Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 1, 2009, 08:32 PM   #1
Personal Sales Rating: (0)
Drives: 2009 RR Lancer GTS
Install Interior LED Lights
I finally got around to installing my interior LED kit from LEDGLOW and thought I would take a few pics for anyone interested. I chose to install the kit through the in-dash fuse block, you can also wire it directly to the battery but I didn't feel like poking around under the hood for this.
Here is what you will need;
-Standard or MINI Fuse adapter/splitter: 3.99 at Kragen (Comes with 10A fuse).
-Adjustable wrench or socket.
-Wire strippers/scissors.
-Pliars/fuse puller.
1: To start, you will need to open the in-dash fuse panel to find out where you will place the fuse adapter. I chose Fuse#25 which has a 30A fuse for the heated seats (GTS doesn't have heated seats so I went for this one in case anything went wrong). Use the manual or the poorly visible imprint on the back of the fuse panel to find #25.
2: Once you found where to place it you will want to start by stripping back some more of the wire on the positive side of your LED kit if needed. Then insert the wire into the blue butt connector and crimp it down slightly past the divot using a pair of pliers/crimpers/ or wire strippers.
3: Now that the wire is securely connected you can now ground it, locate the bolt below the drivers seat directly above the footrest. Remove the bolt with an adjustable wrench or socket driver and place the ground wire under the head of the bolt, make sure to strip enough of the wire back as my kit needed to be re-stripped.
4: After grounding it now take a pair of needle-nose pliers and remove the fuse you selected earlier, be careful not to bump around too much when doing this and accidentally set off your knee airbag!
5: Place the removed fuse into the lower part of the adapter and the supplied 10A fuse in the top accessory slot and insert it back into the fuse block. There should be no need for you to disconnect your battery when doing this if you follow this method, make sure to ground first before you place anything into the fuse block.
6: Now you can turn your LED kit on and start placing your LED tubes. The wires are easily concealed by tucking them under the plastic interior molding. I placed the hub under the drivers seat inside and used Velcro to tie up the wires under the seat. The rest is just a matter of finding the sweet spot of getting the best light without having to worry about accidentally kicking your LED's.
I still have a little adjusting to do, I will end up using Velcro to hold the LED's up rather than the supplied double sided tape and holders.
If anyone has questions let me know or discuss.
Hope this helps someone.
Offline
Old Nov 2, 2009, 12:21 PM   #2
Drives: Lancer X 1.8 MT
Cool!!! Is it possible to get direct link to buy interior LED kit from LEDGLOW?
Offline
Tags
09, accessory, fuse, install, installation, installing, interior, lancer, lancers, led, ledglow, lights, panel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
