Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer (ES, LS, OZ) Tech Forums > Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 10, 2003, 09:24 AM   #1
Personal Sales Rating: (0)
project_lancer's Avatar
Drives: 95 accord exr v6 / 93 civic si
Suspension 101
taken from a webpage http://www.hondalive.net/lordaccord/lowering101.html
this information is suspension info in all vehicles, not just honda
maybe should be a sticky ?
--What are springs and struts? Why do springs effect my ride? Whats the difference between shocks and struts? Why stiffer?
Ok, first you have to understand the difference between the springs and the shocks and their stiffness. Its not the same thing. You dont want a stiff spring and a soft shock, but you can be just fine with a soft spring and a stiff shock.
the principal behind it is that as a spring gets smaller, the rate gets higher. The higher the springrate, the quicker and harsher the bouncing of the spring. However, the higher the springrate, the less the spring compresses where it usually would the most on stock springs. This is what causes bad rides and also what gives better performance as in less body roll. Frankly, thats what it gives you.
The principal behind shocks is that the shock compresses a certain amount (of course) as the spring does, but it really isnt absorbing the "shock" per say. No matter what shock you have, no matter how stiff or soft it is, whatever, its not doing the work, the spring is. The shock works to STOP the spring from the bouncing caused by its compression and decompression. However quick the shock reacts or rebounds will affect how much of it you feel and how much the car moves.
--Why shouldnt I put an aftermarket spring on stock shocks?
This is why you dont just throw any damned spring on the stock shocks - you all that want a technical answer - this is it. It takes power to stop a progressive rate spring. Your stock springs are not progressive. They are evenly spaced apart. This means when you hit a bump in the road, the entire spring can compress, there are no dead coils persay. It takes a lot less power to stop a non progressive spring. Think of it like you have a 1 foot long spring with evenly spaced coils, you hold it down, and let it go. Now you do that again with a 8 inch tall spring that has all the coils near the top all close together, even touching. THis means that you have a lot less spring pushing it. BUt principal physics says its going to decompress a hell of a lot quicker, thus faster.
Now, I am a supporter of Eibach, they have awesome quality springs. They are a world renound company. But despite whatever they say, over and over, and whatever your friends or people on this board say, you cant make a shorter, progressive rate spring to work with stock shocks. Its springrate may be at the limits, it may feel about like stock, but it aint. under your car your shocks are working the hardest they have in a while to carry that springload. Now, whatever the claims, however long your friends have had them, is absolutely fabulous, go for it. If they say they are for stockers, then they are. But I have seen prokits blow stock shocks as fast as race springs. It happens easily. However, they are the least likely to do it. So if you are gonna cheap out, cheap out the right way. (I wonder if I could get that published in an oxy moron book...)
--What has more effect on my ride and performance? Springs or Shocks? Both?
Now, addressing the question of which has more of an effect on the ride. Well, the spring. But the shock has an equal effect WHEN you have the spring. Heres how that works. You know how I talked about the spring absorbing the shock and compressing, and the shock matching it to stop the compression? Well, the same principal applies going into, say, a hard 75 degree turn at 75. What happens? Your spring compresses. You can certainly tell on stock springs, its less obvious with aftermarket springs though. But anyhow, in this instance, the quicker that shock can come out of compression and stop the springs compression, the more even your car will remain. Thus less body roll, and a still yet centered center of gravity. This equals control. Good control. Cant just the spring do this? Yes yes, of course, but even when you put that spring on stock shocks and head to the twisties, your car will still roll. Not as much, of course, but it will fluxuate. You lack evenness and clarity and preciseness. Your crux lies in how well that shock will respond.
--I heard that I can cut and melt my stock springs...is this a good way to save money and lower my car?
NO!! Since your stock springs arent highly pro rate, you will be cutting off your springrate as you go. You will have a very stiff, often uneven, harsh ride and you will blow your stock shocks. You also can never revert back and if you screw one thing up you are basically screwed alltogether. Its a money trap.
--What are the differences between different brands and genres of springs?
Well, generally springs, as they get lower, have a higher and higher springrate, which is how close together the spring coils are to each other - but a prorate spring gathers coils together towards the top and spreads out as they move down. The lower the springrate, the softer the spring, the higher the car sits. Eibach is the choice spring for many people as they claim compatibility with stock struts, which is not all that far off, however they are still a highly progressive spring, even though they have a relatively lower springrage, and really are still putting a lot of pressure on your struts, its just unrealized since the springs have a lower springrate at the bottom. Neuspeed springs and H&R springs are basically the "next step" up. They offer an allright ride, but they are a lot stiffer than eibach springs and a tad less progressive. They still progress down, except the coils are closer together. These offer higher performance. There are others, like Suspension Techniques, Intrax, Sprint, BBK, etc. Most of these springs are as high or high of a springrate as the Neuspeeds, but some of them are notorious for sagging or being to stiff. However, The designs can be nice and great for the right application, like using S/T sport springs which are a very small drop.
--Ok, enough technical jargon, what about the actual drop height of the springs...what are some different springs?
Here are some springs and their average drops (it varys from generation)
S/T Sport or Neuspeed Sofsport about a 1.0" drop, 3 finger gap Eibach Prokits are about a 1.4" drop, 2 finger gap Neuspeed / H&R Sports are about a 1.8" drop, 1 finger gap Eibach Sportlines are about a 2"+ drop, 0-1 finger gap Neuspeed / H&R Race are about a 2.25" drop, usually no gap, depends on strut
and the catagories for most sport and race springs from other companies (intrax, suspension tech, sprint are about the same drop as neuspeeds.
--Thats nice, but my parents dont want me to lower my car, is there anything I can do that they might be OK with?
Sure, you can go with a minor drop spring like S/T Sport or Eibach prokits. Im sure you will notice the stance of the springs but your parents may not unless they just stare at the car or they always have something to compare it to. Most of all you get rid of a lot of that ugly gap.
--I dont race, I just want people to see me and like my ride. What should I do?
The thing is, if you want the look and comfort and are not extremely concerned about performance, grab up the prokits or sportlines... they are just a softer spring to put it bluntly.
--Whats up with that guy? Why would you lower a car just for looks? I want the best performance baby.
In that case, I would say go with Neuspeed springs. There is a noticeable difference in the performance, but the ride suffers more. The best performance springs are the high springrate springs, but your comfort is compromised. If you are really into it, go for some Race series springs, but I mean if you are really into it.
--Ok, you mentioned struts earlier, but what do I need to do about them?
Well, on just about any car, if you replace your springs, your stock struts arent going to take it near as well, they cant stop the springs. First off, the springs are stiffer...no matter what. THe thing about eibachs is they still they arent uniform and they arent stock springs, and they will be stiffer. Eventually with any spring, especially the very stiff ones like Neuspeed, etc, you are going to blow out your struts...eventually. some people take weeks some months some can go a year but it doesnt matter - Ive seen people blow shocks with prokits just as fast as H&R Race, its still money you have to spend later if you dont do it now.
--Oh crap, what kind of struts are good?
Some good struts are Koni yellows (the "best" by some) which have adjustable dampers on them (awesome) to match the rebound with the spring you are using or the situation you are in. They also have movable perches, which arent why you should buy them, but if you had to be in a height adjusting need situation, then it might be a nice choice. There are also Neuspeed Konis, which have 5 perches and not just 3. These cost more, but are better geared towards someone who wants to move the perches when paired with Neuspeed springs... Before Konis, I had Bilstein HDs which are a non adjustable strut, they are my favorite and I say they are the best N/A strut, perfect for a budget street application, though the Koni Red had a bit stiffer ride. KYB is another good strut maker that you hear great things about, but their warranty is null and void past a certain drop, I beleive 1.5. Still, for a lesser drop that you want an adjustable strut on, the AGXs remain a definite best value. TOKICOs, well, I say they blow balls. I have grown to hate them the more I ride on them.. no offense to anyone with tokicos but they are best used in a low stress situation, IE with prokits that are on there solely for looks. However, If you choose tokicos for money, I would highly suggest getting the illuminas over the blues, so you can stiffen them up. There are a few other options like the Bec Tec ride height adjustable struts, but I personally have not learned enough about them or seen enough people with them for an extended period of time to draw a conclusion.
--How do you know that if you blown a strut or not? Do you feel any difference?
You will know when your struts blow. Your ride will be come very bouncy as your shocks no longer do their job. You will be very harsh over bumps... even with stock springs you will know. Its pretty bad. Basically what is happening is that your shocks no longer control how much the spring compresses, so when they are gone, your spring just keeps on boucning up and down until it stops. Thats it. All Im saying is that you should know.
--What do you think is the best combination overall?
Now, as for that, my Ideal functional look and good ride combonation is Neuspeed sport and Koni Yellow. You can get your cars ride excellent with Eibach springs, and you can really get your ride down close to the ground with Neuspeed Race and Koni Yellow. H&R springs would be my next choice, and Bilstein struts respectively.
--BUT I want to raise and lower my car, what should I do?
IF you think that you might be lowering and raising your car often, like car shows, etc, then something that might suit you better is a coilover setup.
Now moving on to coilovers- thats a different ballpark. You ask if a spring shock combo can match that performance and ride of coilovers.
--Whats a coilover...you mean those uppey downy thingys?
The definition of a coilover is a spring threaded on to an adjustable shock body. Thats it.
--Wait a second, I saw some "coilovers" that were just a spring looking thing, there wasnt a strut.
There are companies that make what are called coilover sleeves. Dont be confused. These are just the spring on an adjustable perch that sits on a strut ,like konis,...but the real coilovers are actually combined into all one unit.
--Oh, those coilover sleeves are a lot cheaper, why not just get those?
There are many complaints and problems with the coilover sleeves, Harsh ride, slipping threads, blown shocks, etc, but THey do serve a purpose and many people that dont care about the actual ride but want an adjustable perch for the looks will get them. I don't recommend them.
--What brand of coilover sleeves are the best?
Some popular ones are Skunk 2s, Weapon R, and Ground Control. Most others are generic and made from the same place and have different names on them. Its really up to you, but for the best ride and compatibility, the above listed is the better choice. Best performance being Skunks, best quality and ride being Ground control.
--Will I need struts with coilover sleeves?
Most definitely, these are some of the stiffest springs you are going to come by when lowering your car. If there is a time when you need struts, this is it. THis is also a good reason why many people go to a full coilover setup instead of sleeves and shocks, because the cost becomes almost equal and you can get so much more out of the full setup.
--Well, if I have that sleeve for 300 bucks and shocks for 300 bucks, why would I want TRUE coilovers?
True coilovers are the ****. Really. Since height is adjustable and sometimes the dampers are adjustable, and the spring and shock body are tuned very well to each other, these make for a very nice comfortable ride that performs much better than most strut / shock / coilover sleeve combos. However, you have to pay a price, usually a High one, for the all out compression/rebound/height adjustable coilovers. But when it comes to just height adjustable but well matched setups, like Apexi WS, the price you pay is only 100 or 200 more than what you would for coilover sleeves and shocks. Ask anyone with that kind of a setup, and they will tell you, as I do, its worth the money to go all out.
--What are some good Full coilovers?
This is a mod I will more than likely make in the future. Some popular ones are Tien, H&R, Koni, Neuspeed, Tanabe, and Apexi.
--You talk Coilovers up to be so good, so could a spring or coilover sleeve / shock combo match the performance or ride of a true coilover?
Well, theoretically, by what Im saying, yes. But there is a difference between the construction of a coilover and a spring and a shock. When you have a coilvoer that is tailored together, never to leave one peice, you gain a rigidness in design for the suspension movement. It changes. The ride is smoother because of how well matched the rebound is, but the performance is at its peak as well because of how matched the compression is. IF the shock doesnt have to work as hard to rebound, your performance increases soley with its ability. With say, sportlines and konis, your compression is set. You can match the rebound, but that may not be your peak performance. That may actually be with a stiffer rebound. Take for instance my konis and neuspeeds. My peak ride comfort is at a 180 degree turn. But if Im taking hard turns, I will set it at 360. What I lack is the fine tuning. Its matched, but not tuned. And then you have another issue to throw in. Height and damper adjustable coilovers... hehe. Now you are talking. Taking an already tuned pair and tuning it even more based on your height adjustment. Its a setup that costs money for good reason. It can be almost flawless. Almost perfect.
--So coilovers really are the best?
You are right in your thinking, coilovers are the ultimate in ride and performance, but they arent for everyone. If one is out to spend a little and get as much as possible, a spring shock combo has a LOT to offer. And i mean a LOT. If you arent going to be machine setting your stiffness to .002 with a springrate dialed to 250lbs to match with blabla blah blah... you know, not many will go this far...not racing far, not perfect suspension far. This is WHY I push that a spring shock combo will get the job done, as do most of the other suspension "experts" on the various boards around town....so you gotta think about it before you jump into it. UNderstand it. And you will figure out what is right for you.
--LETS REVIEW:
The suspension setups-
Cut springs-
Pros: dropped look
Cons: very bouncy and rough ride, blown shocks quickly, no height or damper adjust, uneven springrates
Just springs-
Pros: dropped look, good performance
Cons: rougher, bouncier ride, blown shocks quickly, no major height or damper adjustability
Springs and Shocks-
Pros: great ride, best performance, dropped look, no maintenence
Cons: sometimes bumpier ride in places, no major height adjustability
Just coilover sleeves-
Pros: adjustable dropped look, OK performance
Cons: thread slip, blown shocks quickly, very harsh ride, no damper adjustability
Coilover sleeves and Shocks-
Pros: adjustable dropped look, better performance, semi smooth ride
Cons: thread slip, no damper adjustability
True Coilovers-
Pros: adjustable dropped look, great performance, damper adjustability, springs threaded directly on shock
Cons: some w/o damper adjustability
Others (airbags and dubs)
Pros: instant adjustability, smooth ride
Cons: for show, performance lacks, constant maintenance
:-) hope this helps all the new people in the import scene
__________________
Project Lancer 2003
ETA : feb 2003
Offline
Old Jan 10, 2003, 10:02 AM   #2
camber ...
CAMBER
Most roads slope to the side to make the water drain or is banked on slightly on fast motorway a-road corners.
This is camber, the angle your wheel sits in relation to vertical when pointed ahead and you look straight at the car from front or rear.
Measured in degrees, most common road cars have 0 - .5 degree as standard. Some a little more.
Too much NEGATIVE camber will wear out tyres on the inside. POSITIVE wears out the outside.
If you look at really old cars they often have POSITIVE camber for some unexplained reason.
The correct amount varies depending on CASTOR, and how you drive your car. If you have little castor and you love driving fast through corners then you need more NEGATIVE camber,
If you do lots of motorway driving then less is better.
THE REASON? When you turn a corner the outside tyre tends to roll under the rim, causing it to wear on its outer edge. By laying it on its side you reduce this effect. Too much and it will wear on the inside, too little and it wears on the outside.
This is often used to stop wide tyres rubbing on wheel arches or suspension points, in this case a tyres life is not a primary focus
Too much negative camber and you will lose traction in straight ahead driving as the tyre is not flat on the road.
Camber in understeer and oversteer
As shown in below, if a wheel is not perpendicular to the road, then it is cambered. If it leans towards the center of the car, then it is negative cambered. (or " toe-in"). If it leans outwards to the car, it is positive cambered (or " toe-out", as shown in the following picture.)
When a wheel has positive camber, due to the elasticity of tyres, the wheel will be reshaped to something like the base of a cone. It will have a tendency to rotate about the peak of the cone, as shown in the picture. Now, you will see the wheel tries to steer away from the center of the car.
If both the right and left wheels are positive cambered (that means they lean towards opposite directions), the steering tendency will be cancelled so that the car remains running in straight line. If the car is turning into a corner, body roll puts more weight on the outside wheels than the inside wheels, that means the outside wheel's steering tendency will have more influence to the car. As the positive-cambered outside wheel tries to steer the car to the outside of the corner, the car will understeer.
On the contrary, if both wheels are negative cambered, the car will oversteer.
CASTOR
Castor is most often like everything else not adjustable on modern cars.
Camber stays the same if the pivot (vertically) of the cars suspension is zero.
EG if you turn the wheel about its axis it stays the same. BUT if the axis is at an angle (for or aft) then the more you steer the car, the more camber you get!
Its hard to relate, but if you imagine looking at the LHS of the cars wheel, with front to your left, if you grabbed the top of the axis and moved it back (to horizontal) with the wheel position staying still then this is castor, then imagine, if you turned the wheel to the right 90 degrees then the wheel will lay flat, this is obviously an extreme example.
The more castor the more the wheel will increase negative camber the more you turn the wheel. Too much castor and the car will want to wander as it has less tendency to want to point straight ahead.
__________________
Project Lancer 2003
ETA : feb 2003
Offline
Old Sep 14, 2006, 05:49 PM   #3
Drives: 06 Mitsu Lancer ES
Should be noted that Lancers (atleast 06's) DO NOT have front end Caster/Camber Adjustment, if it goes out, you bent something and need to take it to a frame/body place, the rear end however DOES have caster/camber adjustments.
Offline
Old Sep 14, 2006, 07:47 PM   #4
Former Vendor
Personal Sales Rating: (27)
2008 Volkswagen GTI
crypto's Avatar
Drives: GTI MkV
Send a message via AIM to crypto Send a message via MSN to crypto Send a message via Yahoo to crypto
^^ ha ha, thats what my passenger rear wheel looked like after i 180'd into a curb. Its still a little like that cos the drum is bent still. Its on my to do list.
Great info by the way!
__________________
THIS SPACE FOR RENT
Offline
Old Sep 14, 2006, 07:53 PM   #5
Personal Sales Rating: (11)
lancer2show's Avatar
Drives: 2005 Lancer ES/ 92 Talon TSI AWD
dang i should buy dubs than
__________________
LAST PIX OF MY 05 turbo lancer:
http://forums.evolutionm.net/lancer-show-shine/341242-my-last-pix-my-05-turbo-lancer.html
16G TURBO POWERED BY ROAD///RACE
Offline
Old Sep 14, 2006, 07:54 PM   #6
nice post btw!
__________________
http://forums.evolutionm.net/showthread.php?t=341242
Offline
Old Sep 14, 2006, 08:30 PM   #7
Personal Sales Rating: (1)
rhyzin's Avatar
Drives: '02 Mitsubishi Lancer OZ "Rally" Edition
Send a message via AIM to rhyzin
i'm not aware of any camber or caster adjustments in the front at all for any year. there is no caster adjustment in the back, only camber.
__________________
Dyno'd Lancers List
[ S C L C . n e t ] <- Southern California Lancer Club
Looking for stock parts? Look here first --\))> www.car-part.com
Basic Engine FAQ
Offline
Old Sep 14, 2006, 09:30 PM   #8
Quote:
I had my 06 on the rack today, it showed a caster adjustment
I dident LOOK for it as my rear was perfect, but the alignment machine pointed out a caster adjustment.
Offline
Old Sep 15, 2006, 07:16 AM   #9
EvoM Moderator
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
The alignment machine showing caster adjustment is different from the car having an adjustment point. You're not thinking about it the right way.
Just because the machine shows the stats doesn't mean the mechanic has a way to change them.
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Old Sep 15, 2006, 01:34 PM   #10
I know that, thats why I said it it showed, but I dident look visualy
Just stating the machine itself pointed out there was a Caster nut/eccentric on the drawn diagram of the rear end.
Kinda funny 8-)
Offline
Old Apr 4, 2007, 07:28 PM   #11
DickMorgan's Avatar
Drives: 2004 mitsubishi lancer oz rally(sold) 2008 black Lancer ES
wow this is a great thread.......i'm surprised i didn't run into it before
Now this is exactly the info i needed when i make my adjustments on forza or gran turismo
Offline
Old Apr 5, 2007, 11:32 AM   #12
EvoM Moderator
Quote:
This is why we sticky the good **** at the top. So it's easy to find...
__________________
Modern Warfare 2
Offline
Old Jul 16, 2007, 12:46 AM   #13
JohnnyBoy427's Avatar
Drives: 2003 Mitsubishi Lancer ES
Okay so I am a complete noob when it comes to suspension so here is my question. What exactly IS a strut? is it the shock or no?
__________________
Mitsubishi Motors for life. I bleed this s**t.
Cardomain
Quote:
Originally Posted by DSMorBUST View Post
:lol: there is something sexy about a new crate 4g63t i gotta say........ :rolleyes: its kinda like a virgin poontang waitin to have her cherry popped:eek: well minus the warranty:lol: :lol:
Quote:
Originally Posted by Bonestock! View Post
:lol: Now that had me spitting OJ all over my keyboard. Thanks ass-hat!:p
Offline
Old Jul 16, 2007, 11:49 AM   #14
Personal Sales Rating: (2)
Noe18's Avatar
Drives: 03 Lancer es ( BLK )
Send a message via Yahoo to Noe18
wat is the best springs and shocks for 03 lancer es, I wanted to buy the KYB from RRM and http://www.streetbeatcustoms.com/sps4390.html or http://www.mitsubishipartsstore.com/...ishi-lancer-es
Offline
Old Dec 27, 2007, 01:18 PM   #15
Exclamation
SOMEONE HELP!!!
i have a 2002 lancer oz and i just put 18 inch enkei or52's i was thinking about just getting tien s tech lowering springs but im worried they might rub..... and coil overs are to much money... anyone got any ideas??
Offline
Tags
coilovers, cons, evolutionm, koni, lancer, mkv, outkast1713, oz, pros, suspension, travel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
