Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer How Tos / Installations > Lancer How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 24, 2003, 07:30 PM   #16
Personal Sales Rating: (0)
Drives: Silver EVO VIII
When I changed my oil the other day, I noticed a hex plug in the filter block. Can this be tapped for oil pressure?
Offline
Old Nov 25, 2003, 12:03 PM   #17
Personal Sales Rating: (1)
airlinevomitbag's Avatar
Drives: '07 Ranger/ '01 Aprilia Falco '03 Taurus No Mitsu :(
Send a message via AIM to airlinevomitbag Send a message via Yahoo to airlinevomitbag
Quote:
Good catch dude! You are the only person other than me who has mentioned that plug on the boards. Although I used that hex pluged hole for my turbo oil feed there is no reason it cant be used to feed a sender for an oil pressure gauge. Better than using a T.
__________________
Thats impossible, Rhonda! How can you sleep when you're high on crack!?
Offline
Old Apr 20, 2006, 02:19 PM   #18
Personal Sales Rating: (4)
Danno's Avatar
Drives: F150
Bump, I am doing this this tonight, anyone know what the metric thread is that I need.
__________________
Quote:
Originally Posted by Import Junky View Post
Don't bother asking for help in the OT. Most of these guys won't help you and decide to speak in their own gay internet language. If a word doesn't look right or doesn't make sense just look at the poster, I'm sure they spend most of their time here. Sad and Lame but whatever floats their boats.
Dating Tips
Shaving Tips
Don't Swallow Gum
Candy Nightmare
Know Your Women
Drunkin Pain
Girlfriends For Dummies
Offline
Old Apr 21, 2006, 01:04 AM   #19
Personal Sales Rating: (19)
sykou's Avatar
Drives: 2003 Lancer OZ Rally
i have the plug that you take out. But i don't know how to measure the thread...If you tell me how i can measure it and i'll let you know...I also installed my oil pressure gauge a few gays ago and i used a oil gauge install kit and a bracket i made to mount the sender on the fire wall...lemme know i can do a write up if you need.
Offline
Old Apr 21, 2006, 05:54 AM   #20
Danno's Avatar
Drives: F150
Okay, I figured it all out, I will write up a "How-To" today. (sorry No pictures)
You need to buy the metric adapters.
__________________
Dating Tips
Shaving Tips
Don't Swallow Gum
Candy Nightmare
Know Your Women
Drunkin Pain
Offline
Old Apr 21, 2006, 10:21 AM   #21
Danno's Avatar
Drives: F150
Here Is The How Too!
I installed 3 Guages, a Volt meter, an Air/Fuel Meter, and an Oilpressure guage. I used all Auto Meter Ultra Lite Gauges.
Disconnect the battery and lift the front of the car and properly put it on jack stands for safety.
I briged my positive connections and my grounds from all three gauges so that I would only have to run 1 power and 1 ground wire to the car. (Including the lights)
I used the 12 volt wire for my cigerette lighter as my power source, I hardly ever use my cigerette lighter anyways. Thus Finishing all the wiring for my Volt meter.
I ran the purple wire off of the air fuel gauge (sending wire) to the blue wire on the O2 sensor at the exhaust maniflod. I Cut the Blue O2 Sensor wire and wired in the sending wire from the A/F gauge to it, then reattached everything using crimp connectors and then taping it to keep moisture out. Now the A/f Gauge is done.
Then I went under the car and disconnected the dummy sensor for the oil pressure by unscrewing the philips screw, taking out the wire and then unscrewing the stock sending unit. I didnt have a wrench the right size so I had to use an adjustable. Then inserted the 1/8-NPT to 1/8-BSPT adapter into where the stock sending unit screwed into using pipe dope. Tefflon tape works too but I wanted the added security. (Used on all of the fittings but not mentioned from here forward)
Next I attached the 1/8-NPT "T" fitting to the adapter. On one end I installed the stock sending unit to the "T" this time using a 1/8-BSPT to 1/8-NPT adapter and on the other end I installed the Auto Meter Oil Press. sending unit. Then I Tightened my fittings, re-attached the stock sending unit wire and fed my sending unit wire and attached it to both the sending unit and the guage for the oil pressure meter.
YEAH!!!! now its done and you know what all the sizes are.
-Danno
**Note**
The adapters were a pain to find. I was able to get One of them from a local Autometer dealer but they Charged me $20.00 CDN for it . I had to make a bunch of calls to industrial suppliers to get the other fitting.
I returned the AutoMeter ripoff priced fitting to the speed shop and got all of my fittings including the "T" from a near-by supplier for $20.00 total.
**IMPORTANT NOTE**
A 1/8-BSPT male end will fit into a 1/8-NPT but it WILL NOT BE SECURE, do not do this!!! Do it properly with the correct fittings
**Other Notes**
You will have some oil come out when you stak eout the stock sending unit so have a catch tray below in preperation for this. Its a good idea to have an extra quorte of oil to top up any lost fluids.
__________________
Dating Tips
Shaving Tips
Don't Swallow Gum
Candy Nightmare
Know Your Women
Drunkin Pain
Offline
Old Apr 21, 2006, 10:47 AM   #22
Personal Sales Rating: (23)
Wallesasuaz's Avatar
Drives: to get Beer!
Send a message via AIM to Wallesasuaz Send a message via MSN to Wallesasuaz Send a message via Yahoo to Wallesasuaz
Good Write-UP!
__________________
- David
- Mr. Suaz ( NY 5 Boros. Capt. )
TSE
-Domo-Elite MASTER
Offline
Old Apr 22, 2006, 11:41 PM   #23
sykou's Avatar
i thought i read something about the sender not working properly if you used a T fitting with the stock sensor...but i guess it does huh.. nice write up....
Offline
Old Apr 24, 2006, 07:55 AM   #24
Danno's Avatar
Drives: F150
I don't see why it would be a problem, it works off of pressure.
__________________
Dating Tips
Shaving Tips
Don't Swallow Gum
Candy Nightmare
Know Your Women
Drunkin Pain
Offline
Old Jun 5, 2006, 07:40 AM   #25
Personal Sales Rating: (111)
Z_Lancer_Man's Avatar
Drives: 06 WW EVO IX w/ SSL
Send a message via AIM to Z_Lancer_Man
Danno -
I'm currently using a 1/8" BSP - 1/8" NPT fitting for my sender and its leaking oil. I am just using teflon tape. What is pipe dope? Would it okay to use like Silicone Gasket Maker stuff on it?
__________________
AMS 3" TBE w/ TP |GFB BOV | AMS UICP | Muse LICP | Walbro 255 Fuel Pump | Mini Battery | Amsoil air filter w/ Vibrant MAF adapter | Custom Boost Pill (#58) | Omni Power 4-Bar MAP Sensor | Powerslot Slotted Cryo Rotors | Swift Springs | MIL.SPEC TB Shaft Seals
325/310 WHP/TQ (VDR 5.7) - 24 PSI, 91 Pump - Self Tuned w/ECUFlash
Previous Lancers
- '09 Lancer GTS (traded 6/19/09)
- '03 Lancer OZ Rally (traded 1/18/09)
Offline
Old Nov 3, 2006, 10:29 AM   #26
SnapDragun's Avatar
Drives: 2003 Mitsubishi Lancer Oz Rally Edt.
Send a message via AIM to SnapDragun Send a message via Yahoo to SnapDragun
Nice right up and I'll post pics of my install when I do them this weekend
__________________
Quote:
...WHOA slow down man it's raining........Thats not rain man, that is God drooling cuz he's so impressed with my awesome driving...
T.D.L.R
Team Draguns Lair Racing
10 Seconds Is All I Need To Make You Bleed The Green Seed
WTB: EVO Front Seats - PM Offers
Offline
Old Feb 18, 2007, 04:01 PM   #27
customlancer's Avatar
Drives: 2002 Lancer
(I have 02 lancer, road race headers)i installed a air fuel ratio gauge and it works but its not giving me a correct reading. It jumps from rich to lean and back all the time. Even at idol. I have it hooked up to the o2 sensor in the header. Is it a bad o2 sensor? Would moving it to the o2 sensor in the cat fix this?
Offline
Old Feb 19, 2007, 08:46 AM   #28
Personal Sales Rating: (2)
DemisedGabe's Avatar
Send a message via AIM to DemisedGabe
could be connected wrong?
__________________
myspace.com/demisedgabe5
Items for sale:
Stock Cam
Stock Fuel Rail
Tama 5 x 14 Snare drum
Stock Intake Manifold
stock grill
Offline
Old Feb 19, 2007, 09:25 AM   #29
So you are reading your narrow band signal, right. Was the gauge designed to read off one of the stock o2 sensors? I know with almost all after market widebands, you want the o2 sensor further away.
__________________
Previous Lancers
Offline
Old Dec 5, 2007, 07:21 PM   #30
Personal Sales Rating: (16)
yellance's Avatar
Drives: 2002 yel lancer oz rally
Send a message via AIM to yellance Send a message via Yahoo to yellance
is there a pic of the dummy oil sensor thanks
__________________
Quote:
Originally Posted by HobieKopek View Post
BTW, if you minored in possession, what did you major in?
Offline
Tags
4age, alternative, oil, pressure, sender
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
