Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer How Tos / Installations > Lancer How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 10, 2009, 11:23 AM   #1
Personal Sales Rating: (0)
Drives: Black 2008 Lancer GTS
LED DRLs
Just installed these on my lancer, and I wanted to know if there is a good adhesive to use. Since zip tie seems like easy to remove...
Offline
Old Sep 19, 2009, 11:31 AM   #2
Personal Sales Rating: (1)
2008 Mitsubishi Lancer
mrblondelv's Avatar
Drives: Lancer GTS 08, RX8 07, Eclipse 07
Send a message via MSN to mrblondelv Send a message via Yahoo to mrblondelv
Are these your DRL's now? and if so, how did you get teh DRL's to be these lights instead of the regular bulbs
__________________
VOTE FOR MY CAR //////////http://forums.evolutionm.net/garage....&vehicleid=422
Offline
Old Sep 19, 2009, 06:11 PM   #3
The socket for my actual low beams wasn't being used, because I went with a relay to the parking lights for my HID Low Beams, since the DRL current from the socket will mess up my HID ballast. So basically my corner lights switch also turns on my Low Beams.
Always planned on hooking up a set of foglights inside the grill, and using the unused low beam sockets as the power source. But I went this route, after seeing someone try something similar.
Offline
Old Sep 19, 2009, 06:23 PM   #4
Personal Sales Rating: (23)
yahu's Avatar
Drives: 06 Evo MR
3M double-stick is pretty good. Why not just go with some epoxy? I suppose you might want to remove them in the future.
Offline
Old Sep 20, 2009, 06:50 AM   #5
I was thinking of using silicone sealant. I'm in texas, and I've had some issues with 3m double sided tape in the past sliding off when stuck to plastic. Since the temps in the summer reach close to 105°F, not to mention my car is black.
Offline
Old Sep 20, 2009, 03:28 PM   #6
livefastdieslow's Avatar
Drives: 2008 Lancer GTS
Yeah some clear silicone should stand up to Texas weather, or some really small zip ties.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
