Oct 5, 2008, 05:02 PM
Personal Sales Rating: ( 11)
2002 Mitsubishi Lancer
Drives: Lancer
Low and high beam on at the same time
Ok so i have cedias and want the low beam to stay on when the high beam is turned on .
What would i need , i know the evo's do that so can i just get the light switch from a evo?
Or could i just buy some kind of relay and wire it up.
Lmk guys
Btw i have 8k hid low beam and 5k hid high beam
haha
Offline
Oct 8, 2008, 09:04 PM
Personal Sales Rating: ( 1)
Drives: 2003 Lancer OZ Rally [ Lightning Yellow ]
i have cedias too.. but i am unable to find that answer...
i dont know how the evo's stay on, but im guessing a relay of some sort
Offline
Oct 9, 2008, 12:02 AM
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
Yes, it is a relay of sorts. I had a 01 mirage that had seperate high and low beams. I had a dual halo set of headlights. I wrecked the front slightly and had to order a new set. The second set came with a wiring harness that had a relay wired in and drew power directly from the battery. It was set up for using both high and low beams at once. You may have to find one of these harnesses or make one yourself. Do you have any pics of your headlights and wiring? I may be able to help out.
Offline
Oct 9, 2008, 12:16 AM
Drives: Lancer
Well i dont have any pics but im pretty familiar with them since i do alot of wiring work .
I found one a couple days ago called the 4 headlights system but it said only for Gm's =/
Offline
Oct 9, 2008, 09:44 AM
Here is a link to a set of mirage headlights with the harness I used on my mirage for dual high beam. http://cgi.ebay.com/ebaymotors/97-98...mZ300264900072
You'll probably have to make your own harness for this, but all you have to do is get two relays, wires, connectors, and the connecters for your type of bulb. You can go on ebay and type in h4 wiring or whatever bulb wiring and find them. Don't worry, I am searching around for you ( and me) to find out how to do this.
Offline
Oct 11, 2008, 06:46 PM
Drives: Lancer
Ok i bought a 5 prong 30 amp relay and wired them so now they both light up when on high beam and high beam turns off when low beam is on
Offline
Oct 11, 2008, 09:13 PM
do a write up
Offline
Oct 12, 2008, 11:32 AM
Drives: Lancer
I might do it under high demand because i dont really like explaining my self lol
But it looks nice!!!!!!!x2
I sold my 5k high beams and put 3k and it looks hawt with the 8k low beam on and 3k high beam!!!!!!!!!!!!!
I'll take some pics later
Offline
Oct 12, 2008, 12:21 PM
Drives: Lancer
Offline
Oct 12, 2008, 03:34 PM
Drives: Lancer
Ok here is the diagram to wire them
All these connections are labeled on the relay (5 prong)
87 High beam positive ( Spliced)
87a Low beam positive( Cut and connected)
85 High beam positive ( Spliced)
86 negative (Spliced)
30 positive going to the bulb ( Cut and connected)
Offline
Oct 12, 2008, 04:59 PM
Interesting. Can that relay be used with bulbs that aren't HID?
Offline
Oct 12, 2008, 07:36 PM
Drives: Lancer
yea i just use hids all the time
Offline
Oct 12, 2008, 09:00 PM
Drives: Lancer
Offline
Oct 13, 2008, 09:07 PM
Personal Sales Rating: ( 3)
Drives: 05 Mercedes Benz
^^ ur head lights are colorful as hell man... i got a ticket for having yellow head lights in my state... so be careful...
Offline
Oct 14, 2008, 10:32 AM
Drives: Lancer
Well i turn them off and on , i noticed people gte really pissed off when i turn on my high beams
and my low beam is 8k , that isnt too blue
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
