Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 21, 2009, 02:34 AM   #1
Personal Sales Rating: (1)
Juan Martinez's Avatar
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
Send a message via Yahoo to Juan Martinez
How to: 02-03 Projecter headlights and HID install
I have just completed my install of my projectors and HID kit on my 03 Lancer OZ. This will work on all 02-03 Lancer ES/LS/OZ Rally Editions. I got the headlights and HID as a kit together off of a member on Ebay who prewires them for plug and play. Even though they where plug and play, there were some modifications I had to make to get them work correctly.
First, unhook the positive terminal on your battery (be safe, not sorry).
Next, you'll need unbolt the 3 bolts that hold in your headlight. You'll have to angle the headlight just right to get it out. After you get the headlight out far enough, you can unplug the harness's from the headlight.
Next, I found that the plug for the running lights that came on the new headlights didn't want to plug up very well so I reused the connector off my old headlights. You'll have to cut and rewire them into your harness thats attached to the headlights. its the one that a screw holds down the connector. You may not have to do this if the connector on the new headlights connects and your running lights work.
Next, I found the light socket for the turn signal didn't fit well either and it didn't work. Just remove the socket from the hold headlights, replace old bulb with the new bulbs that came in the headlight and plug them into the new headlight.
Now, just plug up all 3 of the harness's to the stock harness. Here is a pic of the headlight hookup up close
Next, find a place to mount the ballasts. I didn't have alot of time, so I just zip tied the passenger side to the cruise control mount and the other to the side of the fuse box.
Make sure all the connectors are connected. Before you bolt your headlight in, make sure all the bulbs work. Hook your battery back up. When you turn them on, make sure you leave the HID low beams on for 10 min for burn in time. You may want to start your car before hand. I drained my battery doing this. If your high beams don't turn on, I found that mine came wired incorrectly. They mixed up the positive and negative sides. If that is the case and yours don't turn on, all you have to do is take the black rubber piece off the back of the headlight on the low beam/projector side. Behind that, you should see a connector that has two wires hooded into it. Just reverse them. Now, they should work. If you get the headlights without the HID, this is the best place to tap in for the power to the ballast because you will not have to cut any wires. Here is the finished pics
__________________
Build Thread http://forums.evolutionm.net/lancer-...ld-thread.html
Check out my rides at
http://www.cardomain.com/id/k_dog007
03 Lancer OZ Rally
04 Lancer ES
98 Eclipse RS (Traded in July 2007 for 04 Lancer)
01 Mirage ES (Traded in on Eclipse in 2005)
85 Pontiac Fiero (never made it on the road, sold 2004)
93 Eagle Summit ES (Traded in in July 2003 for 01 Mirage)
Offline
Old Mar 21, 2009, 02:38 AM   #2
Personal Sales Rating: (0)
thanks for the DIY!
Offline
Old Mar 21, 2009, 03:19 AM   #3
Quote:
Originally Posted by yadoh View Post
thanks for the DIY!
I hope it helps. Its more of how to fix the all the problems with these lights than how to install. The actual install would probably only take 20 min, but the issues I had made it take almost 1 1/2 hours. I'm probably going to rant on about the problems, but they are good headlights.
__________________
03 Lancer OZ Rally
04 Lancer ES
Offline
Old Mar 22, 2009, 01:01 PM   #4
Personal Sales Rating: (19)
sykou's Avatar
Drives: 2003 Lancer OZ Rally
hey thanks for the write up. Do you have any pictures of the inside of the headlight from the back side? trying to tell if theres enough room to retro a set of tsx projectors into them....
__________________
"Everything is LEGAL... As long as you don't get caught."
Offline
Old Mar 22, 2009, 11:14 PM   #5
Quote:
There should be room, but why would you want to take out the projectors and put in the tsx ones?
__________________
03 Lancer OZ Rally
04 Lancer ES
Offline
Old Mar 23, 2009, 04:43 AM   #6
sykou's Avatar
^much sharper cutoff, wider beam pattern, color flicker, clarity etc. try hit up hidplanet to check out the retros other people did. judging by the pic you provided i think the shield is a curved one with a kinda foggy looking lens. the tsx lens is clear, and although the shield is also curved it produces a very sharp cutoff that causes it to seem like its flickering different colors..
__________________
Offline
Old Apr 2, 2009, 04:45 PM   #7
chuloloco's Avatar
Drives: 02 OZ Rally
This post is perfect! I was looking for something exactly like this! Could you take some pics of the headlights from the side? I want to get a better idea of how the amber side marker lights look turned on. If you could possible take 2, 1 when its getting dark outside and 1 when its completely dark outside. If you can only take one, either one will do.
Thanks maing!
__________________
"The 02' Mitsubishi Lancer...the benchmark of performance, style, and sex appeal!"
Offline
Tags
04, 0z, chart, fuse, headlight, hid, hids, install, lancer, lights, make, plugged, projector, removal, work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
