Jul 28, 2007, 08:33 PM
Personal Sales Rating: ( 1)
Drives: 05 lancer ralliart
overcharge on my system
yes my battery light an brake came on my 05 ralliart then when popping my hood i noticed the harness melted down an the red top battery was releasing fluid. im running a 1800 rms an 400rms mtx amp an 2 12" mtx 8500 700watt power inverter. i know the ra's are 110 amp alternator im sure upgrading that to 170amp alternator is a good start an upgrading to the yellow top just kindin getting some ideas on witch is the best set up for this system so this wont happen again
Offline
Jul 29, 2007, 09:41 AM
Personal Sales Rating: ( 29)
Drives: 2005 Mr. Evo Eight
Wow i'm not too familar with audio setups but i've never heard of that happening before...
So you're sayin' that your stereo setup melted your battery?
__________________
New to the Ralliart forum? Got some questions about your car and its compatibility? Check out the Noob Thread and you'll find a lot of your answer there!
Online
Jul 29, 2007, 12:16 PM
Personal Sales Rating: ( 10)
Drives: '03 OZ Rally
Not overcharging, definitely not...but was their any electrical issues that you've dealt with lately? Any electrical failures, faults, grounding issues, anything?
__________________
Mission accomplished! Got the garage, and now it's time to play!!!
Offline
Jul 29, 2007, 01:53 PM
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
I think you've got more serious problems than just overdrawing power, though I think it's laughable that you even thought you could pull that much power in the first place off a stock alternator. You're going to need to upgrade a lot of wiring, you can't expect to move that kind of power without beefing up all the wiring to your alternator and all your ground points.
Offline
Jul 29, 2007, 03:11 PM
^So true! More important than RMS though, what's the amperage draw from each amp? I had a 4-ch 6004 MTX and it drew 80 amps itself!!! and that's the 4-ch, not the sub amp.
__________________
Offline
Jul 29, 2007, 04:42 PM
Personal Sales Rating: ( 0)
Drives: 03' Mitsubishi Lancer OZ Rally
agreed with all above, first of all, double ground everything, second, upgrade all your power wire/ ground wire/ and all engine compartment wiring to 0awg...3rd...get a new alternator
__________________
FOR PEOPLE PARTING OUT THERE CAR!!!!!
i am looking for the folowing...
*R/L OEM Factory Replacment Door Panels (front)
*Headliner (any color)
Offline
Jul 29, 2007, 08:54 PM
Drives: '05 Lancer Ralliart
sounds like you have a lot of rewiring to do!
__________________
Mods:
Alpine sound system
compustar 2 way alarm/remote start
red calipers
debadged
17" BSA 363 rims, with Nexen N3000 tires
Injen CAI
RRM header/downpipe
Custom Exhaust with Apex'i WS II muffler
RRM UDP
Offline
Aug 1, 2007, 11:28 AM
found the problem
now what happen was that the harness plug the conected to th alt melted from heat causing a short in the system that forced the alt to over charge causing the battery to explode. replaced the harness an alt an battery every thing is in good order now
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
