Go Back   evolutionm.net > Lancer Forums > Lancer General > Lancer-Mirage Compatibility Forum
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 11, 2006, 09:53 AM   #1
EvoM Moderator
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
The big Mirage-Lancer thread
I'm just going to use this thread to give a brief glimpse of what works. All info is based on the 4G93 motor (1.8 liter) used in 5th generation Mirage DX models.
Please post up anything I don't have listed and it'll be added.
Engine:
Crank pulley - any 4G93 crank pulley will fit on the Lancer 4G94. If an underdriven pulley is purchased, a new belt will be needed.
Part number's of the belts compatible with the UDP (those are just ordinary DAYCO belts).
Drive Belt # 5050490-5PK1245
Alternator #5040285-4PK0725
Throttle body - 50mm, which is smaller than the 4G94 stock TB. Also uses different wiring (throttle position sensor, etc.).
Intake manifold - a newly-popular swap. The 4G93 intake manifold flows much better than the stock 4G94 IM. Threads regarding the swap can be found in this forum.
Head - exact same part as the 4G94 head. If you can get a cheap one and port it, it's a great start.
Notes:
Cam position sensor is different.
Lifters - 1997 are solid and then 98+ are hydrolic
Camshaft - if will work, however the Mirage and Lancer are tuned differently. Getting a 4G94 cam will most likely produce better results.
Cam gear - any aftermarket cam gear will work.
Header/exhaust manifold - stock header is tubular (rather than the 4G94's more restrictive design), but it's somewhat shorter. Will work perfectly if lengthened (can be done by any exhaust shop).
Turbo manifold - obviously coming off a 4G93T or turboed 4G93. This will fit.
Exhaust gaskets - they're pretty damn close to the same size. In a pinch, I've used them when the part store didn't have Lancer gaskets. I just had to open the bolt holes a tiny bit.
Spark plug wires - exact same part. I personally recommend NGK ME-96 wires. $22 at ngk.com
Fuel rail - same part. Can be ported just like 4G94.
Fuel injectors - they fit, but they flow 210cc - 30 less than the stockers. Send them out for modification or sell them to a guy with a 1.5L Mirage.
Valve cover - same cover, but the PCV looks different. Great for getting powder-coated.
Drivetrain:
Clutch - 4G93 clutches will work on 4G94 motors perfectly. There are many aftermarket options available.
Pressure plate - fits.
Flywheel - same part, so aftermarket lightweight flywheels will fit. Confirmed that any flywheel for 4G92 or 4G93 will fit.
Throw-out bearing - confirmed to NOT fit 02-03 models. You must either reuse the stock Lancer TOB or purchase a new one from . But do not try to use a Mirage TOB. That being said, it WILL fit 04+ models.
Brakes
Rotors - Lancer ES models that have the 4x100 bolt pattern can use aftermarket Mirage rotors.
Pads - the jury is out on this one. Some say yes, some say no. Check with the pad maker to be sure. But realistically, there's enough Lancer pad makers that you really don't need to go to the Mirage parts for this item...
BBK/rear brakes - again, the ES should be able to use them. Haven't encountered any Lancers that have actually done it, though.
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Old Aug 11, 2006, 10:03 AM   #2
Personal Sales Rating: (16)
comatose721's Avatar
Drives: '05 Elanta GT
Send a message via AIM to comatose721
Quote:
DJ, here's the part number's of the belts compatible with the UDP:
those are just ordinary DAYCO belts. i forget the exact length.
ALSO, i just read that somebody called mitsu and confirmed the fly's have the same part number....therefore being compatible
mark
__________________
...fill your hands with something tangible...
Offline
Old Aug 11, 2006, 10:14 AM   #3
EvoM Moderator
Thanks. Added it.
__________________
Modern Warfare 2
Offline
Old Aug 12, 2006, 01:27 AM   #4
Personal Sales Rating: (4)
2003 Mitsubishi Lancer
Hotshot940's Avatar
Drives: 2003 Lancer OZ Turbo, BBYBruno's "Race Gas Only" Evo
Send a message via AIM to Hotshot940
Doug you MAY want to check up on the throwout bearing thing. I was told something about 02 lancer are able o use the throwout bearing, while 03+ have the throwout bearing attached to the shifting fork as one peice, i know that was the case with mine, and i was not able to use the throwout bearing provided with my mirage clutch, but it should have worked with an 02 lancer. Look into that but I'm pretty sure it's right.
__________________
Powered By
Road///Race Motorsports
Offline
Old Aug 12, 2006, 08:26 AM   #5
EvoM Moderator
Edited. Thanks, Matt.
__________________
Modern Warfare 2
Offline
Old Aug 24, 2006, 06:00 PM   #6
Personal Sales Rating: (3)
2001 Mitsubishi Lancer
Evo666's Avatar
Drives: the image above
Send a message via AIM to Evo666 Send a message via MSN to Evo666 Send a message via Yahoo to Evo666
I worked on my buddy's car ('02 lancer ES) and his front brake pads look different from mine ('01 mirage)
__________________
Myspace - Cardomain
Offline
Old Aug 25, 2006, 11:15 AM   #7
EvoM Moderator
Thanks! Much appreciated.
__________________
Modern Warfare 2
Offline
Old Aug 25, 2006, 01:14 PM   #8
Personal Sales Rating: (1)
Kurt's Avatar
Drives: Something with a turbo and AWD
Send a message via Yahoo to Kurt
Quote:
That is not the case. The 02's throwout bearing is attached to the shifting fork(one piece). I just had mine replaced a couple months ago.
edit.
here is the picture of the throw out bearing that came with my clutch kit.
__________________
If you are happy and you know it, stick with your dosage.
Member of the EvoM OT BLT club.
Offline
Old Aug 25, 2006, 03:35 PM   #9
EvoM Moderator
And we have our final answer!
__________________
Modern Warfare 2
Offline
Old Sep 21, 2006, 09:11 AM   #10
Personal Sales Rating: (9)
krnzzang84720's Avatar
Drives: EVO MR
Send a message via MSN to krnzzang84720
how about the shock and suspension?? are they the same??
__________________
My car got totalled, Check out the sale item
Custom Turbo Kit Installed!!
July 20, 2007
Lancer - RIP
2009 Evo MR
Offline
Old Sep 21, 2006, 11:21 AM   #11
EvoM Moderator
Not exactly sure. Might be some similarity with the ES model, as the Mirage and ES are more similar in brakes, lug pattern, etc.
__________________
Modern Warfare 2
Offline
Old Sep 21, 2006, 09:02 PM   #12
OZrallyMatty's Avatar
Location: addison, not to be confused with aurora, illinois
Drives: 2002 Mitsubishi Lancer OZ
what part of the header is too short? the downpipe... cuz headers are cheap for the mirage, i wanna pick up some
__________________
----------for sale-----------
2-, 12 inch 1300 watt octagonal sony x-plod subs in a bandpass box, with a 1600 watt soundstorm amp, very very loud, pics coming soon, $250 obo PM me if interested
Offline
Old Sep 21, 2006, 09:51 PM   #13
Drives: EVO MR
man!!! is anybody is going to produce shocks/strut for our oz?? I really want some high performence KYB or Tokeiko Shocks!!!! desperate!!!
__________________
July 20, 2007
Lancer - RIP
2009 Evo MR
Offline
Old Sep 21, 2006, 11:48 PM   #14
rhyzin's Avatar
Drives: '02 Mitsubishi Lancer OZ "Rally" Edition
Send a message via AIM to rhyzin
so you guys know, the 04+ lancers share the same throwout bearing as the last two generations of mirages. MD722744.
__________________
Dyno'd Lancers List
[ S C L C . n e t ] <- Southern California Lancer Club
Looking for stock parts? Look here first --\))> www.car-part.com
Basic Engine FAQ
Offline
Old Sep 22, 2006, 12:18 PM   #15
EvoM Moderator
Quote:
Put a spacer between the header and downpipe and you should be golden.
Basically, the 4G94 block is taller, so it hits on the Mirage exhaust.
__________________
Modern Warfare 2
Offline
Tags
02, 20, 4g93, 4g94, 98, adjustable, bearing, bolt, damper, exhaust, lancer, lower, manifold, mirage, oil, pan, part, pattern, throw, tob
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
