Jun 4, 2009, 03:43 PM
Personal Sales Rating: ( 0)
Drives: black 08 lancer
HELP on how to change my oil!!!
I am new to the forum and im looking for some help. I have a black 08 lancer gts and have decided its time for me to save money and learn to change my own oil!!! Please break it down for me including what oil and filter to buy because im honestly clueless!!!
Thanks!!!!!!!
Offline
Jun 4, 2009, 03:48 PM
Personal Sales Rating: ( 7)
Drives: 2006 Evolution IX GG
im guessing there is a thread on this in the DYI section
__________________
bolt ons... tune one 91... 335 wtq 312 whp, 06 gg ix
Offline
Jun 4, 2009, 04:11 PM
Drives: 08 lancer es
Oil: 5w20 synthetic or conventional. most go with synthetic and some have said that once you go synthetic you cant go back to conventional which is total BS.
Oil Brand: its really up to you I usually use valvoline or castrol
Oil Filter: dont remember the numbers on it but you can look it up in the oil/air filter book in the store or have someone look it up on the computer.
Process: first you start by placing an oil bucket or whatever you are going to use to drain the oil into. Unscrew the oil plug from the oil pan( the oil pan is located on the passenger side just about directly under the floorboard you cant miss it the plug is facing the rear of the car) once you remove the plug clean the plug with a paper towel or rag whichever you choose. let the oil drain until it stops.
Next: remove the oil filter which is almost directly infront of the oil pan a little closer to the front of the engine. once removed let the oil drain from there. once it is finish clean off all the oil from the seal and threads.
Next: replace the oil plug back into the oil pan securing tightly. now onto the filter place a thin layer of new oil onto the rubber seal of the filter and screw back on( caution: do not over tighten the filter cause as the seal heats up it becomes a greater seal and over tightning will cause it to be hard as hell to get off the next time)
Next: fill with whatever brand of oil you choose as long as it is 5w20. takes 4.2 quarts.
Finally: after you have the oil filled crank the car and let it run for a few min and turn off. let the oil settle for a few and check the oil level (just to ensure that you have filled it properly)
Thats the process.
Just a tip you can warm the car up a little and the oil will drain faster.
__________________
Added: Gts Wing
Tint
Xbox Live Tag: BabyBoy34
Offline
Jun 4, 2009, 04:16 PM
thanks
Offline
Jun 4, 2009, 04:37 PM
Drives: Apex Silver 2008 Lancer GTS
I recomend pouring about half a quart directly into your filter. Remember people the Oil amounts with and without filter are very important. it says like 4.2 quarts w/o filter and 4.5 w/ filter if im not mistaken.
__________________
RRM SRI Intake
RRM Rear Strut Tower Bar
RRM Carbon Fiber Mirror Covers
RRM Carbon Fiber Splitter
RRM Emblem on rear
RRM Timing Module
Partially Debadged rear
Limo Tint on rear
Vortex Generator
Nikon D80 with Nikkor 18-55mm lens and 55-200mm lens.
Offline
Jun 5, 2009, 05:40 AM
Personal Sales Rating: ( 1)
Drives: 2008 Grey Lancer GTS (5spd)
If you care to do so, I always use engine flush when I do my oil changes. Most people will say you dont need it, but it wont hurt, and itll keep your engine cleaner.
Offline
Jun 5, 2009, 06:59 AM
Quote:
Thanks, what product to you use for this?
Offline
Jun 8, 2009, 05:18 AM
not sure what its called lol
but if u go by all the chemical stuff in the back of an auto zone or advance auto parts, theres a small silver can that holds like half a litter maybe and itll say engine flush on it. Should only be a few buxs.
Offline
Jun 8, 2009, 11:23 AM
Drives: 08 Lancer GTS
There's a how to by blacksheep. o.O
Offline
Jun 12, 2009, 06:27 AM
Personal Sales Rating: ( 5)
Drives: 1997 Honda Prelude 2003 EVO VIII
Check out the AMSoil website. It will give you the types of oil needed for your vehicle and the capacities.
__________________
AMS Stage 1,2,3--HKS 272 I/E Cams--
Turbosmart BOV--Greddy turbo Timer--
RPS Clutch 6-Puck disk--Hallman MBC
Fidanza Cam gears--ARP Headstuds
Shep stage 1 T-Case--w/TTP tune
339 AWHP 302Q
GET YOUR AMSOIL HERE!...
http://www.lubedealer.com/ExquisiteDetails/
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
