Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 10, 2008, 06:28 PM   #1
Personal Sales Rating: (5)
toolmanblink182's Avatar
Drives: 2004 Mitsubishi Lancer ES
Send a message via AIM to toolmanblink182
How to: Change Belts and/or Crank Pulley for 04+ ES
I have been checking this site for answers for forever, but I finally figured it out.
To change the belts:
3/8" or 1/2" drive Socket Wrench
12mm socket
14mm socket
14mm box-end wrench
Open the hood.
There are two bolts that you are mainly going to be concerned with. There may be three others that cause trouble, but they may not.
Start first by loosening the serpentine belts by loosening (counter clock-wise) this bolt with the 14mm socket:
You should see the belts start to loosen around the AC and Water pumps. If not, then you will need to use the 14mm box-end wrench to loosen this bolt that is located under the AC pulley:
After that, your belt should just fall off. Now its on to the Alternator belt. Start by loosening this bolt that is located to the rear of the engine bay with a 12mm socket:
If it doesn't come off easily, you may need to loosen 2 more bolts.
There is a bolt right next to the one you are at that might need to be loosened:
Loosen it using the 12mm socket.
If you are still having problems, hop under the car and look up at your Alternator, you should see this:
Your belts should fall right off and you'll be able to change them! Put the new ones on and tighten EVERYTHING up back to the way it was.
__________________
Current Mods:
[x] Injen CAI
[x] Lightweight Crank Pulley
[x] RRM Piggyback
[x] eBay Black Projectors
[x] Mesh Grille
[x] Blue LED Interior Lighting
[x] Blue Vinyl Interior
[x] Lightrikz Gauge kit
[x] TSX Projectors
[ ] 20% Tint
[ ] Smoke Headlights & Taillights
[ ] RRM Front Strut Bar
[ ] RRM Rear Strut Bar
[ ] RRM Header
XBox Live: Tim2LMan
Offline
Old Jul 10, 2008, 06:41 PM   #2
To change the Crank Pulley, you will need:
Everything from above plus:
12" breaker bar
22mm socket
Jack stand
Straight blade screw driver
A good friend
Start at the point where all your belts are off.
Take off your front passenger tire and remove the Wheel well lining by popping the clips with your straight blade:
You will see the Crank pulley right there. The easiest way that I found to remove it was to put the breaker bar on the bolt and place the handle on the frame:
From here, get your friend to get in the driver's seat while you hold the breaker bar. Have him turn the key and jump the car, DO NOT START IT. You can ensure that the car won't start by unplugging the spark plugs. Doing this will turn the crank forward and keep the bolt still, essentially loosening it.
Take off the bolt and give the Crank pulley a tug and it should come right off.
Replace it with your new spiffy Lightweight Crank pulley:
Put the bolt back on and tighten it with the breaker bar. If it spins, have your friend put the car in 5th gear and push as hard as he can on the brakes. This will prevent the pulley from spinning and give you the umph to tighten it up.
Put your belts back on and your wheel well on and that's it!!!!!!
If you have any questions about the install, feel free to PM me!
P.S. Yes I know the pics are sideways, not sure how to fix it. Tilt your head to the left?
__________________
Current Mods:
[x] Injen CAI
[x] RRM Piggyback
[x] Mesh Grille
[x] TSX Projectors
[ ] 20% Tint
[ ] RRM Header
XBox Live: Tim2LMan
Offline
Old Jul 10, 2008, 06:54 PM   #3
What do you guys think? Sticky-worth?
__________________
Current Mods:
[x] Injen CAI
[x] RRM Piggyback
[x] Mesh Grille
[x] TSX Projectors
[ ] 20% Tint
[ ] RRM Header
XBox Live: Tim2LMan
Offline
Old Jul 10, 2008, 11:11 PM   #4
Personal Sales Rating: (0)
1lancer's Avatar
Drives: 06 lancer...
very nice write up.....now all i need is the pulley......lol
Offline
Old Jul 11, 2008, 01:13 AM   #5
Yeah, the Ralliarts have a different setup and require different stuff. Just figured I'd write up my experience for all you guys with 4G94 engines. Also, it works wonders! I notice a big difference! I recommend this to all of you! This was first ever engine mod (besides the intake, but come on)!
__________________
Current Mods:
[x] Injen CAI
[x] RRM Piggyback
[x] Mesh Grille
[x] TSX Projectors
[ ] 20% Tint
[ ] RRM Header
XBox Live: Tim2LMan
Offline
Old Jul 11, 2008, 05:57 AM   #6
Personal Sales Rating: (11)
lancer2show's Avatar
Drives: 2005 Lancer ES/ 92 Talon TSI AWD
nice write up man.
__________________
LAST PIX OF MY 05 turbo lancer:
http://forums.evolutionm.net/lancer-show-shine/341242-my-last-pix-my-05-turbo-lancer.html
16G TURBO POWERED BY ROAD///RACE
Offline
Old Jul 11, 2008, 01:22 PM   #7
Why thank you! Hows it going? ^^^^
__________________
Current Mods:
[x] Injen CAI
[x] RRM Piggyback
[x] Mesh Grille
[x] TSX Projectors
[ ] 20% Tint
[ ] RRM Header
XBox Live: Tim2LMan
Offline
Old Jul 11, 2008, 02:42 PM   #8
pretty good man, you? i see your car is moving a long nicely..haha
__________________
http://forums.evolutionm.net/showthread.php?t=341242
Offline
Old Jul 11, 2008, 05:41 PM   #9
Yes it is. I am getting an Injen CAI and RRM Piggyback ECU on July 14th. That's when DHL will deliver them. My next write-up will be my Piggyback ECU install, I already posted instructions, but when I get it and put it on, I'll post pics. I may post a how to on the CAI, but there are plenty of those...
Anything I can do to help the community!
__________________
Current Mods:
[x] Injen CAI
[x] RRM Piggyback
[x] Mesh Grille
[x] TSX Projectors
[ ] 20% Tint
[ ] RRM Header
XBox Live: Tim2LMan
Offline
Old Jul 18, 2008, 09:43 AM   #10
Personal Sales Rating: (2)
*Zero*'s Avatar
Drives: 06 Lancer Es
nice write up bro...im gonna install my RRM one here in a week or two....
__________________
Why spend money to make your car look stock? JDM is over rated anyways...
i Trader vouch
http://www.azht.net/forum/member.php?u=2076
Offline
Old Aug 22, 2008, 03:18 PM   #11
Drives: Lancer ES
awesome write up. You might want to include the torque for each nut & bolt.
Offline
Old Aug 23, 2008, 02:30 AM   #12
doctorjon's Avatar
Drives: TurboCharged Mitsubishi Lancer OZ-Rally
Pretty nice write-up. So is it a big difference? Does it eat a lot of gas?
__________________
pushing the limits of my stock 4g94 (turbo'd)
Offline
Old Dec 14, 2008, 06:59 AM   #13
isn't cranking while you have the breaker bar scary? i can't imagine it mate
Offline
Old Jan 10, 2009, 10:28 PM   #14
deftones1868's Avatar
Drives: 03 lancer OZ
Send a message via AIM to deftones1868
nevermind.
Offline
Old Apr 25, 2009, 11:45 PM   #15
12" breaker bar
22mm socket
Jack stand
A good friend
do you have to have all the belts off the pulley(s)?
when i do my 99 civic si...the Crank Pulley still moves..
help me plzzzz...i put a metal stick to stop the power steering pulley..
but the crank pulley still move..plz help.!!
Offline
Tags
20, 2002, 2004, alternator, belt, car, change, crank, es, lancer, mitsubishi, pulley, replace, threads, trouble
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
