Go Back   evolutionm.net > Lancer Forums > Lancer (ES, LS, OZ) 2002-2007 Forums > Lancer How Tos / Installations > Lancer How To Requests / Questions / Tips
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 25, 2009, 10:23 PM   #1
Personal Sales Rating: (4)
Drives: 03 Lancer Es
Request: How to replace a radiator??
i have a punctured radiator and i need to know detail instructions on how to replace it because i dont want to have someone else doo it. i know its an easy job i just need a little bit more info thank you.
Offline
Old Jun 10, 2009, 11:16 PM   #2
Personal Sales Rating: (1)
Juan Martinez's Avatar
Drives: 03 Mitsubishi Lancer Oz Rally, 04 Mitsubishi Lancer ES
Send a message via Yahoo to Juan Martinez
Well, its alittle late, basicly, you take off the bottom hose and let it drain out into a pan. Take off the top hose and top mount pieces. Unhook the trans coolant line. Just lift out the radiator. Unbolt the fans and relocate to new one, reverse everthing. Put in new coolant. Its really easy after you drain it.
__________________
Build Thread http://forums.evolutionm.net/lancer-...ld-thread.html
Check out my rides at
http://www.cardomain.com/id/k_dog007
03 Lancer OZ Rally
04 Lancer ES
98 Eclipse RS (Traded in July 2007 for 04 Lancer)
01 Mirage ES (Traded in on Eclipse in 2005)
85 Pontiac Fiero (never made it on the road, sold 2004)
93 Eagle Summit ES (Traded in in July 2003 for 01 Mirage)
Offline
Old Jun 11, 2009, 05:53 AM   #3
Personal Sales Rating: (7)
blaze_125's Avatar
Drives: Yellow OZ
After you put everything back toget, you gotta drain the air out.
Pour in your coolant, don't fully close the rad cap open the bleeder and start your car.
Periodically check the coolant level by removing the rad cap and add some as needed. When you get a steady stream coming out of the bleeder, close the bleeder, top off the rad, tighten the rad cap and you're set.
__________________
Quote:
Originally Posted by Mechanic who worked on my transmission
I'm 63 years old and even I don't have that much play in my shaft
Offline
Old Jul 15, 2009, 11:09 PM   #4
thanks guys i appreciate it
Offline
Tags
2003, eclipse, radiaor, radiator, replace
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
