Go Back   evolutionm.net > Lancer Forums > Lancer General > Lancer-Mirage Compatibility Forum
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 6, 2006, 07:54 PM   #1
Personal Sales Rating: (4)
2003 Mitsubishi Lancer
Hotshot940's Avatar
Drives: 2003 Lancer OZ Turbo, BBYBruno's "Race Gas Only" Evo
Send a message via AIM to Hotshot940
Mirage / Lancer Compatibility?
Ninja mod edit - this thread was originally in Lancer Transmission. Since then, it's become a really helpful discussion. Moved to Lancer General. -Blacksheepdj
I know that the clutch from the 1.8 liter mirage is interchangable with the 2.0 lancer clutch, but I was wondering if anybody knows if the flywheels and limited slip differentials are also interchangeable, at the least i would think the flywheel is too, but i'm looking for someone that has a solid answer before i start spending money.
__________________
Powered By
Road///Race Motorsports
Offline
Old Apr 7, 2006, 12:48 AM   #2
Personal Sales Rating: (23)
grubiaco's Avatar
Drives: Modified 2003 OZ Lancer (RRM tuned)
Send a message via AIM to grubiaco
Hotshot do you know if the alignment tool is the same also?
Also, what are you planning on getting and where? I just want to keep my options open also.
__________________
Items for sale: stock shift knob, stock fuel rail (perfect for boring), stock oz sway with perches, bushings, and bolts (perfect for es guys), vortech 12:1 FMU, 2g DSM BOV, Greddy e-manage with plug n play harness, stock clutch, pressure plate, and throw out bearing, '97 mirage act TOB, and the driver side headlight housing.
PART OUT: http://forums.evolutionm.net/sale-engine-drivetrain-power/322373-part-out-03-lancer-parts.html
Link to my ride!
http://registry.evolutionm.net/viewride.php?vid=3463
Offline
Old Apr 7, 2006, 01:08 PM   #3
Hotshot940's Avatar
i think the alignment tool is the same, i was told that a 1997 1.8 liter mirage clutch WILL fit on our cars. i would ASSUME the flywheel will as well, but i'm not 100% sure. I would also really like to know if the limited slip differential from the mirage can be used in our transmission, i would think they probably could, i'm pretty sure the only major difference between the cars is our is basically a .2 overbore.
__________________
Powered By
Offline
Old Apr 7, 2006, 01:46 PM   #4
grubiaco's Avatar
I'll look into the limited slip differential along with the flywheel.
__________________
PART OUT: http://forums.evolutionm.net/showthread.php?t=322373
Link to my ride!
Offline
Old Apr 7, 2006, 09:37 PM   #5
Hotshot940's Avatar
alright sweet, just post up in here what you find out, i'll do the same
__________________
Powered By
Offline
Old Apr 7, 2006, 11:21 PM   #6
grubiaco's Avatar
Does anyone know the specs of our flywheel? If so we can compare the two and see if they are identical. The mirage 1.8L are 7 bolt pattern 215 mm.
__________________
Link to my ride!
Offline
Old Apr 7, 2006, 11:33 PM   #7
grubiaco's Avatar
Did some more digging and this is what I got.
http://www.coximports.com/FID-161111
However, no one has verified anything yet. I am waiting for a response from the mirage boards. This looks promising though.
Hotshot, what places are you looking at to get your clutch and flywheel. Hopefully, you have some places that are good buys because I am going to quite searching right now.
__________________
Link to my ride!
Offline
Old Apr 8, 2006, 01:08 PM   #8
Hotshot940's Avatar
well from that link i would consider it safe to say that the flywheels would fit as well. i'm basically looking around for clutches that will handle around 250 ft lbs of torque, the thing is there are so many more mirage applications, they are much cheaper. from what i've seen, flywheels are still pretty expensive. i was looking for an lsd also, and phantom grip has one but it says its for the mirage.
__________________
Powered By
Offline
Old Apr 8, 2006, 07:32 PM   #9
Personal Sales Rating: (16)
comatose721's Avatar
Drives: '05 Elanta GT
Send a message via AIM to comatose721
i've got an OEM fly in my garage. i'll check the bolt pattern. what is the 215mm a measurement of?
__________________
...fill your hands with something tangible...
Offline
Old Apr 8, 2006, 08:57 PM   #10
grubiaco's Avatar
This is what I pulled from the mirage guys.
110 teeth on the ring gear, approximately 11 1/16" diameter. (ring gear, from tooth point to point.)
the aluminum flywheel outside dia. is 10 3/8"
the center hole that locates on the crank is somewhere around 1 3/4"
__________________
Link to my ride!
Offline
Old Apr 8, 2006, 09:02 PM   #11
grubiaco's Avatar
By the way those measurements are for the flywheel.
The 215 mm was for the clutch
__________________
Link to my ride!
Offline
Old Apr 9, 2006, 12:08 AM   #12
i've got an ACT clutch in the garage too. if you'd like, i can take the measurements after work tomorrow.
__________________
Offline
Old Apr 9, 2006, 01:43 AM   #13
grubiaco's Avatar
awesome!
__________________
Link to my ride!
Offline
Old Apr 9, 2006, 04:49 AM   #14
Personal Sales Rating: (3)
2001 Mitsubishi Lancer
Evo666's Avatar
Drives: the image above
Send a message via AIM to Evo666 Send a message via MSN to Evo666 Send a message via Yahoo to Evo666
it should be the same and i believe we both share the same tranny
__________________
Myspace - Cardomain
Offline
Old Apr 9, 2006, 10:59 AM   #15
grubiaco's Avatar
just out of curiosity are the gear ratios different? Because the 1.5 to 1.8 are the same tranny with the exception of different gear ratios.
__________________
Link to my ride!
Offline
Tags
18, 97, difference, grip, interchangeable, knob, lancer, lsd, mirage, modified, mr953195, oz, parts, phantom, sale, shift, tuned
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
