Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Noise when I come to a stop
Old May 9, 2015, 07:23 PM
Newuser213's Avatar
Past few month when I'm driving on local streets and coming to a stop or stop sign I'll hear some(I'd say 70% the time) squeaky or bouncy(maybe grinding? or like springs?). At first I thought it was my brake pads going bad so I had them changed but the sound still remains... I use to use the car for restaurant grocery(sometimes heavy, trunk filled up) shopping(half a year almost) with 3 passenger+ me as well and that could wear out my suspension? I'm starting to think that maybe a spring or shocks? or shaft? I don't know much about cars. I noticed that the gap (gap between the actually tire and the fender) of both side(passenger and driver side) of the back wheels are lower or lesser than the gap on the both front wheels, is that normal? My car is bone stock.
Need this fix! >< its embarrassing when I'm out with girls(usually i listen to music so it doesn't bother me but when a girl sits they don't like loud music[get my drift?]).
Old May 10, 2015, 09:03 PM
CamShaft's Avatar
Yeah, with constant overloading your springs may have sagged and suspension components may be worn out. You should get it checked out.
Old May 12, 2015, 11:27 AM
CamShaft's Avatar
The lancers cargo capacity is approximately 1000 lbs (including all occupants)
Old May 12, 2015, 11:34 AM
Newuser213's Avatar
Kind of broke to bring it to mechanic to charge me X amount to inspect the problem and X more amount to fix it(hopefully its the problem) or it cost more to fix something else...
Wanted to get a idea of or know if anyone had/known this issue before.
Old May 15, 2015, 08:22 AM
Veronica's Avatar
Can you post up a video of the sound? That might help us help you...
Old Jun 30, 2015, 03:34 PM
shinobee1's Avatar
any luck?
bryan013evo
Feb 16, 2016 07:44 AM
TACH_MOTOR_WORK
Evo 'For Sale' Suspension / Brakes / Handling
137
Mar 9, 2014 02:47 PM
TACH_MOTOR_WORK
EvoX 'For Sale' Suspension / Brakes / Handling
94
Nov 11, 2012 03:16 PM
Quick Reply: Noise when I come to a stop
