Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 5, 2008, 05:43 PM   #1
Personal Sales Rating: (12)
OZ Rally's Avatar
Drives: a boostmobile
Send a message via AIM to OZ Rally
How to install interior lighting... Good Pics
Okay where do I begin?
I saw a couple of guys having trouble with this so I'll just post up how I did it.
What you need...
1) A kit for interior lights, I used this one because it was the cheapest and easier to install. http://www.ledunderbody.com/red4pcledinteriorkit.aspx
2) Zip Ties
3) Exacto Knife or Scissors
4) Long 10mm wrench (for battery)
5) Ring Terminals (2)
Now for the installation...
1) Disconnect the negative terminal first and take it off the prong thing. Be very careful.
2) Disconnect the positive terminal inside the fuse box. Be careful not to touch the negative terminal on the battery with the wrench.
3) Once you have the kit ready (unwrapped from the packaging) lay out the control box on the drivers seat and start putting the lights where you want them to go.
4) For the driver's seat I just put the wires under the carpet and along the right side of the center console.
5) Attach the light with zip ties (both sides of the light) on any bar that you see under the dash.
6) Now the passenger's side is the same but you have to make sure you hide the wires under the dash really well.
7) For this light I used the double sided tape that came with the kit because there isn't a bar to zip tie it to. Just use good judgment on where to apply the light to prevent from others kicking it or seeing it.
8) Now the two back seats are the easiest to do. For under the driver's side just zip tie the light to the bar that runs across the back of the seat. Cut any excess zip tie on both sides.
9) The passenger's seat is the same but just make sure u hide the wires really well under the back of the center console.
10) Zip tie the light to the same bar and cut any excess zip tie.
11) Now check all of your wiring and make sure it's well hidden. For the front driver's side light I used clear tape to the wire. You could see it on the bottom right of the picture.
12) Mount the control box anywhere you prefer that is easier for you to get to. I put mine next to the trunk/gas levers.
13) Now the wiring that goes to the battery (black/red wires) I just ran it through the fender and straight to the battery.
14) Now attach the negative and positive wires to the ring terminals.
15) First connect the positive (red wire) ring terminal to the positive terminal in the fuse box. Be careful not to touch the negative terminal on the battery with the wrench.
16) Do the same for the negative (black wire) terminal and connect it to the negative terminal on the battery.
17) Should look like this
18) Cover up the fuse box and put the key in the ignition to let the car restart itself. Start the car and let it run for 10 minutes or so.
19) Turn on your lights and enjoy!!!
Offline
Old Sep 5, 2008, 05:52 PM   #2
Personal Sales Rating: (1)
Jehuty's Avatar
Drives: Cali into the arms of S6
Send a message via AIM to Jehuty
Is there any way to connect this with your door? So that way when the door opens these lights will turn on also?
__________________
RAPTOR JESUS' ANGEL OF DEATH
WINNAR OF JEHUTY OF THE YEAR AWARD
Quote:
Originally Posted by 22stars View Post
i <3 Jehuty
Quote:
Originally Posted by mikesevo8 View Post
:walks in, looks around:
:grabs piece of chalk and writes "Jehuty>VincentX" on the wall:
:walks out:
Quote:
Originally Posted by Kurt View Post
Something is not right about you. I like that.
Quote:
Originally Posted by thetox View Post
shoot a load in her dumper or her belly will get plumper.
XBOX LIVE: TheMasterQweeph (XBOX live made me change my name....sigh)
Offline
Old Sep 5, 2008, 05:54 PM   #3
OZ Rally's Avatar
Quote:
Yes you just have to re-wire the wiring to the dome lights. That's the only way I can think of.
Offline
Old Sep 5, 2008, 07:04 PM   #4
Personal Sales Rating: (0)
hey, did you add a toggle on switch?
also whats the difference b/t the kit you purchased and the "expandable" ones?
like, what does expandable mean?
thanks
Oh yea, do you know if i get a multi color switch, will i be able to use it with a switch? (like pause it a color, and just use the switch to control on and off and never have to touch the control box)
Offline
Old Sep 5, 2008, 10:33 PM   #5
OZ Rally's Avatar
thanks
I didn't add a toggle on switch, the kit came with a control box that turns lights on/off and has different lighting settings.
I'm pretty sure the expandable ones just expand a little longer if needed.
If you get the kit then you wont need a multi-color switch. All the color variations will be on the control box that you can change whenever you want.
I personally think having a control box is better than a switch.
1) easier to mount
2) easier to have access to it
3) no need for drilling holes
4) a switch is a little dangerous because wires are left exposed and you can get hurt
Offline
Old Sep 5, 2008, 11:05 PM   #6
L.Lancer1's Avatar
Drives: 2008 E.B. Lancer ES
Send a message via AIM to L.Lancer1
johnny ur a mad man! im gunna have to have u helpe me do this when i get mine lol
__________________
Mods Done:
[x] painted front bumper
[x] Debadged rear
[x] engine cover painted
[x] hyperwhite lights
[x] custom apexi style exhaust
[x] valet car starter
[x] 12" kicker sub
[x] stock es rims painted bronze
On there way!literally being shipped
[ ] nokya h11 fog lights
[ ] angel eyes
mods soon:
-fujita sri with heatshield
-strut bar unsure which
-tein, rrm or works lowering springs
::CHI-BURBS LANCERS::
Offline
Old Sep 6, 2008, 11:10 AM   #7
OZ Rally's Avatar
Hahaha thanks man.
It was actually fairly easy. The hard part is having to open up the box and take out the lights.
Offline
Old Sep 6, 2008, 11:11 AM   #8
OZ Rally's Avatar
I think I'm going to re-wire the wires that run along the fender because I don't really like them showing. Another project for me to do
Offline
Old Sep 7, 2008, 05:55 PM   #9
sly
Personal Sales Rating: (7)
sly's Avatar
Drives: 03 silver OZ rally
Send a message via AIM to sly
good you know how to do this so you can help me, i set mine up but now the damn thing wont turn on i cant figure it out.
Offline
Old Sep 7, 2008, 06:53 PM   #10
OZ Rally's Avatar
Did you buy the kit or did you buy 4 separate tubes and hooked them up?
Offline
Old Sep 7, 2008, 07:43 PM   #11
Personal Sales Rating: (21)
ThunderOZ's Avatar
Drives: 02 Lancer OZ 16G TURBO
Send a message via AIM to ThunderOZ Send a message via Yahoo to ThunderOZ
looks like mine except I ran it through one of the holes in the firewall so the wires aren't visible
__________________
-Merc
Build thread on Mitsu-Media
Cardomain
Offline
Old Sep 7, 2008, 07:50 PM   #12
OZ Rally's Avatar
Quote:
Yea I wanted to do that too but I was in a hurry to install it. Now that I have time I'm too lazy to re-wire everything. lol
I'll probably do it tomorrow cuz I have some free time.
Hey did you cover up the wires so they won't melt from the heat or did you leave them exposed?
Offline
Old Sep 7, 2008, 07:53 PM   #13
ThunderOZ's Avatar
??? Your wires get that hot? Aren't they insulated?
__________________
-Merc
Cardomain
Offline
Old Sep 7, 2008, 07:59 PM   #14
OZ Rally's Avatar
You see the picture where I ran it through the fender then to the battery?
Well the part that covers the wire melted a couple of days ago and started to spark (scared the crap out of me!)
So I wrapped it all with electrical tape.
Offline
Old Sep 7, 2008, 08:14 PM   #15
ThunderOZ's Avatar
did you check your wires? what fuse are you using? that wire looks pretty thin too...
__________________
-Merc
Cardomain
Offline
Tags
2002, box, drivers, firewall, fuse, hooking, install, interior, kit, lancer, light, lighting, lights, side, wire, wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
