start with taping around the stock headlight beams.. this will be for alignment of the new headlights.. then simply remove the 3 screws.. they are very obvious.. the headlight should still feel snug.. reach in behind the headlight bulb and push straight forward and out.. DO NOT ATTEMPT TO PULL OUT BEFORE THIS POINT..
it should become loose.. now the hard part is finding a angle for the headlights to come out.. they should be stuck between the bumper and the point of the fender.. GOOD LUCK.. this takes about 30 minutes tops..
Discuss this thread
here.
