Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer How Tos / Installations > Lancer How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 13, 2009, 09:01 PM   #1
Personal Sales Rating: (0)
notFSTenuff's Avatar
Drives: 09 lancer es
evo rims
just wondering would evo rims fit on a 09 lancer????
Offline
Old Oct 14, 2009, 12:48 AM   #2
2009 Mitsubishi Lancer
kmc8302's Avatar
Drives: 2009 Lancer GTS
which evo rims be more specific! and also learn how to search this info is already on evom.
evo x stock
GSR Enkei: 18x8.5 +38 ~22 pounds
MR BBS: 18x8.5 +38 ~19 pounds
Centerbore/hub size: 67.1mm
All 2008+ models
Lug pattern is 5x114.3
Lug nut thread/pitch - 12 x 1.5
Offset is 46mm.
Center hub is 67mm.
ES
Stock tire size is 205/60/16
Stock tire is Yokohama AVID S34B
Wheel is 16x6.5
IMO yes you could run evo x rims on your ES if you were to get tires with a sidewall of at most 45% i would run a 35% sidewall height on them im not sure of clearance on the ES but the 2 inches of extra width may affect clearance so you may have to roll your fenders but im about 80% sure it will be possible. Also another thing from upgrading 16" to 18" would be alignment and your speedometer will be off so you'll have to get those adjusted.
Offline
Old Oct 14, 2009, 06:39 AM   #3
MasterAK's Avatar
Drives: 08 Lancer ES MT
Quote:
Yes although you will probably need to roll the rear fenders. I've seen a thread here with pictures. However they're a little too big for a lancer. You might be better off with a different set of wheels.
__________________
2008 Electric Blue Lancer - 5 spd
☑ Works Rear Sway Bar
☑ HKS Drop-In Filter
☑ 17x8 Rota DPT / Falken FK-452
☑ Rally Armor Basic Mud Flaps
☑ 20% Tint
☑ DDM SlimLine 4500K HID with DRL defeat harness
☑ Fog Light Kit
Offline
Old Oct 15, 2009, 04:49 PM   #4
to roll you gotta like cut heat it up and pretty much roll it back right
Offline
Old Oct 15, 2009, 05:24 PM   #5
Personal Sales Rating: (7)
2007 Subaru Impreza
ambystom01's Avatar
Drives: Robut bear cavalry to the bearpocalypse
No, rolling involves a rolling machine that physically flattens the little protrusion on the inside of the fender.
__________________
This FAQ is a great starting point for new lancer owners
If you want my help, PM me, I won't post in technical forums lest I make waves.
Online
Old Oct 15, 2009, 05:51 PM   #6
oh dang. i remmeber seeing other ppl talking about doing it themselve so i was confused but thanks man.
Offline
Old Oct 15, 2009, 09:49 PM   #7
kmc8302's Avatar
Funny story about rolling fenders. My friend did his the "ghetto way" took an aluminum baseball bat, wedged it in between the fender and the tire (his old tires of course) pushed and rolled, then pulled and rolled. The problem he had was getting a consistent roll, they didn't look half bad i would definitely not recommend this to anyone lol. He was just lazy didn't want to pay a shop to do it nor buy/rent a roller. Don't take the cheap way out if you're going to roll!
Offline
Tags
2009, evo, fit, lancer, rims
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
