May 14, 2008, 09:23 AM
Personal Sales Rating: ( 0)
Drives: 04 Ralliart
back speakers
The entire back panel that houses those 6 3/4 speakers is completely metal. So what would be the difficulty rating of pulling that out and cutting some 6 by 9 holes in there to get better sound. I know most of you guys are going to say "just get subs" but im looking for a difficulty rating. thanks
Offline
May 14, 2008, 11:49 AM
Drives: 06 Lancer Ralliart
i made some fiberglass enclosures for my 6x9's so that they would fit cause i didn't want to hack everything apart too much....so the speakers are now slightly raised and tilted forward and it sure made a huge difference in the sound and it was definately for the the better......my enclosures are just a test model and i plan to refine my design a bit in an effort to take up less space and make them look cleaner
Offline
May 14, 2008, 06:46 PM
Drives: 06' Lancer Ralliart
Jessie, were you running those 6x9's off stock amp? I have a set kicking around but dont want to get another amp
Offline
May 15, 2008, 02:45 PM
yah they are just running off my kenwood flip but i plan on buying an amp yet
Offline
May 15, 2008, 07:11 PM
Drives: 2004 lancer ralliart
be careful putting in new speakers, if they are to big they are going to hit a cross metal bar that helps stabelize the trunk lid. u might hit them if the speaker gets to long.
Offline
May 17, 2008, 03:44 PM
Personal Sales Rating: ( 1)
If you're referring to the carpetted rear deck panel... removing that and cutting your holes wouldn't be that hard. I would say on a scale of 1 to 10 it would be a 5.
If you're referring to the metal rear deck underneath the carpetted rear deck panel, you can't remove it and cutting it wouldn't be too hard if you had the right tool. I would say on a scale of 1 to 10 it would be a 7.
Like "myfakeevo" said... make sure you're 6x9's mounting depth isn't too deep that it hits the trunk's crossbar springs. The trunk won't open or close or stay up properly if it hits the speaker.
If you find that the 6x9 will hit the crossbar... you can make a plate to mount up top to space it out, or fiberglass a new speaker pod so that you don't modify the rear deck.
Hope this helps,
Nick
Offline
Jun 18, 2008, 12:51 AM
Drives: 1993 Dodge Stealth ES, 2003 Chevy Trailblazer
I wouldn't do it......
what i would do is...if you don't want to go the sub route.....buy some good 6.5" speakers for the back and run them through a 4 channel amp. 6.5" will produce a cleaner sound than a 6x9
__________________
Past Cars
2005 Lancer ES
2006 Chevy Colorado
1981 Firebird
Current Cars
2003 Trailblazer
1993 Stealth ES
Offline
Jun 18, 2008, 01:01 AM
Personal Sales Rating: ( 13)
Drives: TurboEs
I agree, even you are not looking to go with a sub, buying some aftermarket 6.5" speakers and a small 4 channel amp will produce better sound then a 6 x 9 will.
__________________
"In The Eyes Of A Blind Man, You Can See Everything"
Online
Jun 18, 2008, 01:02 AM
Drives: TurboEs
__________________
Online
Jun 19, 2008, 03:45 AM
it doesn't have to be a very powerful amp.....about 50 rms through each channel will be plenty....i had some nice pioneer speakers and a sony amp and it sounded MUCH better than stock.....with the stock system you are missing out on quite a bit of the sound spectrum....the amp helps you gain some of it back.....
just curious....why would you want the 6x9s
__________________
Past Cars
2005 Lancer ES
2006 Chevy Colorado
1981 Firebird
Current Cars
2003 Trailblazer
1993 Stealth ES
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
