Feb 26, 2009, 09:31 AM
Personal Sales Rating: ( 1)
Drives: '09 RG GTS 5sp
Need Help with K&N Filter
I purchased and installed my K&N drop-in filter for my 09 GTS. I was just wondering if the drop-in is supposed to make the engine louder or have a slight growl under medium to hard acceleration. I am trying to find out if I did not line up the seal correctly, and if that could be causing the growl. I can definitely hear the air rushing into my engine, but I wasn't sure if there should be that vibrating/rumbling growl with it. Thanks.
Offline
Feb 26, 2009, 09:46 AM
Personal Sales Rating: ( 7)
Drives: 2006 Evolution IX GG
it's pretty tough to mess up the install of a filter... but if you are worried try flipping it upside down and seeing if it fits, if it doesnt you have it installed correctly...
__________________
bolt ons... tune one 91... 335 wtq 312 whp, 06 gg ix
Offline
Feb 26, 2009, 09:49 AM
Lol yeah that is what I figured, I just wasn't sure what kind of results I could expect other than low hp gain. Seemed easy enough to install just am not used to the growl so was just wondering if it was normal.
Offline
Feb 26, 2009, 09:53 AM
Personal Sales Rating: ( 0)
Drives: 2006 Evo IX MR, 1979 Chevy C10, 2002 R6
Yeah thats how it always is. I did a short ram one on my evo and did one on my dads tacoma. Its a "little" bit louder! But everything is ok
__________________
♠I would rather be a smartass than a dumbass♠
♠Up on one♠
♠I was part of the AMS website crash of 2008♠
Offline
Feb 26, 2009, 10:05 AM
Drives: 09 Lancer GTS M/T
shouldn't be much change at all in sound... check that everything is lined up well. there have been people reporting that the bottom of the airbox is hard to get clipped with the k&n
Offline
Feb 26, 2009, 10:39 AM
Quote:
Awesome thanks for the tip.  I will check it again tonight. The bottom should be sunk in between the two halves and not flush with them correct?
Offline
Feb 26, 2009, 11:47 AM
Drives: 08 lancer GTS
Quote:
thats exactly right. i have the K&N on mine rite now. its the bottom two clips. take the filter out. get the bottom clips on first thenn slide the filter in. theres ur solution.
Offline
Feb 26, 2009, 12:15 PM
Quote:
Crrappppp. Thanks so much, thats got to be my problem. I'll be doing some adjusting again tonight!  Thanks again everyone for all the help!
Offline
Feb 26, 2009, 12:43 PM
Personal Sales Rating: ( 2)
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
i can guarantee you this is the problem the bottom clips are hard to get in place
but once you do the car should sound normal again.
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Mar 22, 2009, 03:15 AM
2009 Mitsubishi Lancer
how the filter..?? does it gain some hp after installing it..?? I'm thinking of replace mine too...^^
Offline
Mar 25, 2009, 10:25 PM
Quote:
honeslty. not alot of gains i just unclip the bottom clips to make it sound louder  haha
try taking the air tunnel out and just have the air box...its LOUD =D
Offline
Apr 5, 2009, 09:26 PM
Drives: 2008 Lancer ES A/T
i noticed that if you take out the tunnel, you lose high-end torque, and your engine works a lot harder moving at highway speeds.
Offline
Tags
2009, correctly, drop, engine, evo, filter, gts, install, installed, ix, kn, lancer, loud, louder, sound  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
