Go Back   evolutionm.net > Lancer Forums > Lancer (DE,ES,GTS) 2008+ Forums > Lancer How Tos / Installations > Lancer How To Requests / Questions / Tips
New! Use your Facebook to securely log into this site, click logo to login
Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 6, 2007, 11:34 AM   #1
Personal Sales Rating: (0)
Drives: Black 2008 Lancer GTS
Talking Solution to bypassing the DRL
Ok, I just ordered a kit from http://www.MobileHID.com that comes with a wiring harness. I think this might be our best bet in actually running hid's with minimal problems.
The kit is powered straight from the battery, and the relay switch needs little power to actually turn on. Plus the kit seems very reliable, saw the water and hammer demo they have.
Basically what I'm going to do is, I'm going to be splicing into the corner lights wiring and connect the relay switch there, so that the corner light switch will also be my headlight switch. This will leave both low beam factory connectors open and not used (bye bye DRL).
I have actually ran my GTS with the factory low beam connectors unplugged and got no warning or sound from my car, telling me I have a burnt bulb (I thank god for that). So leaving the factory harness alone is fine.
But, I plan to actually use my factory harness to power another set of foglights I'm going to be mounting behind the front grill, which means I can choose to have drl's whenever I want, by just flicking a separate switch. So this might be a win win situation.
Anyway, I just wanted you to share this info, and hopefully I will have pictures in about 2 weeks, if I can do this right.
Offline
Old Oct 6, 2007, 02:58 PM   #2
Bradley_J's Avatar
Drives: 2008 Lancer GTS
So basically, you are going to use the corner parking lights to relay your headlights on? I think that is a good idea, and could actually still work with regular lights (non-HID). As long as the relay closes when it gets power from the parking lights, it should work.
Offline
Old Oct 6, 2007, 03:18 PM   #3
The current that's going to the relay from the corner lights, is just to put the relay switch in the on position. The current used by the HID's is actually straight from the battery. So there should be no risk of overheating my factory harness.
http://www.mobilehid.com/wiring.jpg
Offline
Old Oct 6, 2007, 06:15 PM   #4
Personal Sales Rating: (8)
2009 Mitsubishi Lancer
08Lancer89's Avatar
Drives: Wingless 2009 Wicked White RalliArt
tell us how it works out when you get it, Rob this may help you guys out at RRM///
__________________
Mike
270 AWHP 290 AWT.
[X] AMS Small Battery Kit
[X] AMS BOV Upgrade Kit
[X] AMS Intake
[X] AMS Boost Pill
[X] AMS Single Exit Catback
[X] AMS ECU Reflash
[X] RRM Drop Springs
[X] Rota Torgues 18x8 Flat Black
[X] 8000k HID Kit
Offline
Old Oct 6, 2007, 07:58 PM   #5
Hawkeye's Avatar
Drives: Yes.
You... you're not going to have parking lights only, are you?
I mean, if the relay is getting its switching power from the corner lights, well they come on at parking lamp setting.
So it is a solution, and probably the most viable solution thus far! But I don't see parking lamp solution...
__________________
2008 Lancer GTS - loaded 5MT, SilverStar Ultra low beams
1995 Isuzu Rodeo S 4x4 3.2 5MT - 15x8 Ultra type 61 wheels with A/T KO rubber, Alpine CDA-9870 iPod connect, Infinity Reference speakers
1991 C/1500 454 SS - Belltech lowered 3.5/4.0, GearVendor Under/Overdrive, MSD ignition, posi rear end 3.73, fresh paint, hard tonneau.
Offline
Old Oct 7, 2007, 03:56 AM   #6
I don't really understand what you mean. I'm just tapping into the low current being fed into the corner lights to get a signal for the relay switch to turn on the hid system.
The way I'm going to have it, is that every time I turn on my corner lights, my hid will also come on. I see very little downside to this method.
Offline
Old Oct 7, 2007, 07:43 AM   #7
Bradley_J's Avatar
Yes, the low beams will have a relay (for each light) and will receive switching power from the parking lights. So, you could cut the main positive wire for the light, route it through the relay, and they would only turn on when the parking lights have power. I think I am going to try this today. It should only require a couple of relays, and some good connectors.... I don't think it should take that long.
Offline
Old Oct 7, 2007, 10:32 AM   #8
Hawkeye's Avatar
Drives: Yes.
Right, and like I said this is still the most viable conclusion to this issue.
But generally when you turn the stalk to parking lamps, you only get the parking lamps - no headlights. With your relay mod, you'll get headlights at parking lamp location. So you can't just have your parking lamps on; that's what I'm getting at.
Not the biggest of deals, but some people like being able to just turn on perimeter lighting in certain circumstances such as waiting for someone at night, you want visibility but not your headlights glaring all over the place so you just turn on parking lamps.
__________________
Offline
Old Oct 7, 2007, 10:48 AM   #9
EvoM Moderator
Personal Sales Rating: (88)
Blacksheepdj's Avatar
Drives: 2004 Ford Explorer, 1969 Chevrolet Camaro, 1997 Honda Civic (beater)
Quote:
Considering that we don't have this ability in stock form, it's not that big a loss, I'd think...
__________________
Xbox Live - DJ zero 1980
PlayStation Network - blacksheepdj
Offline
Old Oct 7, 2007, 12:56 PM   #10
The only time you can turn the parking lights only, is if you shut the engine off, turn it back on with the parking brake on, or with the engine fully off.
I can understand this might be an issue, but it's a small price to pay. besides, you can always install a undercar kit and use it as a parking light, which I think will look real nice, and completely legal unless you start driving with them on.
Offline
Old Oct 7, 2007, 02:18 PM   #11
empire4vr's Avatar
Drives: WW 08 GTS
I have seen a few pictures of the Evo X and it looks like it has HID's. I am in now way an expert on cars but if they will have them shouldn't we be able to just swap out the stock ones with those? Or would the DRL problem still be there?
Offline
Old Oct 7, 2007, 03:19 PM   #12
The ECU probably needs to be reprogrammed or probably replaced.
Although it's rather weird that the headlight assembly has a socket where you can plug the low beam plug when you have it disconnected it from the bulb, and that there is no warning signal telling you your headlights aren't working when you have it unplugged.
kinda seems like this car was rigged to have HID's.
Offline
Old Oct 7, 2007, 04:04 PM   #13
turdbo's Avatar
Drives: 03evo
Anybody notice that when you first get in the car and crank it, that the drl's don't cut on until you put the parking brake down. Maybe this could be a quick fix?
Offline
Old Oct 7, 2007, 05:18 PM   #14
I think everyone that has been trying to get rid of the drl knows that. which is why everyone is looking for a solution.
I'm so freakin excited about this, I hope the kit comes by next friday.
Offline
Old Oct 7, 2007, 05:30 PM   #15
EvoM Moderator
Quote:
Nope. Even if you drive with the e-brake on, the DRLs will come on.
Unfortunately, the computer is quite smart and integrated on this car.
__________________
Offline
Tags
2008, 2009, 87, battery, camaro, evo, fix, flicking, gts, headlamps, headlight, hid, lancer, relay, turn
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
