Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 13, 2009, 05:32 PM   #1
Personal Sales Rating: (1)
darkmitsu's Avatar
Drives: 02 mitsubishi lancer es
How to Swap your ECU...
1. Open your glove box on the left hand side there is a romovable tab...
2. Remove it...
3. grab the right hand side of the glove box and push left to get the tab over
4.
5. open the glove all the way towards the floor and it will pop off
6. grab a hold of the wire harness cover and pull it towards you
7. unplug the ecu
8. remove the three black 12mm bolts
9. the ecu should fall to the floor
10. to remove the ecu from the metal bracket use a flat head screw driver and pry on the outer edge.
11. then reverse to get everything back in...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
