Quote:
Originally Posted by sa town ridah
so is my current suspension , so im just going to go ahead and get it , its because i wanna lower it alot more , like a 3-4 inch drop from stock and im currently at a 1.8 inch drop all around with dropzone springs
3 to 4 inches. Have you check your clearences. It sounds like you will have a whole bunch of rubbing issues. Will you be able to turn your steering wheel to full lock without the wheels hitting anything? I think you will greatly comprimise the safety of your vehicle lowering it that much. The lowest I ever went on my coilover set up on my Lancer was about two inches. Even that low I had rubbing issues and I was using 15" wheels with a little bit wider tire. (205/55-15) I hope you think about what you are going to do before you move foward with this.
