the mileage is hard-coded to the eprom inside the cluster to prevent odom fraud so you cant change it.. my oz cluster had 59,212 miles when i swapped the evo8 cluster that had the same exact mileage as my oz.. it took me over a year to find one that was just over what my oz had... so yeah my evo cluster mileage is a dead on match..
the only isue is the antilock light.. from what i gathered from the ra forums its a non-issue. its just an issue with the evo cluster & the lancer oz/ls/es computer.. workaround is just pull the antilock light bulb behind the cluster... did it to mine and the annoying light is gone.. my abs works just fine btw
my advise is find a evo cluster thats just over your current mileage around 2-3k miles over.. thats what i did..
