Feb 14, 2008, 11:17 AM
Personal Sales Rating: ( 1)
Drives: Diamond White '05 Ralliart
FM reception problem.
Ok guys as some of you know i bought an Alpine HU a couple of months ago. Since installation I have been having very bad radio reception. It did not bother me at first because i was listening to the iPod most of the time, but there is a new morning program in my fav station and i can't listen to it. To make things worse apparently my HID are causing more interference, making it impossible to listen to a radio station at nights. I am trying to solve the main problem with crutchfield, but would like to hear your thoughts, especially regarding the HID interference. thanxs to all
__________________
Mods:
Zaklee Engine Damper
Speed Source Brass Bushings (shifter base & underhood cables)
Borla custom axelback
Custom made 2.5" Exhaust with HF Cat
Injen CAI
Underdrive Pulley
Custom made Ground Kit
Best E.T. 16.00 @ 86 mph 100% Stock
Coming soon:
Track and dyno day!!!
Offline
Feb 18, 2008, 06:47 AM
ehhhh... anybody???? nobody with this problem ever????
__________________
Mods:
Injen CAI
Underdrive Pulley
Coming soon:
Offline
Feb 19, 2008, 05:03 PM
Personal Sales Rating: ( 34)
Drives: '00 Chevy Prizm
i'm having this problem too but its not that bad tho. i was told it may be the wiring but i double checked everything and it all looked good. if u find anything out, let me know.
Offline
Mar 16, 2008, 01:22 PM
Personal Sales Rating: ( 6)
I had an Alpine headuinit too and it had bad fm reception... I do not think there is much you can do about it, because the problem went away with other radios. So you know it is not the cars attenna nor wiring...
What you can do I suppose is by a different attenna and see how it works with your Alpine. Circuit City sells them for about 25 dollars, just stick it in, and hide it underneath your dash somewhere.
I did that for a costumer and was complaining about reception problems and that cleared it right up.
If it doesnt work, just ask if you can return the attenna..
__________________
"We didn't just build a car, We started a religion."
-Mitsubishi Motors
Totaled Evo Partout
Offline
Mar 16, 2008, 06:45 PM
Drives: 04 LB Ralliart
Double check your antenna connection. I had the same problem with weak/no radio reception when I installed my Kenwood HU. It's a tight fit for the cables in the back and they can shift as the HU is being pushed in.
Offline
Mar 16, 2008, 08:43 PM
Personal Sales Rating: ( 2)
Drives: '04 Lancer Ralliart, '82 Honda Nighthawk, '82 Suzuki GS1100, '81 Suzuki GS1100, '74 Volkswagen Bus
I have no FM reception problems with my Alpine HU.
Offline
Mar 16, 2008, 09:59 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Me neither (Alpine 9830), though I don't use FM all that much. Best I can think of is to make sure the antenna cable is in tight.
Offline
Mar 17, 2008, 10:52 PM
Personal Sales Rating: ( 0)
Drives: Ralliart 2006
The antenna had an powered amplifier according to Shopkey5.com!! On the OEM HU this is the yellow wire that feed power to the amplifier. I don't now the voltage needed to the amp but check out this and let me know!!
__________________
Car page
2006 Ralli\\Art Sun&Sound
Black Halo projector
6000K HID kit
Black Injen CAI
SS exhaust tip
2Way car alarm
Hella Optilux XB in foglight
Offline
Mar 19, 2008, 11:50 PM
I read something like that, about a power antenna on the cars with ROOF or rear glass mounted antennas.
If you fix this let me know, cause I have a Sony and I could have better reception, I had the same sony on my older cars (with simple telescopic antennas) and It had near perfect reception.
__________________
Yes, I know my English Sucks...
Offline
Mar 24, 2008, 11:54 PM
well, I try it, and yes the car has "power antenna" is the yellow cable, but I connect it to my sony HU and the signal doesnt improve at all, it stays the same, so, you people try it anyway...
__________________
Offline
Apr 8, 2008, 11:58 AM
When I have my car in hand I try to check the voltage output at the HU. If is a simple 12V just splice the wire from the ignition switch and maybe it will fine. But if you would try it now just remember to check the voltage at the back of the OEM HU!!!
__________________
Car page
6000K HID kit
Black Injen CAI
SS exhaust tip
2Way car alarm
Offline
Apr 8, 2008, 01:15 PM
Drives: 2004 Lancer RalliaArt
check that there is nothing metal touching the metal part on the back of the antenna wire this will cause problems for you.
Offline
Apr 11, 2008, 12:05 AM
I dont know if its because I connect the antenna, but now my sony HU say " FAILURE" on the screen, a lot of times
but it still works perfectly, it just say that...
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
