Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer How Tos / Installations
Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Closed Thread
Old Apr 3, 2004, 01:06 PM   #1
Personal Sales Rating: (6)
majestic lancer's Avatar
Drives: white pearl rsx-s
Send a message via AIM to majestic lancer
** HOW-TO ** making stock radio red
Step 1:
while in the car, take off the front plastic panel where the climate control and the radio is by following JTC's how-to on changing the interior bulbs. you will see 4 screws holding in the radio.. take them out and pull the radio out. you will see a black wire and a harness connected to the radio. pull both of them out as indicated in the picture. i am only telling you to take it out because it can get very aggravating when you're trying to take the faceplate off while in the car. so take the radio inside and you're ready to get started.
__________________
2004 premium white pearl acura rsx type-s w/ black and red type-r interior
Offline
Old Apr 3, 2004, 01:09 PM   #2
Step 2:
Once the radio is out, turn it upside down and you will see two little screws which you will have to take out
__________________
Offline
Old Apr 3, 2004, 01:11 PM   #3
Step 3:
after taking out the two little screws, you will then be able to take off the faceplate by removing all the clips that hold it in..
here's a picture of the bottom four clips you have to remove..
__________________
Offline
Old Apr 3, 2004, 01:12 PM   #4
Step 4:
here is a big clip you have to also remove on each side of the radio.. it is best to have a small flathead screwdriver and just get underneath the clip and lift. it gets rather annoying trying to do it with you fingers..
__________________
Offline
Old Apr 3, 2004, 01:14 PM   #5
Step 5:
and the last of the clips are located on top of the radio.. when trying to take out the clips, you may get frustrated that some clips snap back into place after you have already taken them out while trying to unclip other ones. so the best thing to do is work from one side to the other.. unclip the big clip on the side first, then work yourself down to the opposite side..
__________________
Offline
Old Apr 3, 2004, 01:17 PM   #6
Step 6:
now that you have the faceplate off, the first thing you do is take out the 'tuning' knob and the 'volume' knob. the volume knob is pretty easy to take out, but the 'tuning' knob might be a little tough. if that is the case, take a set of pliers and pull it off.
turn the faceplate over so that you are in view of the backside of the circuit board. you will need to take out the two small screws as pictured.. when taking out the screw on the right, a small metal piece, indicated by the arrow, will also come off.. do not be alarmed. just simply put it back to the way it was after the completion of the install.
__________________
Offline
Old Apr 3, 2004, 01:27 PM   #7
Step 7:
** NOTE **
there are no red colored gels small enough to fit directly on these small lights. so what i did was buy the red gel cap covers used to cover the dome light from pep boys and just cut it up.
take out the circuit board and turn it over. you will see 8 bulbs covered by little blue condoms. simply take off the blue coverings so that you expose all 8 bulbs. take the red gel cap covers and cut them. after cutting it up small enough to cover the bulbs, simply tape it down with SMALL, TINY strips of tape. make sure you cut the gel large enough so that it covers the bulb almost entirely or you will get a little variation in color.
for the screen, just buy the same red theatrical filter used for the red clock mod and tape two layers over the radio screen. if you only use one layer, it will come out orange. the only downside to making the screen red is that the radio display will be hard to see during the daytime. however, it will look really good at night. its your choice if you want to leave the screen white or make it red..
__________________
Offline
Old Apr 3, 2004, 01:32 PM   #8
Step 8:
reassemble the radio, plug it back into your car, screw in the 4 screws holding it in place, and put the front panel back on. if done correctly, your radio should now look like this..
hope this how-to was of some help to some of you.. enjoy
INSTALLATION COMPLETE
__________________
Offline
Old Apr 3, 2004, 06:00 PM   #9
EvoM Administrator
Bomb Squad Unit #01
Personal Sales Rating: (0)
LancerEvoMR's Avatar
Drives: 2002 Mitsubishi Lancer O-Z Rally
Send a message via AIM to LancerEvoMR
Discuss thread here
__________________
Offline
Closed Thread
Tags
acura, back, bulbs, changing, howto, interior, jtcs, lancer, plug, radio, red, rsx, rsxs, stock, type
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
