Mar 23, 2008, 04:25 PM
Personal Sales Rating: ( 11)
2009 Mitsubishi Lancer
Drives: 2002 Lancer ES (Totaled); 2009 Lancer GTS
im looking to get 17X7.5 +40 will i need a spacer? also any ideas on a good tire size?
Offline
Mar 27, 2008, 10:58 PM
Personal Sales Rating: ( 3)
Drives: RX-7 convertible, 92 Accord...... R.I.P. Lancer
Quote:
you will not need a spacer.
__________________
Quote:
Originally Posted by CaliMR
They found a lost book, the book of Raptor Jesus. The dinosaurs spent so much time on the internet that they did not even notice the comet approaching the earth until too late, and Raptor Jesus sacrificed himself to protect the dinosaurs from the comet. Then he arose on Easter and guided all the faithful dinosaurs to the moon which is where they live now. All those that did not believe were left on earth and died when Moses caused the floods.
Offline
Apr 4, 2008, 11:17 PM
Personal Sales Rating: ( 0)
Drives: 02 Lancer ES
you have any advice about what the offset should be
as far as putting 18x7.5's on an ES?
Offline
May 13, 2008, 11:08 PM
Drives: 2003 Black and Carbon Fiber O-Z Rally
so as far as tire width, what's the widest you would be able to fit with a 17x7, +42 offset? would 225/55/17 work? I basically don't want to sacrifice ride comfort too much, and have heard the 40/45s give you a good jump when you hit road lovelies, which we have everywhere in the north
__________________
N/A 4G94
NGK Iridium IX Plugs
Magnacore 8.5mm Wires
OBX header
SR*S Modified Catback
Rear Strutbar (RoadRace)
Lower Tiebar (RoadRace)
http://www.myspace.com/xtragicxcomicx
Offline
Jun 21, 2008, 10:35 PM
Drives: 05 Mercedes Benz
so what is the lowest offest wheels we can run on the lancers??? i really like when there is like tire stickin out and such... not to the point where it looks stupid but nice you know....
Offline
Jul 6, 2008, 08:56 AM
Personal Sales Rating: ( 28)
Drives: 2003 US Lancer OZ Rally (5-speed)
jwick, remember that there is more than just offset to worry about when asking about rubbing. the tires you are looking at: 225/55/17 are FAR too large in diameter over stock and will probably rub at any offset. with that tire it is about 2.6" bigger in diameter than the stock tires, making about 10% difference on your speedo and causing other issues.
on a 17" rim you are much safer with 205/45/17 since they are very close to stock diameter. you lose a little width and some sidewall, but it's necessary to have it match oem specs.
Offline
Jul 6, 2008, 06:16 PM
Personal Sales Rating: ( 12)
Drives: corn fed turbo lancer
has anyone tried to run 225/40-17 on the lancer on a 7" wide rim with a 40-42 offset?
Offline
Jul 6, 2008, 07:28 PM
Personal Sales Rating: ( 24)
Drives: 2002 Labrador Black Pearl Lancer OZ Rally
the 225/40 will rub.
__________________
For Sale :
Stock Muffler, OZ springs
02' Lancer OZ Rally
If its made by :
- Tein - RRM - Energy Suspension -Brembo - Kamikaze - Greddy -AEM DC Sports - RRM - Injen
- North Star Creations - Rexpeed - Depo - Accolade - Motegi - Yokohama - Eclipse - Infinity
I probably have it
Offline
Jul 7, 2008, 02:54 PM
ah, so the 225 is just too wide for the wheel well/strut clearance on all four wheels..gotchya.
And to go the opposite end of the spectrum, has anyone found 13" rims and wheels that will work with the brake setup on the stock lancers? I was going to stick with the stock rims, but have two with some serious rash on them (NEVER let people drive your car, even to change parking spots). Tirerack doesn't sell any, and i've been looking around and only finding 4x100 bolt patterns. Anyone try these, and if so, what works? Just wanted to explore the lightweight/quick spooling options...
__________________
N/A 4G94
OBX header
Offline
Jul 14, 2008, 10:34 AM
i believe the front discs require a 14" minimum rim, assuming it has the right inside profile for caliper clearance. I thought it was 15" minimum but remembered that the es/ls came with the 14" rims so i guess 14" is minimum you could go for fitment with the brakes.
most brake upgrade kits require 17" rims for fitment. like the baer or brembo packages. so if you plan on upgrading the stock brakes, then be wary of small rims if you will get a big brake kit
Offline
Jul 14, 2008, 11:52 AM
^^just to confirm, my snow tires are on 14" rims. Yeah, I was wondering about the 13" clearing the calipers...all of the racing 13s I've found so far are 5-bolt pattern...I imagine some custom wheels could be made, but I'm not really that excited enough to pay for them:-p
__________________
N/A 4G94
OBX header
Offline
Jul 14, 2008, 11:54 AM
I take it back, just found some... HERE http://www.needhp.com/index.php?main...roducts_id=568
so this is odd, they give offset in inches...how does this convert to our positive offset?
__________________
N/A 4G94
OBX header
Offline
Aug 5, 2008, 07:58 PM
hey jwick this site might help you http://jeep-forums.4wd.com/showthread.php?t=13876 i saw the rims on the site you posted... some 15 rims would look nice in a low offset on the lancer... now what would the lowest offset we could fit on a 15 inch rim on a lancer prolly 7 or 8 inch width??/
Offline
Mar 26, 2009, 12:01 AM
Personal Sales Rating: ( 5)
Drives: 2004 lancer
good info!
Offline
Jun 11, 2009, 06:42 PM
Drives: 02 OZ Lancer
This was helpful. Thanks a bunch bro
Offline
Tags
2002, 749s, bigger, cat, correct, eliminator, es, guide, lancer, mitsubishi, offset, positive, rim, spacer, stock, wheel  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
