Jul 1, 2009, 04:43 AM
Personal Sales Rating: ( 0)
Drives: 2009 Octane Blue Lancer GTS 5 speed
i am getting crappy gas mileage :/
hey i'm new to these forums but i was just wondering what kind of gas mileage you guys are getting in the 09 gts?
I can never manage to get better than 19 mpg in the city and i have the 5 speed manual
Offline
Jul 1, 2009, 05:02 AM
Personal Sales Rating: ( 2)
Drives: 09' Civic SI, Evo X, Mustang
How many miles are on your car? It may still be breaking in.
Also your gas mileage more often time depends directly on how you drive. Try babying it for a tank and see if you don't get better results.
Offline
Jul 1, 2009, 05:44 AM
Personal Sales Rating: ( 1)
Drives: 2008 Grey Lancer GTS (5spd)
if you want better gas mileage you need to slow down. If you take your highway speed down to 60, you can def get 33-35 mpg on the highway. As for the streets, like cornercarver said, you need to baby it.
__________________
HID Lo/Hi/Fog
RRM SRI V2
RRM TCM
Works Short Shifter
Megan Coilovers...if interested in the stock GTS suspension, pm me.
Offline
Jul 1, 2009, 05:29 PM
Drives: 09 Lancer GT
Got any aftermarket parts on? Like Rims etc. They can add weight and cause some difference in mileage.
Offline
Jul 1, 2009, 05:34 PM
Personal Sales Rating: ( 11)
2002 Mitsubishi Lancer
Drives: Lancer
Also change speed at around 2500-2700 Rpm . Helps out alot .
Offline
Jul 1, 2009, 05:38 PM
Drives: 2003 LY OZ rally *RRM Turbo'd / ex- 99 Ford Ranger
since u got a 5 speed.. u wanna use the highest gear 'possible'.
low gears with higher rev's will just cut into gas mileage.
Offline
Jul 1, 2009, 07:11 PM
Drives: 09' Ralliart
The GTS is rated for 21/28.
19 sounds about right for the city for a spirited drive.
My RA is rated for 17/25 and in stop and go traffic, I get ~15. When things are flowing, I hit 17-18 driving like grandma, keeping it off boost. On the highway, solid highway, 65 cruise control, about 24-25.
If I boost a lot, I get 12-14mpg, on premium...
Online
yeah i have 1400 miles on it and i don't have any aftermarket...
how long before i start to see more normal gas mileage?
P.S. i usually shift at 3,000 rpm so maybe that's a little too high?
Offline
Jul 1, 2009, 07:51 PM
Drives: 2004 Lancer/2009 Lancer GTS Sun/Sound/Navi Package
Shift around 2500
Offline
Jul 1, 2009, 09:32 PM
I don't know about the GTS, but I have to shift below 2500 to get any kind of decent gas mileage. Anything above 2500 and the turbo starts spooling.
I haven't driven CVT but I'm assuming that if you modulate your acceleration, you might be able to force the motor to stay in say 3000rpm and have the car "rev" the transmission ratio to continue accelerating? There's gotta be a sweet spot somewhere.
Another thing to do is check the instantaneous MPG meter. I find that I get better gas mileage by briskly accelerating then coasting more rather than "slowly" accelerating and wasting fuel in the process.
Online
Jul 2, 2009, 06:31 AM
weight wont kill ur gas too much. I frequently am the one drivin everyone around on top of having things in my trunk, and i consistently get 28 29 mpg per fill up. I get this with a pretty even mix of driving and travelling at 75 usually and semi aggressive in city. I have gotten 33mpg a few times but thats all highway driving doing no more than 65.
__________________
HID Lo/Hi/Fog
RRM SRI V2
RRM TCM
Works Short Shifter
Offline
Jul 2, 2009, 05:59 PM
Drives: 2009 Lancer GTS
I get between 29 and 30 too. I do have a green drop in high performance air filter, but that is the only modification from stock I have. I would also check your tire pressures. I would say your best mpg's are going to be between 35 and 40 psi for the tires.
Offline
Sep 3, 2009, 12:50 PM
Also one big overlooked issue (not sure if it matters tho since we have TPMS sensors) is tire pressure. If your tires are underinflated it cuts into gas mileage. In my 03 lancer my pressure was low and my gas mileage was cut in half.
__________________
2009 Lancer GTS 2.4L Octane Blue
No Mods yet, but some coming soon i'm sure :)
Previous car - 2003 Lancer OZ, boosted with custom turbo kit at 7psi.
Offline
Sep 5, 2009, 07:30 PM
Drives: 08 RR Lancer GTS - CVT
I took this on a 9 hour road trip a few months ago.
going 70-75 the entire way i got 30mpg, it went up to 31.5 towards the end too.
But mine's a PZEV CVT, which are the most fuel efficient models (and slowest  ) of the 08+ lancers.
Offline
Sep 7, 2009, 09:01 PM
Drives: 2009 Mitsubishi Lancer GTS
i just got back from a 700 mile roundtrip and going between 70-80 highway i avaraged 29.5 on a 09 gts cvt with 2500 miles on it now
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
