Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 22, 2009, 06:09 AM   #1
Personal Sales Rating: (0)
JoeyBallGame's Avatar
Drives: '08 Lancer CVT ES-GT
Send a message via Yahoo to JoeyBallGame
Question 08+ RRM side mount plate kit
Can anyone provide instructions to correctly install the RRM Licence Side Mount Plate Kit...?
__________________
JoeyBallGame
'08 CVT Lancer ES-GT Silver Metallic
[x]5-15% Performance Tint
[x]RRM Pulley
[x]RRM SRI
[x]MagnaFlow Axle Back Exhaust
[x]1st Brake Upgrade
[x]RRM Chassis Braceing Kit
[x]RRM Rear Sway Bar
[ ]17" Lite Wt. Wheel & Tire Combo (Spring '10)
[ ]Pruven Performance Custom Engine Tuning
[ ]RRM Motor Mounts
[ ]RRM Coil Over Adjustable Suspension
[ ]RRM CVT Turbo w/ Trans Cooler
[ ]RRM CarbonFiber Covers & Hood
[ ]EVO Body Kit & New Paint Job...
Offline
Old Sep 8, 2009, 03:13 PM   #2
Question Bump...
Bump...
__________________
JoeyBallGame
[x]RRM Pulley
[x]RRM SRI
[ ]RRM Motor Mounts
Offline
Old Sep 8, 2009, 03:46 PM   #3
Liuc's Avatar
Drives: '09 Mitsu Lancer SE
I covered the bumper with masking tape (not whole bumper ), then found a perfect position for license mount and marked drill holes with pencil. Drilled holes, took of masking tape and mounted the kit.
Offline
Old Sep 9, 2009, 05:19 AM   #4
Question License Plate Mounting Kit Instl
Quote:
The fastener grommets that are supplied with the kit, how are they perminately fastened to the bumper...? And what size hole do you drill for these grommet fasteners...? Are they a expandable grommet...? Please explain...
Thanks,
__________________
JoeyBallGame
[x]RRM Pulley
[x]RRM SRI
[ ]RRM Motor Mounts
Offline
Old Sep 9, 2009, 10:36 AM   #5
2009 Mitsubishi Lancer
bmoresauter13's Avatar
Drives: Lancer GTS 09
i was wondering how it stayed on also. the license plate is held on by them to i think. im trying to find out what size holes to drill, i was thinking about just sizing it up with the ones that are on the middle bumper.
What can you use to cover the holes up or will vinyl be good without anything under it?
__________________
[X] 35% tints
[X] smoked tail lights
[X] black rims
[X] RRM SRI
[ ] Axle Back Exhaust
[ ] RRM Aluminum Crank Pulley
[ ] Carbon Fiber Evo X Wing
[X] Blacked Out Grill
[ ] Carbon Fiber Mirror Covers
[X] Evo-X Style License Plate
Offline
Old Sep 9, 2009, 11:22 AM   #6
Liuc's Avatar
I used 1/2 inch drill bit. I looks kind of big at first, but it fits perfectly. Check before drilling anything. I used some vinyl to cover holes in the middle and sprayed with Plasti-Dip on top.
Regarding mounting grommet, here is my quick sketch
Offline
Old Sep 9, 2009, 02:55 PM   #7
k thanks, that helps alot
__________________
[X] 35% tints
[X] black rims
[X] RRM SRI
Offline
Old Sep 13, 2009, 06:35 PM   #8
09GTSCuban's Avatar
Drives: 2009 LANCER GTS
i didnt even use those. they seemed a little cheesy... i put in rivets in the four holes. it worked a lot better. its sturdy, and looks amazing!
Offline
Old Sep 15, 2009, 06:01 AM   #9
Question Rivets...?
Quote:
What size rivets did you use...? What material rivet did you use...? Was it a CRES (corrosion resistant steel) Blind Protruding Head Rivet...?
__________________
JoeyBallGame
[x]RRM Pulley
[x]RRM SRI
[ ]RRM Motor Mounts
Offline
Old Sep 18, 2009, 12:22 AM   #10
lancerarmstrong's Avatar
i've seen pictures of this rrm plate mount and it doesn't match up at all. i just fiberglassed my own, it's not hard you know.
Offline
Old Sep 18, 2009, 12:55 PM   #11
Off subject...
Quote:
I already have the kit This was meant to get tips for the installation of the kit from RRM...
__________________
JoeyBallGame
[x]RRM Pulley
[x]RRM SRI
[ ]RRM Motor Mounts
Offline
Old Sep 18, 2009, 12:57 PM   #12
Arrow What Size & Type Fastener...?
Quote:
Bump...
__________________
JoeyBallGame
[x]RRM Pulley
[x]RRM SRI
[ ]RRM Motor Mounts
Offline
Old Sep 18, 2009, 01:01 PM   #13
Plat Vendor
Brian@RRM's Avatar
Drives: 2003 mitsu RRM 16G TURBO
STEP 1: hold the plate holder up to the car in the desired location
STEP 2: drill 4 holes in the bumper of you car the same size as the hole in the plate holder
STEP 3: place the rubber grommets in the holes that you just drilled
STEP 4: place the plate holder back in place and fasten with the screws and washers provided.
__________________
BRINGING U THE FASTEST SEXIEST LANCERS IN THE US
Offline
Old Oct 22, 2009, 06:23 PM   #14
mguerrero's Avatar
Drives: 09 white lancer gts stock =(
Those aren't good instructions we need specs. and sizes maybe even a tutorial video if you'd be so nice..
Offline
Old Nov 3, 2009, 10:34 PM   #15
Drives: Tarmac Black 08 Lancer GTS
I've been told to place the license side plate one and a half finger away from the middle part. like the end of the grille
__________________
Mods
-6000k BiXenon E55 Projectors w/Angel eyes-Yellow Fogs-LED(City lights, Interior Lights, License Lights)-MMCS Navigation-Debadged-Tints-Smoked(Tails, side markers, rear reflector, 3rd brake lights)-Injen CAI-HKS Hi Power Exhaust-VG-Shorty Antenna-Blacked Out Front-Mitsu Red Emblems-Red Calipers
To Be Installed
-OEM Ralliart Front Bumper-OEM Evo X GSR Enkei Rims-EvoX MR Spoiler-Side Plate Mount
Want
EvoX Hood-LED Side Mirrors-OEM MR Recaros-Sound System-New Brake Pads/Rotors-Front/Rear Lip
Offline
Tags
08, body, instructions, kit, lancer, license, mount, plate, rrm, side
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
