Oct 12, 2007, 07:43 AM
Personal Sales Rating: ( 88)
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
Quote:
Originally Posted by Hydrolikz
What kind of bulbs do you guys recommend for the headlights? Are the Sylyania bulbs the best?
"Best" is mostly an opinion thing. There isn't really a brand known to be the best.
Sylvania are generally good bulbs. I used their Silverstar line for a while and was pretty happy.
Hella bulbs are available through TireRack. I used those last time and was pretty happy.
PIAA are also available at TireRack. They're pretty high-end cost-wise, and they have a great reputation.
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Oct 12, 2007, 12:41 PM
Personal Sales Rating: ( 0)
Drives: Skyline/Evo/Genesis...?
I just want to get the brightest ones next to HID's
Offline
Oct 13, 2007, 08:09 AM
Just remember to stick to the stock wattage. Some folks buy a higher watt bulb and melt the harness.
I've used all three of the ones I mentioned. I was personally happiest with the PIAA Extreme White bulbs, but everyone's opinion differs.
__________________
Modern Warfare 2
Offline
Oct 14, 2007, 09:11 PM
Drives: 08 Lancer GTS Graphite
Does anyone know the bulb that it is the dome lights? How do you take off the cover and what is the bulb number on a blue led for replacement? What do I need to know when buying the replacement?
__________________
Bleeding Green
2008 Lancer GTS Graphite Grey 5 Speed
[X] RRM Intake-sound great
[X] Custom Axelback Exhaust w/ polished stainless tip
[X] RRM Pulley-a must have
[X] Painted Blue Engine/Spark Plug Cover-I hate it
[X] MIVEC and RRM Decals
[X] Eagles mini helmet hanging on mirror***GO PHILLY!!!**
[ ] Painted Charcoal Calipers
[ ] RRM Strut Bar and Rear Sway Bar
Offline
Oct 23, 2007, 01:21 PM
Drives: 2008 Lancer gts Electric Blue
Quote:
Originally Posted by Jake26
mods move this to appropriate section if this one is not!
Front of car:
Front turn signal light: 21watts bulb: WY21W
Head light, high beam: 60watts bulb: 9005 HB3
Head light, low beam: (halogen bulb) 51watts bulb: 9006 HB4
front foglight: 55watts bulb: H11
Front side marker and parking light: 5watts bulb: 168/194
Side turn signal light: 5watts bulb: 168/194
REAR of car:
High mounted stop light: Led
License plate: 5watts bulb: 168/194
back up light: 21watts bulb: 7440
tail light: 5watts bulb: W5W
tail and stop light: 21/5watts bulb 7443
rear turn signal: 21watts bulb: 7440
rear sidemarker: 5watts bulb: W5W
INSIDE CAR
trunk area: 5watts bulb:----- 3022
dome light: 8watts bulb:----- 3022
Please update the first post with the revised quote above thanks
To remove dome lights take a something really thin and strong like a knife or flat head and just pry it off extremly gently, its very easy to remove.
And trunk and dome lights use 3022 Bulbs. I currently have blue led blubs on the dome lights and in the trunk. I will be installing side turn lights next which use 168/194Bulbs. glad to help
Offline
Oct 24, 2007, 11:36 AM
Done.
__________________
Modern Warfare 2
Offline
Oct 24, 2007, 03:27 PM
Thanks
i will try to post some pics up soon of my beautifull interior and trunk, im waiting to move into my new apt which has a garage  that is when i will be doing all of my led work
Offline
Oct 26, 2007, 06:52 PM
Personal Sales Rating: ( 6)
2008 Mitsubishi Lancer
Drives: Boosted 2008 Mitsubishi Lancer
Quote:
Originally Posted by Mr. Brightside
Has anyone considered sticking the side turn signal assembly (the signal closest to the doors) in the oven and baking it like you would with the headlight assembly? Only thing is that you would be baking it with a bulb inside but I don't think that would make a difference.
Also, has anyone replaced the dome and trunk bulbs with LEDs or any other differently colored bulb? If so, what are the specifications (socket type, etc) besides wattage, which is listed already.
Thanks in advance.
I put a green 12" neon in my trunk. just hook up positive wire to positive on the trunk bulb wires, and negative to negative. what i did is just cut the wires and spliced in the new one and left the bulb and plastic cover on there so i don't have any small, loose parts around my garage.
Offline
Oct 29, 2007, 09:31 PM
Drives: 2008 lancer gts
tunerzimage.com has these bulbs called halo there 55w and 7200k which is like a light blue it supposed to be h.i.d color n its pretty damn close i have them n love them n they were only 40 buks
Offline
Jan 9, 2008, 05:27 PM
Hey, do you guys think these would be ok for my low beams cuz they draw 55 watts and stock is 51 watts. Will a 4 watts make a huge difference and melt my wires?
http://www.tunerzimage.com/Halo-Purp...-p/pr906b3.htm
__________________
Bleeding Green
Offline
Jan 9, 2008, 06:15 PM
Drives: 2008 Lancer GTS, S&S, CVT; 2007 Outlander LS
Does anyone know if Sylvania makes an H11 Silverstar/Ultra? Everytime I see the front of my car it drives me nuts - nice white headlights, crappy yellow fogs...
__________________
Tarmac Black Pearl
35%/18% Tint
Debadged Trunk
Perrin 4" Antenna
RRM Pulley
Sylvania Silverstar Ultra headlights
GReddy Ti-C Exhaust
Fujita SRI - with custom mounting bracket and MAF mount
RRM Header
Sparco Speed shift knob
Offline
Jan 9, 2008, 10:02 PM
Quote:
Originally Posted by Eagles GTS
I am wondering the same too, could someone please enlighten us?
Thanks!
Offline
Jan 13, 2008, 08:09 PM
Drives: Lancer GTS 08
i talked to a guy from autozone and he said the watts make all the difference and stopped me from buying some 55w bulbs.
Offline
Jan 31, 2008, 07:47 PM
Drives: 2008 Lancer
Is the dome light the same bulb as the map light?
How many lights are in the trunk?
Also, we have a light where the ash tray is, what's the bulb for that? is that easy to change?
Offline
Feb 1, 2008, 10:06 AM
Dome light and map light should be the same thing, as far as I know.
One light in the trunk.
Not sure on the ash tray one... I don't see it on the bulb list from the owner's manual...
__________________
Modern Warfare 2
Offline
Tags
08, 2008, 2009, bulb, bulbs, headlight, lancer, license, light, lights, list, plate, removing, tail, taillight  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
