Jan 27, 2006, 10:14 PM
Personal Sales Rating: ( 0)
Drives: 4G94T
Balance Shaft Removal...
I searched but didnt find much about balance shaft removal in the 4G94. They arent any kits im aware of made for our engines. Anyone know if the 4g93 balance shaft eliminator, it comes with:
Balance Shaft Eliminator Parts
MD103722
Balance shaft
bearing, rear
MD040597
Balance shaft
bearing, front
MD092785
Balance shaft
cap (plug)
MD098626
Balance shaft
stub shaft
Anyone have any ideas on this? I had this mod done on my 1G, it frees up a few extra horses, and generally increases oil pressure, soething you want in a turbo setup
__________________
BOOOST
Offline
Jan 28, 2006, 09:23 AM
Personal Sales Rating: ( 88)
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
It is basically the same motor, just stroked out. So I'd say that the kit would probably work.
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Jan 28, 2006, 09:52 AM
Drives: 4G94T
yea i fiqured it has a very similar block. I think I'm going to try and pioneer something....
__________________
BOOOST
Offline
Jan 28, 2006, 08:16 PM
Drives: Ralliart
As far as i know there are no balance shafts in the Lancer... that goes for either the 2.0L and the 2.4 for the ralliart.
I've seen both torn down and there's nothing like it in there. They use an excentric gear to pump the oil... it's driven off the timing belt like the water pump is. I know on the 1G there's another belt in there and with this you eliminate that. And those shafts are like the length of the motor and weight like 5 pounds or more. Nothing like that in the lancer motors.
If you do find one in there... let us know.
Offline
Jan 29, 2006, 11:15 AM
Drives: 4G94T
Hmm, Interesting, I could've sworn i read on a older post we had them. Oh well I need to remove the oil pan soon. I'll be sure to check, maybe take a pic or 2
__________________
BOOOST
Offline
Jan 29, 2006, 04:49 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
The 4G69 definitely has a counterbalance shaft. On the attached image, part number 18 is the drive sprocket for it. I'll see if I can get a better picture.
Online
Jan 30, 2006, 12:14 PM
Drives: Ralliart
I've had the 69 apart fully... no balance shafts that i've seen at all. If you know what one is and how the oil pump is on the 4G63 you'd see there's nothing like it in these motors.
Offline
Tags
1g, 4g63, 4g63t, balance, eliminator, evo, evolution, ford, kit, lancer, removal, remove, shaft, shafts, stub  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
