Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Closed Thread
Old Apr 3, 2007, 09:14 PM   #1
Personal Sales Rating: (2)
lucentex's Avatar
Drives: 2009 Lancer ES
Send a message via AIM to lucentex
Side Turn Signal Always On (Adding LED)
This is a how to on making your Side markers run continuously by adding an LED. Here is a picture of the finished product.
What you will need
2) 12v Ready LEDS 8MM or less in size
Some footage of positive wire
1) 1/8 inch drill bit (Whatever Size Really, Just Small)
4) Wire Splices, get some extra they sometime don’t work all the time
Offline
Old Apr 3, 2007, 09:16 PM   #2
lucentex's Avatar
Step 1 Remove Side Markers Instead of that tool you could use a credit card or something like that.
Offline
Old Apr 3, 2007, 09:18 PM   #3
lucentex's Avatar
Step 2 After disconnecting the side light, bring it to a safe location and drill a small hole in the opposite side to the clip that holds the led in place. See Below.
Offline
Old Apr 3, 2007, 09:23 PM   #4
lucentex's Avatar
Step 3 Run wires though hole and pull fast, I recommend putting a little rubber cement on the outside of the led where the wire and hole are to be sure the wire won’t move and to seal the hole. You can test your 12v led with a 9v battery.
I’m like a freaking surgeon, oh yea.
Here is the what it should look like
Offline
Old Apr 3, 2007, 09:25 PM   #5
lucentex's Avatar
Step 4 Attach some wire to the positive side of the side marker led and attach it to the light green wire coming out of the light shown with splice. Attach the 12- (Black Wire) to the black wire coming out of the side light harness with another splice.
Step 5 Check Application and replace side marker.
Offline
Old Apr 3, 2007, 09:28 PM   #6
lucentex's Avatar
Tips: You can attached LED Lead Wire To 12+ running wire by soldering. You may need to remove the two lights on the corner of the headlight to really get to your work to splice the 12+ to the Green wire.
Pic With Turn Signal Flash On which will actuate between this pic and the lower pic
Pic With Turn Signal Off Or Intermittent Off While blinker on.
Offline
Closed Thread
Tags
2009, adding, change, flash, how, install, lancer, led, light, marker, side, signal, signals, splice, turn
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
