Apr 2, 2007, 08:39 AM
Personal Sales Rating: ( 111)
Drives: 06 WW EVO IX w/ SSL
Lancer MAF = Mirage 5th Gen MAF
I just thought I'd throw this up here in case anyone runs into a similar problem I did. Last week my MAF dies (pin rusted off....) and in my search for a replacement MAF, I discovered that the 5th gen Mirage uses the same MAF as the Lancer. It's the same Mitsu part #. Hope that helps someone else out.
__________________
AMS 3" TBE w/ TP |GFB BOV | AMS UICP | Muse LICP | Walbro 255 Fuel Pump | Mini Battery | Amsoil air filter w/ Vibrant MAF adapter | Custom Boost Pill (#58) | Omni Power 4-Bar MAP Sensor | Powerslot Slotted Cryo Rotors | Swift Springs | MIL.SPEC TB Shaft Seals
325/310 WHP/TQ (VDR 5.7) - 24 PSI, 91 Pump - Self Tuned w/ECUFlash
Previous Lancers
- '09 Lancer GTS (traded 6/19/09)
- '03 Lancer OZ Rally (traded 1/18/09)
Offline
Apr 2, 2007, 08:53 AM
Former Vendor
Personal Sales Rating: ( 27)
2008 Volkswagen GTI
Drives: GTI MkV
Quote:
thats pretty cool. good detective work
__________________
THIS SPACE FOR RENT
Offline
Apr 2, 2007, 08:57 AM
Personal Sales Rating: ( 9)
Drives: EVO MR
z lancer man i got extra maf if you need it!!
__________________
My car got totalled, Check out the sale item
Custom Turbo Kit Installed!!
July 20, 2007
Lancer - RIP
2009 Evo MR
Offline
Apr 2, 2007, 09:07 AM
^^ You're a little too late.  Thanks for the offer though. I ended up getting one at a local junk yard for $50. Not the cheapest I found, but I needed it ASAP as the Lancer is my only car!
__________________
Previous Lancers
Offline
Apr 2, 2007, 09:08 AM
Drives: EVO MR
cool cool just tryin to help out
__________________
July 20, 2007
Lancer - RIP
2009 Evo MR
Offline
Apr 2, 2007, 09:12 AM
Thank you, very much appreciated!
__________________
Previous Lancers
Offline
Apr 2, 2007, 10:10 AM
Personal Sales Rating: ( 23)
Drives: Modified 2003 OZ Lancer (RRM tuned)
Good looking out. I am currently using an evo maf because my car is also a dd.
__________________
Items for sale: stock shift knob, stock fuel rail (perfect for boring), stock oz sway with perches, bushings, and bolts (perfect for es guys), vortech 12:1 FMU, 2g DSM BOV, Greddy e-manage with plug n play harness, stock clutch, pressure plate, and throw out bearing, '97 mirage act TOB, and the driver side headlight housing.
PART OUT: http://forums.evolutionm.net/sale-engine-drivetrain-power/322373-part-out-03-lancer-parts.html
Link to my ride!
http://registry.evolutionm.net/viewride.php?vid=3463
Offline
Apr 2, 2007, 09:08 PM
Personal Sales Rating: ( 3)
Drives: 04 4G69 (daily) 97 Mirage 4G63 powered (fun)
98 and up Mirage use the same MAS and same "upgrade" MAS as the Lancer. The 97 Mirage has a bigger pin connector and thus a different upgrade path.
__________________
Daily driver: 4G69 powered Ralliart Lancer
Fun car: 4G63 powered 5th Gen Mirage
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
