Nov 26, 2008, 03:18 PM
Personal Sales Rating: ( 5)
Drives: 05 Pearl White Ralliart AT
Does the Transponder in the Key really work?
So I have a question but hopefully the title of this thread really explains it. Anyway when it comes to getting keys for my 05 RA they say I have to get a special key from the dealership and I'm like okay that seems sensible. A few weeks later my brother goes to Home Depot and gets a copy of my key and I still figured it'd be okay cause there's no transponder in the key. About 5 minutes later I hear my car driving off and now I'm wondering if the transponder really does anything? Can anyone enlighten me on this?
__________________
Power: [x] RRM SRI [x] RRM UDP [x] RRM RA Timing Controlbox [x] RRM P/P Intake Manifold [x] RRM P/P Head [x] RRM Header/DP/HF Cat [x] Magnaflow Catback
Aesthetics: [x] Vortex Generator / Shorty Antenna [x] Angel Eye Projectors [x] 6000K Headlight HIDs [x] RRM Black Tails
Handling: [x] Megan Street Coilovers
Future Mods:
[ ] RRM Anti-Sway Bar
[ ] RRM Lower Tiebar
[ ] RRM Piggyback
[ ] RRM Stage 2 Cam
[ ] R1 Premium Rotors
Offline
Nov 27, 2008, 01:55 AM
Personal Sales Rating: ( 0)
2006 Mitsubishi Lancer
Drives: 2006 Mitsubishi Lancer Ralliart
yea u know, i got an 06 RA and I'm wondering the same thing. As far as I know, the car is not supposed to start unless the correct key is used with the car. But I donno..
Offline
Nov 29, 2008, 11:11 AM
Drives: 2005 Lancer ES
Certain models, especially the 04-06 Lancers and RA's, didn't come with a transponder. Most dealerships are lazy and don't want to try to figure out if it was one that did or didn't and will try to sell the more expensive key rather than admit mistake after they cut it and can't get it to code.
Offline
Nov 29, 2008, 01:02 PM
so basically my car doesnt have a transponder and im paying $80/key for nothing?
__________________
Future Mods:
[ ] RRM Piggyback
[ ] RRM Stage 2 Cam
Offline
Dec 1, 2008, 08:30 PM
Personal Sales Rating: ( 1)
My lancer does not have a transponer. Not sure if the transponder is in the key or the key cylinder. Maybe someone with a transponder can shed some light. I do know from experience installing remote starters that some vehicles have a transponder chip in the head of the key itself and other vehicles have the transponder in the key cylinder/barrel. When a valid key turns the ignition cylinder it reads a transponder on the cylinder side and allows it to start.
An easy way to check would be to try hot wiring your car... hehe... just kidding.
Offline
Dec 1, 2008, 08:45 PM
From what I know there is a transponder in the key and there is some receiver in the key cylinder that receives the signal to start the car with the appropriate key. But now I'm having my doubts about whether or not I have one in the car.
__________________
Future Mods:
[ ] RRM Piggyback
[ ] RRM Stage 2 Cam
Offline
Dec 9, 2008, 06:27 PM
Drives: 02 lancer oz rally
If you can go to home depot and get a metal key made that starts your vehicle there is no transponder/chip in the factory key. most lancers that i know of dont have transponders on the other hand some galants and diamantes do.
Offline
Dec 12, 2008, 03:16 PM
Drives: 2004 Lancer RalliaArt
Lancers ands Evo's are the only mitsu's that dont use electronic keys, so yes you have waisted 80$ on a "transponder key" witch doesnt exist for the RA and most lacers if not all. hope that helps
Offline
Dec 12, 2008, 03:38 PM
Personal Sales Rating: ( 9)
Drives: 03 BBY VIII
Evo's have the chips in them. The dealer had to replace my ECU at one point and when they did that they reprogrammed the key I had with me. The spare I had at home no longer works...the car will start up using the spare key but die within 3-4 seconds because the codes don't match.
__________________
Steve /// 03 BBY VIII /// FP green ported :: HKS 264i/272e :: AEM intake :: AVO 3.5" fmic :: Weapon-R uicp :: AMS licp :: RC 750cc :: Walbro :: RRE tbe & clutch/flywheel :: Espelir springs :: Tein front strut :: Progress rear sway :: SP slotted w/ Hawk HPS :: Evo 9 MR bov/BBS/tails :: Apexi EL II Boost/EGT :: Vortex Gen :: 15% /// tuned by C-Spec Tuning /// only 312whp 282tq on 91 (DynoPack)
For Sale/Trade:
AEM UEGO single controller $125
Apexi EL II fuel pressure gauge $100
Offline
Dec 13, 2008, 07:09 PM
^^^ i dont believe.
Offline
Dec 13, 2008, 07:13 PM
Drives: '08 Evo X 5sp, SMG M3, JDM IX RS
Quote:
It may not because the 2008+ has a valet key in the FOB with no chip
__________________
Quote:
I never said most of the things I said.
-Yogi Berra
Offline
Dec 21, 2008, 09:50 PM
Personal Sales Rating: ( 3)
Drives: 03 TB Evo
Quote:
Originally Posted by RalliDew
^^^ i dont believe.
Evo definitely has a transponder key, its programmed into the ecu to match.
Offline
Dec 28, 2008, 12:41 AM
Drives: 05 ww viii
Quote:
Yes, the key in the fob in your KOS (Keyless Operating System) is just a metal key with no transponder, but the key will not work by itself. The key fob must be attached to the end of the key while it's turning in the ignition cylinder in order for it to start the car. This metal key is there so you can start your car in case your FOB has lost its' program and the KOS is inoperative.
Offline
Dec 28, 2008, 12:46 AM
Drives: 05 ww viii
Quote:
Confirmed, Evo's definitely have an immobilizer and all useable keys must be programmed at the same time or the non-programmed one will not work.
Offline
Dec 28, 2008, 01:04 AM
Drives: 05 ww viii
Quote:
You can have your dealer program your spare key to work, so the key isn't a waste. Or if you have 2 keys that work already, you can program any extra keys by yourself. PM me if that's the case, and I can guide you through the method to do it.
Offline
Tags
03, auto, car, chip, cylinder, depot, factory, home, key, keys, lancer, program, transponder, work, works  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
