Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer How Tos / Installations > Lancer How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 24, 2009, 05:44 PM   #1
Personal Sales Rating: (0)
2009 Mitsubishi Lancer
kmc8302's Avatar
Drives: 2009 Lancer GTS
Megan Racing Gauges
Just got megan racing gauges air/fuel, volts, oil press, oil temp and vacuum. Anyone install any of these yet and can spread some light onto how i do it, just trying to make it simpler and faster if possible, otherwise ill have to go exploring and figure it myself which will take longer than if someone has first hand experience! thanks in advancee. I really only need to figure out the oil press, temp and vacuum ones. The air/fuel and volts i can do easy.
__________________
[x]Greddy TI-C
[x]Fujita SRI
[x]Greddy Emanage Ultimate
[x]Kenwood Custom System
[x]Eibach Sportline Springs
[]Megan Racing Seats
[]Megan Racing Coilovers
[]Enkei RPF1
[]5% tint
[/]Turbo Install (wip)
Offline
Old Oct 24, 2009, 05:58 PM   #2
Personal Sales Rating: (7)
2007 Subaru Impreza
ambystom01's Avatar
Drives: Robut bear cavalry to the bearpocalypse
Oil pressure- you can buy a sandwich plate that goes between the oil pan and the oil filter. Alternatively, you can tap the block.
Oil temp- same as above.
Vacuum- tap into a vacuum line coming from the intake manifold.
I'm guessing the A/F gauge is a narrowband?
__________________
This FAQ is a great starting point for new lancer owners
If you want my help, PM me, I won't post in technical forums lest I make waves.
Offline
Old Oct 24, 2009, 06:45 PM   #3
MasterAK's Avatar
Drives: 08 Lancer ES MT
What does the A/F gauge look like? Does it have an oxygen sensor attached to it? If it doesn't have it you might need to get a wideband oxygen sensor.
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Old Oct 24, 2009, 10:28 PM   #4
kmc8302's Avatar
well the oil pressure gauge came with a oil pressure sending unit, I already hooked up the a/f and vacuum so those are up and running well. Its just does the 09 gts have a oil pressure sending unit i can replace or do i have to tap into it.
__________________
[x]Greddy TI-C
[x]Fujita SRI
[]Enkei RPF1
[]5% tint
Offline
Old Nov 5, 2009, 07:02 PM   #5
notFSTenuff's Avatar
Drives: 09 lancer es
do you have any pictures? i was thinking about getting the same set up
Offline
Tags
gauge, install, megan, racing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
