Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer How Tos / Installations > Lancer How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 11, 2003, 09:14 AM   #1
Personal Sales Rating: (20)
livelyjay's Avatar
Drives: '03 Mazdaspeed Protege
How-To Request: Oil Pressure Gauge
I'd like a full how-to write up on an oil pressure gauge. I'm sure some of you out there have done one, and I'd like to know where exactly to install the sending unit. Also, is there a way to keep the stock pressure sensor so the light in the cabin doesn't go on?
Offline
Old Nov 11, 2003, 06:30 PM   #2
Moderator
Bomb Squad Unit #02
Personal Sales Rating: (14)
urbanknight's Avatar
Drives: a bicycle
I would like such a write-up as well. I am thinking of putting an pil pressure guage on a steering column pod. Also trying to decide on digital or mechanical. Any help would be great.
__________________
- Brian
Offline
Old Nov 11, 2003, 08:23 PM   #3
Personal Sales Rating: (1)
4Gaijin63's Avatar
Drives: 02 CS6A, 88 FC3S
Send a message via AIM to 4Gaijin63
why would you need an oil pressure gauge at the center of your attention? im just curious as to your particular style of driving. oh wait, an autoxer, question answered, everything explained. Kinda makes this post pointless. Well that makes number 3.
__________________
First Lancer Purchased in Sarasota, FL: 10/31/01
私の車に当ってはいけない!
Offline
Old Nov 11, 2003, 08:44 PM   #4
EvoM Administrator
Personal Sales Rating: (8)
HobieKopek's Avatar
Drives: A little red Neon. I also have a Lancer that presumably still rolls...but doesn't drive.
Send a message via AIM to HobieKopek
I think it's going to vary from brand of gauge to brand of gauge, because I don't think they all use the same pressure sensors and senders. If it doesn't have to be Lancer specific I'm sure you could find an answer with a bit of web searching.
__________________
Quote:
Originally Posted by Foggy View Post
I believe the bears are our future
Feed them well, and let them lead the way...
Quote:
Originally Posted by Raphael
Hi. As you can see I'm a bear. I contain no artificial flavors and no artificial colors. Now you may be thinking, "Oh, he's such a cute little bear," but let me tell you I am hard. Really hard. Deep down, I am still a bear. An animal born to raise hell. If I saw a dinosaur right now I'd rip his head off.
Sign up to win prizes by running web searches with Blingo. Powered by Yahoo!
Offline
Old Nov 15, 2003, 08:41 AM   #5
EvoM Moderator
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: '04 Ford Explorer XLT, '69 Chevrolet Camaro, '97 Honda Civic LX (beater)
Um, if it helps, I third the request for a write-up.
__________________
Now playing (online):
PlayStation Network - blacksheepdj
Modern Warfare 2
Xbox Live - DJ zero 1980
Modern Warfare 2 - Not much else until I renew my Gold status
** If you have an extra 48-hour XBL code, I'd love to use it.**
Offline
Old Nov 16, 2003, 09:08 AM   #6
Personal Sales Rating: (5)
JVlancer's Avatar
Drives: '02 Turbo Lancer
Send a message via AIM to JVlancer
uhm.. i just ordered my air/fuel gauges and also boost gauges i can do a write up on those if you would like
Offline
Old Nov 16, 2003, 05:33 PM   #7
Personal Sales Rating: (0)
TypeIII's Avatar
Drives: 4AGE AW11
Send a message via ICQ to TypeIII Send a message via AIM to TypeIII
This may or may not help, but I figured it's worth a shot...
In order to keep your factory oil level warning light/buzzer from going off, you will need to a) replace the factory sender with a "dual sender" or, b) use the aftermarket sender and kill the oil warning light/buzzer manually or, c) tap the aftermarket sender somewhere else in the block. The above options were listed from most desirable to least desirable (IMO).
Take my old GTi VR6, for example... VDO made an aftermarket oil pressure sender that would go in the place of the factory sender unit, but at the top of it, had two signal outputs. One would go to the factory wire, and the other one would go to the aftermarket VDO oil pressure gauge. I am not sure if such unit is available to you, what I would suggest you do is that you first take measurement of thread size as well as voltage of your factory unit. If there are companies out there that can find a unit that suits your application, then you're in luck.
I think the other two options are pretty self-explanatory, but I really wouldn't recommend the third option unless you're really that desperate to monitor your oil pressure.
Brian: I would just recommend an electrical unit. I don't really see the need for a mechanical gauge? The thought of running a line of steamy hot engine oil into the cockpit isn't exactly my idea of fun.
__________________
Chinese Redneck™
Offline
Old Nov 16, 2003, 05:42 PM   #8
Personal Sales Rating: (4)
Quickshift's Avatar
Drives: in circles
Send a message via ICQ to Quickshift Send a message via AIM to Quickshift
Easiest way to get oil pressure connected is through an oil filter block ( oil cooler block or oil sensor block) they connect to the engine between the oil filter and have spots to fit 1/8 pt connections I have a link for one somewhere , if I find it ill post it. I have a greddy oil pressure and oil temp gauges setup through it .
__________________
Atlantic Motorsports
www.amstuning.com
Washington DC's Premier Mitsubishi Evo Store & Garage
Visit us:
8001 Queenair Dr.
Gaithersburg, MD 20879
Call us!
Toll free 1888-AMS-1788
Local 301-869-7700
Official Sponsor of Evolutionm.net
Offline
Old Nov 17, 2003, 06:31 AM   #9
livelyjay's Avatar
JVlancer: That would be cool if you could do a write up because I plan on doing more gauge installs and I am sure other people will be doing them as well.
urbanknight: If you want the gauge in the cabin, you're going to have to use an electrical gauge because a mechanical gauge will have oil right behind the gauge itself. It wouldn't be pretty if that thing broke and sprayed you with 200 degree oil.
Quickshift: I'm a little confused about what you're talking about. Do you mean there is a sender unit that screws in where the oil filter goes, and then the oil filter screws into the other side of it?
After everyones comments I think I'm going to call up or email the gauge companies and see what they have to say. Any suggestions on gauge manufacturers? I already know of Autometer, Greddy, Blitz, and Defi. I haven't seen much on Defi pricing, but it looks expensive to me.
Offline
Old Nov 18, 2003, 07:00 PM   #10
Personal Sales Rating: (9)
nastea's Avatar
Drives: Rally Red Evolution VIII, 2003 Outlander XLS AWD
anyone ever do this?
__________________
DC Metro Evolution Club
www.dcevoclub.com
DC, Maryland and Virginia's Lancer/Evolution Club
Offline
Old Nov 19, 2003, 04:12 PM   #11
jason33hs's Avatar
Drives: 2002 OZ Rally Lancer, 2000 Honda CR-V
Send a message via AIM to jason33hs
Mechanical guages typically have a larger sweep compared to electric ones. Autometers have I believe 270 degrees of sweep while most electric have maybe 130. It depends on the manufacturer.
The state of the art mechanical gauges use a capillary between the source and teh gauge. So the oil is isolated from the gauge while still retaining the best of the mechanical gauge wide range of readings. For street aps, I know a lot of people use copper fittings (think T) and put the T into the block, the factory sensor into one opening, and the new sending unit into the other. Pressure is pressure, so it doesn't matter in the orientation.
I would also like to see someone's installation/solution to this.
Jason
Offline
Old Nov 23, 2003, 10:22 PM   #12
hardcoretuner's Avatar
Drives: 2002 OZ LANCER
Send a message via AIM to hardcoretuner
i have an aem fpr that goes on a 94 honda civic and a guage would b great, the shop around here odes install for it for 100 bucks and i have yet to need anything installed for me and don't plan to anytime so a compleat writeup on a particular guage would b great, just pick a guage thats best for the buck if you need a specific one
__________________
honda's are like belly-buttons everyone has one
Current power and suspension mods:
RMR - Intake
RRM - Throttle Body, Header, Strut Bar, and Progress Springs
Apexi - N1 Exhaust
Greddy - Emanage w/ Injection and Ignition harnesses
RPW - Stage 2 cam and valve springs
Past mods that I lost lots of $$ on...
RRM piggy back, RPW stage 1 cam, safc-II
Offline
Old Nov 24, 2003, 01:58 PM   #13
EvoM Administrator
HobieKopek's Avatar
To solve the oil lines past the firewall thing...Defi Link. The sender unit = brilliant. My gauges should be arriving today. Depending upon how much down time I'm going to have and the apparently difficulty of wiring the fuel pressure gauge I may or may not do write ups. Depends whether or not I end up doing it all myself. If/when there's progress I'll be sure to share.
__________________
Offline
Old Nov 24, 2003, 02:01 PM   #14
Sailorgoon's Avatar
Drives: '02 OZ - Sold - 2005 Focus ZX3 SES
Send a message via AIM to Sailorgoon
Quote:
Lookin' forward to it.
__________________
Gone a long time, but now I'm back.
Stupid post wh0res and b1tche5 beware...I'm coming to berate you.
Offline
Old Nov 24, 2003, 03:32 PM   #15
Moderator
Bomb Squad Unit #02
Drives: a bicycle
Well my main reason was to keep track of oil pressure during canyon runs and track days, but it seems that my Lancer loses almost no oil even after 2 days (about 4 hours of seat time) at a race track. Which is good compared to my dad's shelby, which uses up about 2 quarts per 20 min session. Maybe I will be fine with the standard warning light and just know to shut down if I see it light up?
__________________
- Brian
Offline
Tags
4age, alternative, oil, pressure, sender
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
