Jun 29, 2007, 03:23 PM
Personal Sales Rating: ( 0)
Drives: Phoenix Red Lancer RA
Alternator Whine
So today i installed my speakers, and amp. I ran the power wire along the drivers side of the car and the remote and RCAs along the passenger side of the car. I had a solid ground point to the frame in the trunk. I can tell this is alternator whine, because when i rev the engine, it gets louder and goes with the engine. I have PG RsD component set and a temporary kicker zr240 (until my PG amp shows up). So why the hell is it doing this?!?
Any help would be appreciated!
Offline
Jun 30, 2007, 12:11 AM
Personal Sales Rating: ( 1)
double check the ground (specially) and power wires
check the connectors as well
i had the exact same problem and it was just not grounded properly
Offline
Jun 30, 2007, 03:35 PM
Personal Sales Rating: ( 9)
2004 Mitsubishi Lancer
Drives: 2004 N/A RALLIART , 2003 6MT G35 coupe
Did you use cheap RCA's or good ones....
__________________
RALLIART TURBO PARTS FOR SALE HERE
Offline
Jun 30, 2007, 04:48 PM
I used Phoenix Gold QX series rcas...and i grounded straight to the frame. I removed all the paint around the area. It's really weird, this is the first time I've ever experienced this
Offline
Jun 30, 2007, 04:56 PM
Personal Sales Rating: ( 12)
Drives: 06 GG MR, 08 Acura TL type-s, 03 CBR 954rr, 01 Celica GT
Try a different grounding spot. Just picking a different location to ground the amp could do away with the problem....also make the ground wire from the amp as short that you can.
Offline
Jun 30, 2007, 05:11 PM
It is only about 2 and a half feet. I will try a new spot though.
Offline
Jul 21, 2007, 11:45 PM
Personal Sales Rating: ( 8)
Drives: a boosted Ralliart ;)
I did mine to the trunk latch. Give that a shot...
__________________
RRM ralliart turbo self installed.
Dont hesitate to PM me with any questions an i will do my best to help ;)
Please read through the rules if you have any questions or doubts about your post.
http://forums.evolutionm.net/evom-an...uncements.html
Quote:
Originally Posted by HobieKopek
You'll be fine. You just may feel sore for a while. I bled for 3 days (not much, but enough to taste like I had a mouth full of pennis), but I also had Percoset (sp?) which meant I had a pretty good time.
Offline
Jul 23, 2007, 08:24 AM
Drives: your mom crazy with my striking good looks
the remote turn on is a power wire too, just an fyi. It carries a 12 volt signal, though I doubt it's causing your problem.
changing the ground again is good advice, you never know what route these signals take to the battery.
the quality/age of the amp can cause issues. there will always be noise in the system, the quality of the components determine how much noise there can be before it interferes with the signal. maybe your new amp will solve the problem.
the ground should be the same for the whole system also. hu, eq, amps, everything in the same spot. that's the "perfect" setup.
__________________
wtb 4g69 bottem end. pm me.
Offline
Jul 23, 2007, 08:27 AM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
+1 on the ground being at the same point for your whole system. I used one of the mounting bolts to the rear seat belts for my ground (after sanding off the paint) since it's the midpoint between the amp in my trunk and the one under the passenger seat.
Offline
Jul 27, 2007, 10:40 PM
Personal Sales Rating: ( 7)
Drives: 2003 Evo 8
try sanding down the location where you are putting your ground this might help...
__________________
03 TB EVO MODS:
Megan DP, Ultimate Racing 3" Hi-flow cat, Tsudo Cat-Back, MBC, HKS 264/272 cams, Walbro 255
Tuned by KevinD
Online
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
