I Need Help! How do you change the brake light bulb on a 03 Lancer Tail Light?
Hi, I just need help on replacing a brake light bulb on my 03 lancer oz rally tail light. I already opened my trunk and took out the carpet that covers the tail light from the inside. I don't see any available openings where I can insert the bulbs in? I only see a wire and 2 little openings but it doesn't look like i can stick the bulb or my finger in there? Any info and help would be appreciated
My guess is it'd be similar to the newer model cause I'd see the same thing if I remove the carpet. You probably need to gently but firmly grip the housing from the outside and pull it out. There might be a clip holding onto it from inside the trunk as well. But I'm guessing once the tail light's pulled out, you'll be able to access the bulbs.
RSL4Evr
16
Oct 19, 2011 11:58 AM
ldubexpress
Nov 14, 2007 11:08 AM
