Jun 28, 2005, 06:33 PM
Personal Sales Rating: ( 5)
mirage cam
Does anyone know if the mirage cam will fit in the lancer? If so.... we have a stage 1 cam shaft
Offline
Jun 28, 2005, 08:50 PM
Personal Sales Rating: ( 3)
Drives: 04 4G69 (daily) 97 Mirage 4G63 powered (fun)
It wont work.
__________________
Daily driver: 4G69 powered Ralliart Lancer
Fun car: 4G63 powered 5th Gen Mirage
Offline
Jun 28, 2005, 09:12 PM
will the head fit on the lancer or is that a no go too?
Offline
Jun 28, 2005, 09:14 PM
Drives: TJ Wrangler
im not sure if it will fit, it seems that most other mirage parts will fit, but if youre willing to spend the money to see id be glad to hear if it does. you would be better off going to rpw's site and buy cams specifcally for lancers, but the cam gears for 97-02 (i think thats the right years-1.8L) will fit 02+ lancer
Offline
Jun 29, 2005, 12:08 AM
Personal Sales Rating: ( 8)
Drives: A little red Neon. I also have a Lancer that presumably still rolls...but doesn't drive.
Don't use it. Assuming you had the capability to tune for the changes in lobe profiles...it's a less aggressive cam. Absolute waste of time. And it fits, oz4g94. Our heads are identical aside from the cam. And we already had cams available from RPW through Vision Imports.
__________________
Quote:
Originally Posted by Foggy
I believe the bears are our future
Feed them well, and let them lead the way...
Quote:
Originally Posted by Raphael
Hi. As you can see I'm a bear. I contain no artificial flavors and no artificial colors. Now you may be thinking, "Oh, he's such a cute little bear," but let me tell you I am hard. Really hard. Deep down, I am still a bear. An animal born to raise hell. If I saw a dinosaur right now I'd rip his head off.
Sign up to win prizes by running web searches with Blingo. Powered by Yahoo!
Offline
Jun 29, 2005, 11:14 AM
Personal Sales Rating: ( 88)
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
To be clear (since he's buying it from me), Hobie is saying the head WILL fit but the cam WON'T.
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Jun 29, 2005, 02:31 PM
I had discussed this in another thread.
The heads of the 4G93 and the 4G94 are identical. Same exact head, except for one change, the 1997 Mirage head had solid lifters, while 98 - present have hydraulic lifters. The main difference, as someone mentioned, is in the cam profiles. The 4G94 cams have different durations due to the longer stroker of the motor.
In summary, a Mirage cam would not be effective in a Lancer, but the Mirage head could be used.
__________________
Offline
Jun 29, 2005, 06:42 PM
No, the cam WILL fit, it would just be retarded to run it.
__________________
Offline
Jun 30, 2005, 03:52 PM
I thought the cam duration for the 4g93 was 248 intake and 248 exhaust. On the 4g94 its 240 intake and 248 exhaust. I'll find the post on it from mitsiman.
Offline
Jun 30, 2005, 04:00 PM
Here we go...... http://forums.evolutionm.net/showthr...&highlight=248
I know I've seen more posts on different forums on how the lancer cam is smaller than the mirage cam. I'll have to look in the Aussie forum.
Offline
Jun 30, 2005, 06:06 PM
If you want to try to run the Mirage cam, I'd think you'd need some tuning. The ECU is expecting the 4G94 cam output, so the new air/fuel mix and exhaust will be a shock to the system...
__________________
Modern Warfare 2
Offline
Jun 30, 2005, 09:48 PM
I'd be surprised if the Mirage cam were more aggressive. I guess it's not impossible. What I DO know is that it probably won't run without some trouble on the stock ECU. If anyone wants a stock 1.8l cam I'm sure I could pull mine for a nominal fee and shipping.
__________________
Offline
Jul 22, 2006, 11:41 PM
Personal Sales Rating: ( 11)
Drives: 2003 Mitsubishi Lancer ES
I dunno much about Cams really.
It sounds like youre all talkin' about stock Cams,
but does this mean that an aftermarket Cam upgrade for the Mirage,
wont work for the Lancer either?
Offline
Jul 23, 2006, 04:17 AM
Personal Sales Rating: ( 0)
Drives: Mitsubishi Magna 2000
The mirage camshaft if you get the hydraulic one is slightly larger than the factory camshaft. It woudl be considered a stage 1/2 compared to a RPW stage 1 camshaft. There woudl be no need for any ecu changes or engine mods. Would be a good budget upgrade for someone wanting a cheap camshaft and didn't want to do massive changes to the car.
Make sure you get the late model hydraulic one though, not the early model adjustable tappet unit.
__________________
Racing Performance Works - Mitsubishi Specialists. Check our website if you want to know more.
Offline
Jul 23, 2006, 04:16 PM
Personal Sales Rating: ( 2)
Drives: lancer oz
the mirage cam IS more aggressive. the engines are tuned differently from the factory, the mirage to have less torque and more high end output on the 1.8/ adding the mirage cam is a perfect addition to the lancer imho. the grind gives you more top end power.
__________________
welcome to the rage
my island bishi' Blacklancerr, aka kevin, aka teh black hole. ;p
Offline
Tags
18l, 2002, 4g93, 9702, 98, aftermarket, cam, camduration, cams, camshaft, camshafts, engine, kit, lancer, mirage, mitsubishi, shaft, tune  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
