Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer How Tos / Installations > Lancer How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 11, 2009, 10:40 AM   #1
Personal Sales Rating: (0)
2008 Mitsubishi Lancer
Abdulrahman's Avatar
Drives: 2008 Mitsubishi Lancer EX GT
Unhappy please help me
hi
i have a 2008 lancer GT its the same as the GTS but with a 2.0L engine
the problem is that it doesn't have an alarm system and because it has a keyless entry and ignition system i didn't want to install an alarm system with a remote so i bought a system called crimestopper CS-883 ( http://www.crimestopper.com/2009/keylessentry/cs-883.oem.html ) it's an upgrade for factory keyless entry systems
i need your help for installing it
i've included some photos of the installation manual and highlighted the wires that i couldn't find (it's almost all the wires), i don't want to install the engine immobilizer
i know that the wires in my car might be different in color but if you can tell me how to find them and where
thanx
Offline
Old Jul 11, 2009, 10:42 AM   #2
photo of my car key
Offline
Old Jul 12, 2009, 09:23 AM   #3
Greedy_son's Avatar
Drives: 09 Lancer GT
^ Your car already comes with a factory alarm system. Under your radio do you have a LED that flashes when you lock your car? Its a very basic system but it will prevent people opening your doors etc when locked.
My advice if you arent fimilar with your car the alarm system and have the right tools, take it to a person who does.
You dont want to be cutting the wrong wires.
Offline
Old Jul 12, 2009, 11:06 AM   #4
the LED under the radio doesn't flash
and 2 months ago i woke up and found my car door open and the window smashed , so i think it doesn't have an alarm system
and i'm in the middle east and no one knows how to install it
thank you
Offline
Old Jul 12, 2009, 11:59 AM   #5
Greedy_son's Avatar
^ Ouch that blows. I cant see why yours wouldnt come with some sort of alarm even if basic. Maybe take it to the dealer if you cant find anyone to help.
Do you have a voltmeter? You will need one to find the +12V and negative wires.
Offline
Old Jul 12, 2009, 12:58 PM   #6
Thanks for replying greedy son
I went to Mitsubishi dealers in 3 different COUNTRIES and they all said that they don’t have the factory alarm and they can’t install aftermarket alarm systems
But the good news is that I’ve found the door lock/unlock wires, and the trunk is not that important the only thing left is the lock/unlock validation wires and I’m going to remove the door panel tomorrow and see if I can find them
But … I have a question
Is there any way to check the wires with the voltmeter without stripping part of the wire??
Thanks again
Offline
Old Jul 12, 2009, 02:19 PM   #7
Greedy_son's Avatar
^ Yes. Can you change the two leads (probes) on the voltmeter? if you can then you can get a lead the clamps down and bites into the wire. This prevents you from removing part of the insulation and all you are left with is a small hole. You can pick them up from any electronics store. These are also good when you dont have enough hands to hold the lead down on the wire or you are checking voltage changes.
http://www.switchfisher.com/navigati...all_xm_008.JPG
Offline
Old Jul 13, 2009, 11:13 AM   #8
thanks for the tip
today i removed the door panel but i couldn't find the lock/unlock switch wires (validation wires)
any idea where can i find them
thanks
Offline
Tags
crimestopper, cs883
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
