haha I found my own answer, but ill post it just incase anyone else would like to do the same:
Battery
RED/WHITE
Accessory
YELLOW
Ground
BLACK
Dimmer
GREEN/WHITE
Power Antenna
PINK
LF Speaker (+)
WHITE/BLUE
LF Speaker (-)
BLACK/YELLOW
RF Speaker (+)
WHITE/RED
RF Speaker (-)
BLACK/RED
LR Speaker (+)
YELLOW/BLUE
LR Speaker (-)
GRAY/BLUE
RR Speaker (+)
YELLOW/RED
RR Speaker (-)
GRAY/RED
What I did is took off the dash panel got to the wiring harness, took a razor blade and kind of ran it parallel with the wires at a small angle to stripped away the wire coat, then took speaker wire wrapped it around the spliced harness wire then electrical taped it together and connected it all to the SLC4 which has its own wiring diagram (i only did the front speakers so 4 wires) the slc4 fits perfectly mounted on top of the factory receiver, then i ran the line output rca connectors to the trunk and BAM ready to be hooked up to an amp
