Quote:
Originally Posted by cmiller5150
What are some of the things I can do boost my horsepower? Has any one put a proformance chip in and if so, can you do yourself and do you have to reconfigure the computer? Also what about the K&N cold air filter system? Thanks for any help you can offer on my 2009.
I would stay away from the chips. Some guys have been ripped off by b/s chips out on the market. Get the works ecu reflash or buy a piggyback unit. As stated by the others how much hp depends on how much you spend. A turbo kit gets you to about 200HP, but they are $4-5k so you are looking at the best case being ~$100/hp for the turbo option. The other mods you can do get you as stated from 4 to 20 hp for a total cost of ~$500-1k so you are looking @ best case of $25/hp if you can squeeze 20hp out of a few cheap mods. talk to other members though. see what combination works the best. If a CAI is tested for 7hp, and a catback exhaust is tested to 11hp, you might not always see a 18hp gain.
Also think about options that lighten the car like cf body parts, lighter aftermarket rims, etc. lightening the car can get very expensive even for <300lbs or so. Remember power to weight ratio plays a role in acceleration so either increase hp or reduce weight or any combination of the two.
