View Poll Results: Which style Carbon Fiber Hood should I go with?
R1 EVO VS2 style
7 |
24.14% |
VIS Evo style
22 |
75.86% |
Feb 20, 2009, 04:58 PM
Personal Sales Rating: ( 1)
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
Juan Martinez Customs End All Build Thread
I figured it was time to start my build thread. I see everyone else with theirs and I feel left out. I have both an 03 Oz and an 04 ES. This thread will mostly focus on the 03.
Here we go.
The way she looked right after we got it.
She came with a different set of aftermarket taillights I didn't like, so I went evo style right after we got it
My cd player and in dash monitor, the monitor is gone now, and will be replaced with something else. The Sony cd player is about to go also.
I threw in my Kicker L7 and kicker 1000.1 amp that I've had since 2005. It has really held up to the abuse. The amp is probably a 2003 or 2004 model which I got used.
Here is my kicker component speakers.
Here is my cold air intake. There is also a ss clutch line install on there now.
These pics are from the fall and need to be updated. I also plan for my next update to show my plans.
Offline
Feb 20, 2009, 06:35 PM
Ok, here is the first wave of plans I have when tax time comes.
First. Pioneer DEH-P9800BT
Pioneer UB-100. I prefer to use my HDD and have all my music with me.
Plan on buying these also and using a 6000k HID kit
Here's what is replacing that indash monitor
And because it looks naked without gauges
The big plans down the road
Complete 5 lug, rear disk, and brembo brake conversion. I have figured out the rear, just need to figure out the front.
I am now taking suggestions on 5 lug rims 17x7.5 or maybe 17x8 with an offset (38+) that will fit over evo brembo calipers
Offline
Feb 20, 2009, 06:53 PM
Personal Sales Rating: ( 12)
Drives: a boostmobile
Looks good.
Are you buying all the pieces separately for the 5 lug conversion or are you buying a kit?
Offline
Feb 20, 2009, 07:25 PM
Quote:
Originally Posted by OZ Rally
Looks good.
I'm buying all the pieces seperately. I believe I can make it cheaper than buying any kit. If I'm right, which I hope, all I need are the backing plates, rotors, pads, calipers and brake lines. The ebrake in the drum might be transferable over to the new backing plate. I could redrill the rotors to 4 lug, which might do if funding doesn't go well.
Offline
Feb 20, 2009, 07:55 PM
I would suggest going with the Ralliart brake conversion.
Seems a lot easier and will be a lot cheaper.
Offline
Feb 20, 2009, 08:03 PM
Thats the plan. I found the backing plates on www.mitsubishiparts.com I figure less than 100 I can get them. I was thinking that an eclipse rear brake conversion might work. It looks just about the same and uses the same calipers and rotors.
Offline
Feb 20, 2009, 08:34 PM
Personal Sales Rating: ( 13)
Drives: RWD EVO & 09 Lancer GTS
Jon, can you confirm if the 2g eclipse rear 5 bolt hubs/spindles are the same as the 5 bolt ralliart ones?
Offline
Feb 20, 2009, 09:16 PM
Quote:
No, the spindles are not the same, nor is the hubs. Have to use ralliart ones, sorry, I didn't get around to the axle today. Too cold. Tomorrow is a go I hope.
Offline
Feb 20, 2009, 10:03 PM
right on.. just figured maybe you discorved something new with the eclipse rear hubs..
Dont know if this helps or if I told you already but I've confirmed the spines and outer diameter on the outer cup on the lancer are the same as on the 2g. In short 2g axles fit into lancer hub/spindles.
Offline
Feb 20, 2009, 10:50 PM
The rear 2g hubs are the same as rear of an evo from what I've found. Check out this link. http://repo.jackmoves.com/v/shawn/Ec...ss/?g2_page=10 This guy is putting an evo motor in his 2g. He had the axles redone to use his factory hubs. I don't know if this helps.
Offline
Feb 20, 2009, 11:32 PM
yea I saw that... he head the 2g axles machines for the evo inner cups.
Offline
Feb 21, 2009, 01:19 AM
Personal Sales Rating: ( 21)
Drives: 02 Lancer OZ 16G TURBO
I'm thinking about getting those same headlights... I just wish they didn't have the amber in them though...
Offline
Feb 21, 2009, 10:14 AM
Quote:
I think thats why I like them. They are most like evo headlights with that turn signal. I'm debating if I want to make the inside turn signal into a fog light type thing like on an evo.
Offline
Feb 25, 2009, 04:24 PM
Update: Here are some new pics of some older stuff I put on.
Short Shifter with evo ball type knob. very comfortable.
Evo Gauge cluster
Custom grounding wire kit. Still working on it. Haven't decided if I will use one of those circle things that go on top of the battery. I've had problems on those before. I did this to help the headlights not flicker so much with my sound system.
Offline
Feb 25, 2009, 05:05 PM
Personal Sales Rating: ( 0)
Drives: 2002 lancer
where do u get the evo gauge cluster and is it plug and play?
Offline
Tags
03, 2g, cardomain, cluster, conversion, cup, custom, customs, eclipse, evo, fiero, garage, gauge, install, juanmatinez, juans, kit, lancer, oz  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
