8
EvoM Moderator
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
This thread FTW.
STICKIED!
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Old Jul 30, 2007, 09:17 PM   #9
YES!! haha thats awesome. Now that I read it again, I know it needs to be worded a little different on some parts.
__________________
Offline
Old Oct 3, 2007, 06:33 PM   #10
Personal Sales Rating: (0)
sP33Dy's Avatar
Drives: 06 ES LANCER SPORTSWAGON
Great info
__________________
Sp33dY - Since 1997 -
http://www.sp33dy.com/lancer/
Offline
Old Dec 12, 2007, 12:22 PM   #11
Ok so I bought 2 more 5mm spacers the other day and put them on the back with the other ones. Now my rear wheels (18x7.5) are spaced out 10mm on the rear and none in the front. I kept them on the back that way I dont bend my front fenders if I hit a bump while turning.
It gives it a barley noticable staggered look, and since I cut the inner fender lip in the rear I do NOT scrape but it comes super close to the fender. Now I can go lower!!!
I just took this pic on my cell phone, sorry its so small but thats all I got right now.
Just a little FYI..... My wheels: 18x7.5 --- 215/35/18 tire --- +38 offset, the rear is spaced out 10mm more on each side
__________________
Offline
Old Feb 19, 2008, 10:44 AM   #12
BerIce17's Avatar
Drives: 2002 OZ Rally Lancer
Wheel and Tire Offset
Ok i read the sticky on this subject but im still a little confused...it said with a 17x7 to not go any bigger than a +38 offset right? correct me if im wrong..thats how i understood it....just wondering if i get a 17x7 with a + 42 offset..if it will rub or anything like that...with this will be 215/40R17 tires..Thanks for the help
__________________
2002 OZ Rally Lancer (TOTALED)
Sound System
SRS N1 Cat Back Exhaust
B&M Short Throw
Rims and Tires (17 inch Enkei Evo6 Anthricite w/ Toyo Proxes 4 215/40/17)
Cardomain
NEW
2004 Acura Nighthawk Black Pearl RSX
Lowered
Sound System
Offline
Old Feb 21, 2008, 07:37 PM   #13
Quote:
42 offset should be ideal. You shouldnt have to worry about rubbing at all.
__________________
Offline
Old Feb 24, 2008, 12:23 AM   #14
SlvrOz117's Avatar
Drives: MkV GTI
Send a message via AIM to SlvrOz117
im looking at 16X7 rims with a +45 will this rub or anthing? even after i lower?
lets say those dont fit.. which range of offset on a 16X7 rim would work?
thankss
Offline
Old Mar 5, 2008, 01:54 PM   #15
cmhfender's Avatar
Drives: 02 Lancer ES
awesome thread, very helpful! but i have a 02 ES how different is offset? im wanting to get 18x7.5 215/35/18 wheels and tires should i go with +35 or +42 because it's an ES?
Offline
Tags
2002, 749s, bigger, cat, correct, eliminator, es, guide, lancer, mitsubishi, offset, positive, rim, spacer, stock, wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
